P-Torque
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk3
Ibiza Mk3 For 2000-2002 Specific Information.
Reply
Thread Tools Rate Thread Display Modes
Old 02-05-2009, 16:32   #1
DaNnY_LaD
Big Turbo Leon Cupra R
DaNnY_LaD's Avatar
DaNnY_LaD has 10 points
Angry Abs Sensor i Still have light
Right i got a Abs & tcs light a few weeks ago and it was off and on...
Now ive fitted the drivers side Abs sensor the lights on all the time....Ive check all the wiring and its spot on and the Fuses are fine too...
This is the code i keep getting and it dosnt go away:00285 - ABS Wheel Speed Sensor Front Right (G45):
Copied from ross tech:
00285 - ABS Wheel Speed Sensor Front Right (G45): Signal Outside Specifications
00285 - ABS Wheel Speed Sensor Front Right (G45): Electrical Fault in Circuit
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
ABS Wheel Speed Sensor Front Right (G45) faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
Check ABS Wheel Speed Sensor Front Right (G45)
00285 - ABS Wheel Speed Sensor Front Right (G45): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Front Right (G45) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
Possible Solutions
Check ABS Wheel Speed Sensor Front Right (G45) Installation
Retrieved from "http://wiki.ross-tech.com/index.php/00285"
__________________
HTA-GT2868R Leon Cupra R Built By INA Engineering & AKS Tuning
DaNnY_LaD is offline   Reply With Quote
Old 02-05-2009, 18:53   #2
Reuvers
I is a Dutch man!
Reuvers's Avatar
Reuvers has 10 points
I'm getting worried...
I've been having the same problem for the last couple of weeks.
only code I am getting is the 0285, due to my wiring. I redid the wires and it was fine for a bit now it comes on all the time.
I now pulled out the fuse waiting for time to solve this.
Should you find out more keep me updated please
__________________
83 Golf 1
'92 VW Jetta G60
Reuvers is offline   Reply With Quote
Old 02-05-2009, 19:14   #3
Fl@pper
Cruising with the 6 Pot..
Fl@pper's Avatar
Location: Easy life Cruise control with 200bhp of Bavarian RWD slushboxed Leather Comfort :)
Fl@pper has 10 points
Quote:
which pins in the ecu connector did you test ?
__________________
Fl@pper SouthernPikeyBigEaredHotRoddingIronMaidenMetallicaFan@e-parts.co.uk
Fl@pper is offline   Reply With Quote
Old 02-05-2009, 19:30   #4
sparkie1984
sparky
sparkie1984 has 10 points
ive just had an abs fault come up, but mines front left, outside normal parameters, must be the season for it lol
sparkie1984 is offline   Reply With Quote
Old 02-05-2009, 20:15   #5
DaNnY_LaD
DaNnY_LaD's Avatar
Quote:
you've me flapper.
__________________
Old 02-05-2009, 23:02   #6
Fl@pper
Fl@pper's Avatar
you said you checked all the wiring so i was wondering what u did to make sure it was ok
you can test the sensor itself by measuring the resistance and the wires i usually test both resistance and continuity if possible
__________________
Old 03-05-2009, 09:03   #7
DaNnY_LaD
DaNnY_LaD's Avatar
Flapper do i test it with a digital Multimeter?
I just done a visusal Check on the wires in the arch..
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 91
20vtwy, 50spence, adamcampo, adrian.porter, alex88, alexbradford, Alexis27, antsdd, Armitageshanks, Backdraft, berkeley12, ChrisCurzon, crawford62, cupra tda2, CupraElliott, Cuprapaul91, Cupra_Wayne, Cupra_Wob, cus, Dan1.6, DaNnY_LaD, DarrellcupraR84, davidcupra, davidjcox, dazpoynter, Deanf, denzil691, dg-1984, DJ Walkers, DJ-LIAMC, donCorrado, donie, doti b, DSent, EZ Tutty, Fl@pper, Flash04, G5NRL, gib9060, GRD, GREENYSR7, greg.w, Guffers, Jon_A, jumpinjackflash, krisbutler02, lacojski, leon sport, Leon180, libiza2007, living2xs, magicmcfc, Malk, Masterkm, merlykx, miller 666, mrsixstring, neillys75, Pat D, peter_cupra197, Phil-B, PhilW, PintOfGuinness, Pudders_, RabReith89, raymondk, RD84, Reuvers, Ric 2001, robertj, roblcr, s1l3nc3r, SEATCOOBER, shiller1984, SlipStream, sparkie1984, struds, swilky23, sydoggkdy, tarzan, Timo., toby bwoiii, tooshy, TrisLC, turbo009, turboboy, Tyler_, whitey987, yakirmac, [RSms]RS, __B3NNY__
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ABS light JimmyJames Ibiza Mk2 25 09-07-2009 10:48
Replacement panel filter cause TCS light to come on intermitantly? L3DNT Leon Mk1 4 16-04-2009 20:18
ABS Fault - HELP!!! beezanick Ibiza Mk3 4 13-01-2009 22:41
ABS light danieltm Leon Mk1 6 09-09-2008 18:59
interior light, light packet ?? coxxic Leon Mk2 3 18-10-2007 09:24
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
