Carnauba Wax Shop
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 30-01-2009, 21:17   #1
Fizzy
Newbie
Seat Leon 1.6 2001 engine cut out
Hi
I'm wondering if someone can help me.
My Leon rather strangely cut out on me today while I was parking it
The car was rolling downhill so was in neutral - So I cant put it down to - "you just didnt give it enough gas"
Though before it did the rev counter started bouncing up and down like a yoyo and then cut out - It did start again however and was driveable
Does anyone have any ideas on what could have caused it?
Also on a rather general note, my car idles (ever since I bought it 18months ago) at 600rpm I thought this especially low for for my car as all the cars I have driven always idle at 900rpm (ish) Is this normal?
Fizzy
Fizzy is offline   Reply With Quote
Old 30-01-2009, 21:27   #2
Jimski
Leon Gone Ibiza Here!
Jimski's Avatar
Haha i get the same mate, my idling is all over the place when the car is cold, it also loves to cut out when its cold. I need to book her in somewhere and get things checked over, there are a few threads on cleaning your throttle body with carb cleaner, that helped me for a few weeks.
Jimski
__________________
-- EGR Reduction -- SuperPro Mount -- PD160 Intake & Panel -- SEAT Sport Strut Brace -- Whiteline RARB --
http://www.seatcupra.net/forums/showthread.php?t=255666
Jimski is offline   Reply With Quote
Old 30-01-2009, 21:47   #3
Fizzy
Newbie
Hi Jimski
Just came back from a quick drive - and it almost did it again!!
The weird thing is I put the car in reverse and gave it a little juice and off the rev counter went again!! So I quickly put it in first and gave it some and all seemed to clear?
This is very weird - The car is warm though!!
Old 30-01-2009, 21:49   #4
Jimski
Jimski's Avatar
My idle is all over the place whether the car is warm or not, but it wont cut out when its warm, it threatens to though!!
It is strange!!
Jimski
__________________
Old 04-04-2009, 09:52   #5
paul.sessions
had this problem after a while the engine light came on it going in the garage on tues for a throttle body clean and gasket replacement hopfully this will resolve the problem..
paul.sessions is offline   Reply With Quote
Old 04-04-2009, 10:13   #6
robbie2008
mk1 leon lover
does ti cut out when you turn the steering wheel?? if so there is a sensor which monitors the revs for the power steering i had this problem with my car i jus disconnected it! amm the sensor is located at the bottom left hand side of the engine near enough exactly below your driver side light i disconnected mine and now she doesnt cut out when im trying to turn the wheel but still does the odd time when im driving so to say must be a common fault with the mk1 leon esp if you have the 1.6 8v like me haha
robbie2008 is offline   Reply With Quote
Old 22-05-2009, 14:41   #7
paul.sessions
just had the same problem, kept cutting out when i dropped the clutch especially parking reversing coming to roundabouts, eventually the light came on it was the egr valve so i replaced thet and haven't had a problem since it cost £95 for the part from gsf and i fitted myself two 13mm bolts........
hope that helps
Old 23-05-2009, 20:04   #8
MonkeyB
Where abouts is it on the engine?
MonkeyB is offline   Reply With Quote
Old 24-05-2009, 08:00   #9
paul.sessions
http://s592.photobucket.com/albums/t...lsessions/egr/
the first photo is the egr valve which came off the car the second if you look closely is where is was situated i have marked on the photo, just underneath the cover..
hope this helps
Old 24-05-2009, 10:36   #10
wes c/fergus
new to seat!
wes c/fergus's Avatar
basically your best getting vag com done then before throwing parts on? mine was doing the same a few months back, i put new set of spark plugs and coil packs in her (needed the coil packs changed, done plugs during service) , its just started again with the same issues as you guys.
wes c/fergus is offline   Reply With Quote
Old 24-05-2009, 12:46   #11
MonkeyB
Thats great, thanks alot for your help Paul
Old 28-05-2009, 10:25   #12
robbie2008
mk1 leon lover
any body got ideas then???
Old 01-06-2009, 21:43   #13
robbie2008
mk1 leon lover
well lads any body got any ideas about my problem please adivce needed bigtime cheers lads
Old 03-06-2009, 14:17   #14
FASTER
Best check the EGR Vavle (they carbon up very quickly!) Ive got a AZD 1.6 16v 2nd EGR now
Symptoms are
iratic idle
cut out
rev flat spots
Shite performance
May not show fault code mine did not untill i took battery totally off and did read on VAG COM then it showed!
Worth a shot!
FASTER is offline   Reply With Quote
Old 04-06-2009, 13:34   #15
robbie2008
mk1 leon lover
cheers mate will do that are the parts expensive to replace????
Old 04-06-2009, 22:05   #16
FASTER
Not to much about £100 for the valve! do the battery trick see if it show fault codes first..
Old 06-06-2009, 13:07   #17
robbie2008
mk1 leon lover
alright i take it to do the battery trick ya just simply disconnect a leg of the battery does it matter wat leg or if both legs of it need disconnected what order and will the car be ok when i reconnect it again wont need to do anyfing???? cheers
Old 08-06-2009, 09:59   #18
FASTER
both teminals mate leave it for 5 min then reconect... Find your radio code first...
You will need to run the cars ecu learning mode with involves running the car at all rev ranges keeping around 4k revs i think, drop both front windows to the bottom and then top and run fans/aircon at fast speed so car feels a high voltage load under running conitions.... few oher small bits but can't remember what yet...
Get a mk4 golf manual (haynes) its in there!!!
Dan
Old 08-06-2009, 19:42   #19
robbie2008
mk1 leon lover
top class info mate thanks verymuch
Old 10-06-2009, 22:09   #20
MonkeyB
I know this might sound like a daft question, but what is connected to the opposite end of the little pipe that fastens to the EGR valve?
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 79
-SlicK, A5HL3Y, Aber1, adam cupra 20vt, airfilter, amccan10, ARG7, bedazzledhouse, Benji, blueavenues, BoardTracker, Cheshire_Tom, christianomoe, chumsofmanutd, CoMMy, CupraDerv-chris, D1SHABBA, DarkSeat, DPJ, edmong, egypt, Exocet, FASTER, Faydan, Fizzy, Fl@pper, forestwhite, Giant AC1, gram1210, guitarjon, gurpalbasra, Haggistech, Hairy, highguyuk, hydeh, Irie, james walker, jet-black, Jimski, kbrad44, kewe, kul20, leonsbvd, liamreloaded, m0rk, Macc, maky_LC, marcuswomersley, markmeus, markthispage, Martin_DSG, mike2926, mini, mjt, MonkeyB, MrBen2k7, Muttley, Nimzy, nit_mm, NotPotter, paul.sessions, Ricardo, Ringiho, robbie2008, sa06, SaipH, samu23, Saturbo, seantdi, Senor Vivo, seremotors, sie77, Skint, stolen, tanyacop, Torquemonster, wes c/fergus, xnox202, zilcho
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Leon Cupra-R... Is this my engine number??? Help Mutley08 Leon Mk1 3 26-12-2008 16:13
Rickard Rydell returns to the SEAT Leon in Macau ZBOYD BTCC & WTCC 7 16-11-2007 23:49
Bucket Seat/ Belt Mount/ Harness Fitting Guide (MK2 Ibiza) ibiza_95 Guides 2 03-04-2006 08:24
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
