P-Torque
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 18-07-2009, 18:43   #1
shorn
shorn has 10 points
Passenger Side Rear Door Will Not Open!
Hi all,
I have a mk1 1.9TDi 130 Leon that I'm having a slight problem with. The rear passenger side door will not open. I have tried it from inside and out but it just will not unlock. Every other door is fine, and this door was working because I only opened it a couple of weeks ago as I installed a car seat base! Im not too sure what to do or try?
shorn is offline   Reply With Quote
Old 19-07-2009, 00:50   #2
shorn
shorn has 10 points
Forgot to add, I've tried giving the handle area a whack to no avail, made sure I've pulled the internal handle twice and the interiior windows still work fine!
On a sidenote, MOT is due this week, would this be a reason to fail it?
Old 19-07-2009, 11:11   #3
flares
flares has 10 points
I had that with mine , central locking mechanism was shot . About £90 for a new one , you`ll have to try & get the door panel off to open the door though
__________________
18" TSW Volcano`s
Lowered 30mm on Koni`s
flares is offline   Reply With Quote
Old 19-07-2009, 13:03   #4
Gordz
Caught The Mod Bug Again!
Gordz's Avatar
Gordz has 10 points
I had this on my mk3 ibiza, just had to continually press the unlock button on the key until it opened, or lift the door pin up with pliers! My leon doesn't have door pins and so I assume yours wont either, so just try the continual unlocking with key, or get the door panel off and have a good look and fiddle around?
Shouldn't fail an MOT I wouldn't have thought, I've watched garages perform MOTs in the past and they have no need to go into the rear of the car, so they'd never know!
Gordz is offline   Reply With Quote
Old 19-07-2009, 14:10   #5
drue1
drue1's Avatar
drue1 has 10 points
it would fail as all doors and boot and should open from inside or out
try and get the door panel off or get the pin up
drue1 is offline   Reply With Quote
Old 19-07-2009, 16:19   #6
Gordz
Gordz's Avatar
Gordz has 10 points
Quote:
Is this on the actual MOT 'checklist'? As like I said, I've seen an MOT done all the way through just to see what they actually do etc. And never once saw them open my rear doors!
Old 19-07-2009, 17:27   #7
LEE69
Stage 2 Revo'd
LEE69's Avatar
LEE69 has far too many pointsLEE69 has far too many pointsLEE69 has far too many points
http://www.motuk.co.uk/manual_620.htm
Quote:
Open and close the drivers and passengers' doors. Check that each latches securely in the closed position. Check also that front doors can be opened from both inside and outside the vehicle.
__________________
My Car
Did you not get a manual with your Leon, or want a .pdf copy?
If my post has helped you click the scales to the left and leave me some rep points.
LEE69 is online now   Reply With Quote
Old 19-07-2009, 18:10   #8
Gordz
Gordz's Avatar
Gordz has 10 points
Fair enough! Maybe I just missed the guys doing it!
Old 19-07-2009, 18:40   #9
Nutkin
Pop-a-Keg ya?
Nutkin's Avatar
Nutkin has 10 points
if you remove the rear seats then its not a failure
rear doors only have to open if people can sit in the rear.
__________________
http://www.seatcupra.net/forums/image.php?type=sigpic&userid=15218&dateline=1305554707
Ibiza MK5 Owners Club
Nutkin is offline   Reply With Quote
Old 19-07-2009, 18:53   #10
LEE69
Stage 2 Revo'd
LEE69's Avatar
Might have to remove the belts too.
__________________
My Car
Old 19-07-2009, 19:17   #11
Gordz
Gordz's Avatar
Gordz has 10 points
Here's my thread from a while back when I took the rear seats out of my old Ibiza
http://seatcupra.net/forums/showthread.php?t=184477
Old 19-07-2009, 19:17   #12
Nutkin
Pop-a-Keg ya?
Nutkin's Avatar
Quote:
nah if theres nowhere to sit then there is no need for belts or doors. in spain cars come like this. tax is cheaper if you can call your car a commercial vehicle.
__________________
Old 19-07-2009, 23:01   #13
shorn
shorn has 10 points
OK, well just having a look at that link to the MOT manual and it actually states as a reason for failure...
"b. a driver's or front passenger's door cannot be opened from both inside and outside the vehicle from the relevant control in each case."
Now that is specifically stating a FRONT passenger door, so resumably the rears will not be included in the reason for rejection. I shall probably ask whoever I book it in with before hand.
On the subject of the door not opening, my wife tells me that it did this a while back, but then started opening again.
Will it be possible to get the door card off whilst the door is locked shut?
Old 22-07-2009, 18:40   #14
shorn
shorn has 10 points
Anyone got anymore suggestions on getting the door open or similar experiences?
Old 22-07-2009, 18:47   #15
Gordz
Gordz's Avatar
Gordz has 10 points
I was right then! That would be why I never saw the MOT guys at the garage open the rear doors! lol
You could possibly prize open the top of the door card and have a look in? Might be handy to take out rear seats? Maybe could get all of door card off that way? Working from memory here, lol.
