SERE
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk3
Ibiza Mk3 For 2000-2002 Specific Information.
Reply
Thread Tools Rate Thread Display Modes
Old 26-04-2009, 17:04   #1
Daaveey
Ibiza Cupra 2002 Blue!
Daaveey has 10 points
REVO Problems!! Newbie here!
Hello ALL! First post so bear with me, been searching for answers to no avail, I know alot of you have seen this all before, but hope, with all your expert knowledge, can give a Newbie a hand....
I have an Ibiza Cupra 2002 Plate and had a Revo Remap last year.
From the figures they quote, my car should be putting out around 206BHP, but I had it on the rolling road last week and its only putting out 185....
It had a new MAF about 2 months ago, everything on the car is pretty much standard except a custom made Stainless Backbox (with loads of baffle in to keep it quiet) and Forge Split-R in atmos/recirc mode.
The cars done 50k, no fault codes in VAG COM, I just cant understand it!
Anyone have any ideas?
Thanks in advance!!!
Added 11/5/09...
Sorry to be a pain, but could do with someones suggestions!
Took the car down to a different Dyno today (with a huge fan that nearly blew my legs from under me!), as i've had it serviced and bypassed the dump control valve.
Its given 182BHP at the fly @4224RPM and then really drops off, and compared to Revo's Graph on their website which shows peak power around 206BHP@5300rpm its peaking around 1000RPM lower. BUT its got all the Torque it should have 235lb ft@3432RPM, again with the peak torque around 1000RPM lower than it should be!
Its running exactly as it should up to 4200 RPM compared to Revo graph but then it seems like it runs out of puff and everything goes downhill.
I'm wandering if maybe its a boost leak at higher pressure?
On the other hand, do you think it could be the Bosch Super 4 Plugs that i have always had fitted in it?
Or the Splir R dump valve leaking pressure?
Its doing my head in, some suggestions please!
Only have Unregistered VAG com, and i'm not blaming Revo by the way.
Daaveey is offline   Reply With Quote
Old 26-04-2009, 18:27   #2
acidstrato
My Fast says shut up!
acidstrato's Avatar
acidstrato has 10 points
fmic
__________________
beezer cupra turbo Arctic - GONE....NOW - Milano Civic Type R
acidstrato is offline   Reply With Quote
Old 26-04-2009, 18:45   #3
cupramillo
The "Red Baron"
cupramillo's Avatar
cupramillo has 10 points
To be honest Revo figures for stage 1 are always on the positive side. Get the poper mods on (fmic,tip,turbo back etc) and you'll be pushing a true 200bhp
__________________
cupramillo is offline   Reply With Quote
Old 26-04-2009, 18:55   #4
andycupra
status subject to change
andycupra's Avatar
andycupra has 60 points
on a K03 turbo, which i think you have, then 200 bhp is hard work. On a good day, not too hot, correct fuel, correct settings its possible. But not that repeatable due to the tiny intercooler on the ibiza.
But then there is also the questions over dyno lottery, (do it again i bet its different). Was it set up correctly with the correct loads, correct gear used, decent cooling fans? did the car sit for long before the run? (heat soak)
what fuel you using?
what settings do you have it on?
How many miles has it done? its not a new car and to loose 15 bhp, (id say more like 10 in reality) is not that bad.
__________________
S.K.W.K.L.B.O.F H.K.S.K.P.P.P.
andycupra is offline   Reply With Quote
Old 26-04-2009, 19:03   #5
ibizacupra
Jack-RIP my little Friend
ibizacupra's Avatar
ibizacupra has 30 points
Quote:
Originally Posted by Daaveey View Post
Hello ALL! First post so bear with me, I have an Ibiza Cupra 2002 Plate and had a Revo Remap last year.
From the figures they quote, my car should be putting out around 200BHP, but I had it on the rolling road last week and its only putting out 185....
It had a new MAF about 2 months ago, everything on the car is pretty much standard except a custom made Stainless Backbox and Forge Split-R in atmos/recirc mode.
The cars done 50k, no problems in VAG COM, I just cant understand it!
what airflow are you getting on vagcom? max figure achived is what?
__________________
BADGER 5 LTD: PERFORMANCE TUNING
RACE PROVEN PRODUCTS & HONEST ADVICE:
Contact:07976 800775, 01453 822880
Bespoke Big Turbo conversions,AEM WMI,Forge,Ferodo,AP Racing Brakes,Custom Mapping,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compomotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more...
http://www.badger-5.com
email me at:bill@badger5.co.uk
ibizacupra is offline   Reply With Quote
Old 26-04-2009, 23:14   #6
Riko
MURDER WAGON
Riko's Avatar
Riko has 10 points
Mine was 206.5 at the fly, but about 185 at the wheels. Make sure these aren't getting mixed up?
