Do Porsche C2 rims clear 312mm brakes?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Didn't really want to open a thread on this, but have not been lucky finding an answer on this.
It would concern only the fronts (16 inch), probably around 7J with ET around 60, however reduced to 35 with a 25mm 5x130 to 4x100 spacer.
I currently run 16" BBS RC's 7.5J wide. I had to shave a little off the calliper, as that was touching the inside of the rim. So the 312mm disc itself will fit the 16" rim, I know. its the calliper I'm worried about.
I realise that best way is to find a set a try them, however most are a bit of a drive away, so maybe someone on here has tried/knows.
cheers
Dec 13, 2006
724
Ashford, Middx
I've been looking at getting another set of porsche wheels. They all look like they have quite a large caliper clearence anyway. Must be as most prosche's seem to use 4pot calipers so they need a healthy bit of clearance.
I think they'll be ok, but dont hold me to it, lol.
