| Sere Motors - NI SEAT UK Dealer of the Year. Based in Northern Ireland |
Thread Tools | Rate Thread | Display Modes |
#1 |
Newbie
Broken headlight
Ok...so the brackets on top of my passenger side headlight have snapped...I read on a post about part # 1M0 941 057 being a repair kit...would this be right for me?
If so, how much will it cost? :-D PS. The car is a 53 plate Seat Leon 1.8 20v. |
#2 | |
Dave the Parts Manager
Quote:
there is also 1M0941058 same price but not illustrated on ETKA, I cant remember the difference tho
__________________
![]() SEAT UK 'DEALER OF THE YEAR', GOLDEN GARAGES REGIONAL WINNER 2010, 2011 & 2012 PLEASE READ FOR T+C'S and FAQ's - http://www.seatcupra.net/forums/showthread.php?t=366731 or click banner to email me direct |
#3 |
1M0941058 is the part number for the RHS headlight.
I was told by the friendly local parts guy that part nos. ending even are for the RHS of the car, odd numbers are LHS. Hence 1M0941058 is RHS, 1M0941057 is LHS.
#4 | |
Quote:
__________________
#5 |
I replaced one of the top mounts on my offside headlight today, using the kit 1M0941058. The kit was for the top mounts only and contained one of each.
From what I gather there are 4 different part nos, the two that cover the two top mount kits, and 1 each for the lower mount repair brackets. The lower ones are differently shaped for LHS and RHS. 1M0941057 contains both upper replacement mounts for the LHS light. 1M0941058 contains both upper replacement mounts for the RHS light. 1M0941053 is the part number for the lower mount for the LHS light. 1M0941054 is the part number for the lower mount for the RHS light. These should hopefully be the right numbers!
#6 | |
Quote:
![]() ETKA is crap sometimes
__________________
#7 |
efr 6758 here i come
any chance can get the 2 top an bottom bracket for my r h headlight please :-)
1M0941054 is the part number for the lower mount for the RHS light 1M0941058 contains both upper replacement mounts for the RHS light. thankyou
__________________
#8 | |
Quote:
![]() Strange but true . . . . 1M0941058 is a fiver inc p+p
__________________
#9 |
status subject to change
how do these work? new bits that you glue onto the broken part? screw in?>
thanks
__________________
S.K.W.K.L.B.O.F H.K.S.K.P.P.P. |
#10 |
Senior Member
any one got pics of these as I think i may need these to sort the broken backets on the top of my light both are cracked
__________________
my 200 BHP LEON CUPRA TDI Thread Shells SHARAN TDI Thread Wales Thread "Like a Golf, but not a Golf, BETTER"
#11 |
you glue them on , they old bracket has to be removed an new one just goes in there old 1 was,
__________________
#12 |
exactly right - a steady hand with some superglue and its sorted. dont even need to remove headlamp from car, its actually easier with it in place. A local breaker buys them off me 10 at a time
__________________
#13 |
Senior Member
so does it matter which side I need
__________________
#14 | |
Quote:
#15 |
that sounds like the route id go, not sure about glue... may be ok for one broken braket but not if a few have been broken..
__________________
#16 |
Senior Member
anyone know if these will work on after market headlights ?
__________________
#17 |
Probably, they use the same mounting points.
Most aftermarket lamps are Valeo anyway, just in non-SEAT boxes
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to: Fix broken Load Signal cable from Alternator | AwesomeAl | Mk4 Ibiza FAQ's (6L) 2002-2008 | 39 | 25-01-2013 21:01 |
| twin bulb headlight questio | griff82 | Ibiza Mk2 | 6 | 08-02-2009 01:29 |
| Standard Seat Headlight protectors and Carpet Mats? | jamiebennett81 | Leon Mk1 | 12 | 20-10-2008 13:29 |
| Headlight Adjustment | cat | Ibiza Mk4 | 6 | 19-03-2008 21:38 |