__________________
Riko is offline   Reply With Quote
Old 27-04-2009, 13:25   #7
s1l3nc3r
ASBO car.
s1l3nc3r's Avatar
s1l3nc3r has 10 points
if its all standard apart from a stainles back box then your not going to be getting the full use out of the map...
As said above really fmic, filter, full exhaust (downpipe is very restrictive), tip. you should notice a nice gain over what you have now it will pull stronger...
__________________
When a man steals your wife theres no better revenge than to let him keep her
AMD STAGE 2, TURBO BACK EXHAUST,FORGE TIP, JETEX FILTER, 007P, FMIC, 6K HID'S, BOOST GAUGE, 20MM SPACERS, AP COILOVERS
s1l3nc3r is offline   Reply With Quote
Old 27-04-2009, 15:20   #8
M87NER
MATNER
M87NER's Avatar
M87NER has 10 points
as above or all down to dyno lottery.... you could put it on another roller and achive 195bhp ! different rollers different output claims..
__________________
M87NER is offline   Reply With Quote
Old 27-04-2009, 15:58   #9
PhilW
3071
PhilW's Avatar
PhilW has 10 points
Can we be the judge of it running right on vag com?
How do you know its running right? What rollers was it on? What fuel? Temps? etc...
I wouldnt get too hung up on figures.
__________________
PhilW is offline   Reply With Quote
Old 27-04-2009, 16:12   #10
warren_cox
Back from the dead
warren_cox's Avatar
warren_cox has 10 points
Interesting choice of title for the thread.
Revo's product is tested and validated after many hours of R&D. MANY people run the software without issue.
Why do you assume it's the Revo code that is the problem? All to often people blame the remap as they can't believe their car or the rollers could possibly lie.
Cars although mass produced are not blueprinted. Some will be quicker than others and that's just an unfortunate fact (probably a +/-5% variance in power when standard). Also this can be affected by the way a car is run in, driven, adapted and maintained (then modded). With dodgy MAF's, weak coil packs, and general component wear in the mix your car could potentially drop another 5% performance between services as oil and filters get grotty.
Then their is the bag or worms that is rolling road. I hear more and more people say that they are choosing to give the rollers a wide berth due to dyno lotteries. If you want to see whether an upgrade has made a positive difference then its a useful tool. If you want to diagnose a fault under load then they are useful. However of late they seem to bring about more sleepless nights than glory stories for most of the modding community.
Problem is as you get used to your car it stops feeling fast. My car runs at over 300bhp, and it feels absolutely ordinary until I get in a 1.4 litre hire car and realise how quick it actually is.
As suggested, get your cooling sorted, and maybe speak to a specialist about any weak points in your upgrade path that can be easily fixed.
__________________
Dolphin Grey Audi S3 2.0T Revo Stage 2+
Panther Black Audi S3 Black Edition 3dr MY12 on order, due for delivery wk 2 in October!
warren_cox is offline   Reply With Quote
Old 27-04-2009, 21:23   #11
Reuvers
I is a Dutch man!
Reuvers's Avatar
Reuvers has 10 points
warren you have quite a few posts under your belt, yet I never see that many.
However when I do, they're usually quite sharp.
good post mate
__________________
83 Golf 1
'92 VW Jetta G60
Reuvers is offline   Reply With Quote
Old 27-04-2009, 21:34   #12
warren_cox
Back from the dead
warren_cox's Avatar
good post mate
Cheers ears. I've been here for years, and I used to post a lot more than I do now!
__________________
Old 03-05-2009, 21:56   #13
Daaveey
Front mount and filter on the way then! Any recommendations? Had a K+N ind kit on it for a while but was rubbish when it got hot.
Thanks for the replies anyways, I know rollers are all different and there are so many variables that affect how it goes but seriously, the car seems sooooo much more than an extra 30BHP from standard, im happy with the result, definately worth the money and the easiest way of gettin extra power.
Just wandererd what everone elses experiences were with Revo on a standard car and if I was expecting too much thats all.
Another thing I wanted to ask, does anyone know, when the little old man pretends he knows how to use a laptop when he Remaps the car, he has to set the timing etc doesn't he? He set all mine to 5, bang in the middle.
Well when I use the SPS 2 to change the type of fuel, does it actually change these settings, or are these fixed and it changes something else? As it pulls so much harder with 95RON in the tank but set to 98RON on the SPS! Feels rubbish with the same fuel and setting.
BUT WHAT A CAR!
Cheers Guys!
Old 04-05-2009, 10:12   #14
karls cupra
Senior Member
karls cupra's Avatar
karls cupra has 10 points
BUT WHAT A CAR!
