right.. for those who thought i may have been sat on my arse...
I am very very very busy, and bespoke project builds like these are custom all sorts of parts which soaks up time like a sponge.
It does'nt look like much, but there are litterally >100hours in this build.
it runs tho!
http://www.youtube.com/watch?v=ZkSrs_j_OHY
http://www.youtube.com/watch?v=yLmU8V84zkU
Fuel pump located where filter was, and filter located in engine bay now. Hooked up to get working, whilst the new stainless steel push conenct fittings are being made, then just swap out the temp pipes for the pukka ones. Sufficient to get it going and tested tho
some slight weaping from the oil filter sandwich plate outlet fittings to sort (tighten), and a small coolant dribble to also tighten, otherwise all look ok so far.
first start of the key it fired up.
few little finishing bits to do, and mapping of course. We are very nearly there finally.
first map to flash into it tomorrow, so it knows its got bigger injectors and MAF, and we take it from there.
Hoping for some dry conditions.
as traction is going to be a non-starter