Old 22-07-2009, 19:13   #16
Nutkin
Pop-a-Keg ya?
Nutkin's Avatar
get a new door card and a dremmel and cut it off.
__________________
Old 22-07-2009, 19:13   #17
drue1
drue1's Avatar
drue1 has 10 points
does the door pin go up when open the doors with the key/fob if not try some wd40 around the pin.that might help
Old 22-07-2009, 19:16   #18
LEE69
Stage 2 Revo'd
LEE69's Avatar
How are they going to check the rear belts if they don't open the rear doors?
There are screws under the handle, remove them and the door card comes off, but the mechanism is then behind the metal carrier.
__________________
My Car
Old 23-07-2009, 02:44   #19
shorn
shorn has 10 points
No door pins unfortunatley! I'll have a go at trying to get the card off but mightend up sticking it in garage as need the car pretty urgently!
Old 23-07-2009, 08:25   #20
tonyjo
tonyjo's Avatar
tonyjo has 10 points
This happend on the rear drivers side door on my LCR. In fact, its happend twice now. It will require a new central locking motor as mentioned in this thread. My local stealer only charged me £130 for a new one, which included fitting and VAT. Not too bad.
I also could not open my door. However, I finally managed it by inserting the key in the drivers door and opened the lock manually. Then, leaving the key in, carefully open the rear door from the inside. With just the right amount of pressure it opened. However, the down side is, once its open you can never lock it! No idea why this worked, or if it opened at all because of what I did.
The mechanics at my dealer thought that it was caused by the classic water leakage problems that Leons suffer from, and the lock failed due to excess moisture.
Good luck!
__________________
tonyjo is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 204
&rew, -SlicK, 1000baird, Adz87, ajay_parekh, alant092, alecgr, alextdi, andi leon frtdi, andycupra, antony winfield, apollo996, arferfuxsake, Azza_, backus, Ben111, benhampshire, benjay86, Big Geoff, bigbrutha, bildo, BlackIce, BoardTracker, bob851, Bradz, Braindeadhmster, bravo, brianleon, bully, carlos73, ceejay90, chris.reid, CHRIS87, chrisdoxy, clouduk, cmd, CMR, colmforde, coope182, cra19n, craigo, Cupra Kev, Cupra TDI 150, Cupra-jb, Cuprajamie127, cupratune, cupra_tan, cwharreld, Dan James, DanEdwards, dave_ph, davidhunter, daz1970, Daza, dent, djdorse, djeclipse, djjake, DJLC01, DMackie, dollymixture_z, drue1, EKE Ibiza, EmDee, envy_vwm, escovedo, Exinferris, flares, funkybiscuit, G2232, gac, Garetht, garveyk, ginge100, Goacher65, Gordz, granthathaway, greganderson, gvala, Haggistech, Hobbiniho, HugoGouveia, ijmok, james walker, Jamie225, JamJay, jazz819, jennings, JGTIS, JimiJon, jinjoh_ninjoh, Jirwin, Joe K, joely, Joe_G, johnmoore103, jonathan_phang, Jonny, JR750, jr89, junglist_matty, Juri5120, keany19, kev660, kevlpool24, kewe, King kong, Kris.T12, LCR 225, lee123, LEE69, LeonUser, Lewvr6, libiza2007, LisaK, lolipoppurple, Lowie, mac magic, marcus037, Marthamm, martnewts, Martyn FR, Matt P, matt110tdi, Mattrix, MCGlasgow, Mewcenary, MI 55UTH, Mike R, mikesndbs, mikey306, mjt, MK Guinness, Moffat, munkyboy, munners, NAB_ARCK_86, nibbles, NRM, Nutkin, offitmassive, patang, paultoledo, plums, PnP, push110, qed296, R333DDX, r6_allan, rackha, rallynut, redeye, richjboyd, ridavey, rix, RO83, rob - 73, Rossarm, rsmith, sala7, samfla, Seagu11, Seat racer, sevenyearibiza, shaunymac, shelbournes, shorn, Silentnight*, Si_TDi_FR, snoopz, spiff, Steve, Stevie D, TAOTAO, tayloricedesign, Techno Toledo, techpunk23, TerryCupra, thebody, Tigertim001, Tim__jones, tonto, tonyjo, treborleon, Trev, TRIBALSLEEVE, tripdiesel, troy.wyse, truCido, tszab, twitterers, v0id, vin297, Watson1244, wayne lcr, will105, worzel1, xDaNx, xxjay247xx, yookie, yusuf_1977, zilcho, zx6r
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
2000 X Plate SEAT Leon 1.6S rear passenger side footwell found to be soaking Al Leon Mk1 7 10-04-2008 22:14
Passenger side rear ligh cluster franl Mk1 & 2 Toledo 0 26-01-2008 21:05
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