Cheers Guys!
peolpe on here like the green dynatwist induction kit or the large jetex one there the ones to look at also k&n use oil on there filter and its not good for a car with air mass sensor as it can cause the sensor to pack up cause of the oil ...
__________________
MODS SO FAR. green induction kit, forge 007dv, uni fmic, lowerded h&r/bilstein, gunmetal cupra alloys, silicone hoses, bonnet lifters, boost gauge, oil temp gauge in cupra r pod, lcr splitter, 6000k hids, seat sport front brace, omp rear brace
karls cupra is offline   Reply With Quote
Old 04-05-2009, 10:55   #15
pj1985
1.8T Power
pj1985 has 10 points
Quote:
This is sooo not a problem and if you think it is you dont even have to run it oiled!
__________________
IHI gone but not forgotten!
pj1985 is offline   Reply With Quote
Old 04-05-2009, 18:39   #16
Daaveey
I heard the oil thing with the K&N, but it was more of a heat issue why I removed it. Heard somethin about having the filter in the wheelarch as its cooler, this a big job?
Old 11-05-2009, 19:56   #17
Daaveey
Cheers!
Old 11-05-2009, 20:05   #18
__B3NNY__
OEM with a 'Twist'
__B3NNY__'s Avatar
__B3NNY__ has 10 points
Your going to either have to get yourself a full copy of vagcom or find sombody with it and get your car logged.
Im not to clued up about the Split R as they dont tickle my pickle but i have heard if not setup correct they can cause leaks and lead to problems..
Do you have a boost gauge?
__B3NNY__ is offline   Reply With Quote
Old 11-05-2009, 20:06   #19
Forbez
Huge Member!
Forbez's Avatar
Forbez has 10 points
What values are you getting from the Maf?
__________________
Cheers Tom
Audi A6 S line Le Mans & mk5 Golf Sport Edition Owner Former Ibiza Cupra owner
Forbez is offline   Reply With Quote
Old 11-05-2009, 20:15   #20
Daaveey
Nope, no boost gauge, its on the to do list but spare cash is hard to come by at the moment. Can it be found in VAG com if I get a full copy?
Maf can't be logged in vag scope can it on the unregistered version? Will only be able to read the tickover MAF value won't I?
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 145
-=Rob=-, -pseudonymous-, 20 valve ted, 23mjh, 594pidge, acidstrato, adp, andycupra, artemis_1991, aterro, AudiS3Quattro, beeko85, Bentley_Cupra, BigLad, Big_A_Cupra20vt, Bogwoppit, Bokac, ChrisA, Chriswaite130, cletus, ConradJellyfish, Crafoo, cresswell22, Cupra Gsy, Cupra Kev, cupra.al, cuprachrissy, CupraElliott, cupramillo, cus, Daaveey, dai cupra, Dan1.6, danielc16, Danjw, danny20vt, Danny_B, DaNnY_LaD, davidsonley1, daytona246, daza b cupra, dazpoynter, DEEKY'S-LEON, diggerbucket, Dodson, ebo007, Empi5, Fahid82, Feel, Forbez, fordgt40, fulls1982, gav_1, GraemeC, greg.w, Guile20VT, hamlyn, holty, Hughski, IbizaAlex, ibizacupra, ibizasport08, ibuckley, ikhlaq206, james.l, Jamie P, jayman303, Jedimaster65, Jimmeh, jivejester, jonnyboy, Jordan20vt, JTarry, karls cupra, krisbutler02, kyle'87, leegriffiths, leonbtcc140, LMJ, lm_gauci, lurk, M87NER, MarkE, mat_106, mikey88, modified_nutter, motty_90, mrmattholmes, mrvavavoom, mr_D, ndbrgr, Neale, Nickrobz, Noam, nuckinfuts777, parksy, perm, peter_cupra197, PhilW, Pingu101, pj1985, PriceysPunto, Proff_CUPRA 180, Pulsebassuk, quattronics, RabReith89, ReC]<, redcupraboy, Reuvers, revo carl, RichN, Richy88, Riko, Ross_Cupra-R, s1l3nc3r, s3tuy, SeanyK, SEATCOOBER, seatcupra2001, Sharky_82, shauncupra, sheph4rd, sibiza, SidewaysCupra, simon d, Smithy, sparkie1984, ss55eat, tarzan, tashacupra, tazcupra, thompsy121, toastie, tom w, tommy2008cupra, tooshy, Toxic, turbo009, turboboy, warren_cox, wisejason, yellow_fever, __B3NNY__
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Revo for 1.9 diesel Doddsy Altea - includes XL and Freetrack 10 10-02-2008 20:41
Problems With New Mk4 Ibiza Cupra OFX Ibiza Mk4 13 28-01-2008 21:38
Car booked in for REVO!!! seat130fr TDi - SEAT Diesel specific topics 41 26-01-2005 12:43
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
