Forge Motorsport
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net Sponsors - Trading area » Integrated Engineering
Integrated Engineering Integrated Engineering: Enthusiasts dedicated to engineering and designing the highest quality connecting rods for SEAT, VW, Audi and Skoda. Check out our site for all your performance needs including the following brands: JE pistons, Supertech vavlve train, SPA manifolds, Cat Cams, Walbro, Siemens Deka, Bosch, Eurodyne Software, ARP, Peloquin and our own SAI blockoff plates for 1.8t and VR6.
Reply
Thread Tools Rate Thread Display Modes
Old 02-10-2009, 06:59   #1
pete@integrated
Junior Member
pete@integrated has 10 points
***IE: Timing Belt Drive Pulley Dowel Pinning Kits... DIY!
When building a high HP / high RPM 1.8t, dowel pinning the timing belt drive pulley is one essential step to keeping it in one piece. Normally, this requires a trip to the machine shop, crankshaft in hand. Not anymore. We have sorted out and produced a kit which allows the end user to quickly and effectively dowel pin their crankshafts without any special machine tools. The kit is based around a brand new, OEM timing belt pulley, which we then place into our HAAS machining center and spot drill, drill, ream, and counterbore a precision bore in. We have carefully setup this bore so that the drilled portion can be used as a pilot hole for drilling the crankshaft, without damaging the reamed, precision portion of the hole which is the dowel pins future home. We are using a high strength dowel pin, capable of supporting a shear load of 7200 pounds. This will support the loads whenever they are large enough to overcome the friction in the joint provided by the clamping force from the bolt. This prevents the keyway from shearing and the proper timing from being lost. In addition, this also positively keys the gear to the crankshaft so that exact timing is maintained.
This kit also allows the crankshaft to be easily dowel pinned with the crank still installed in the motor, even in the vehicle. All of the necessary work can be performed IN the vehicle.
Kit includes:
[li]Brand new OEM Timing Belt Pulley, CNC spot drilled, drilled, reamed, and countersunk. [/li]
[li]High strength alloy steel dowel pin capable of supporting 7200 pounds of shear force. [/li]
[li]Drill Bit [/li]
[li]Precision reamer to ensure perfect fit of dowel pin [/li]
[li]2 Page Instruction manual with pictures. [/li]
Available NOW- CLICK HERE
AEB Early 1.8T Kit
__________________
pete@integrated is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 46
acerman, adja240986, albevan, Armitageshanks, audiintegra, bertrum, Celcius, cupra-tfsi, Damoegan, dan.h, Danny@INA, danthemanwhocan, Dave@integrated, Dibs1980, dom b, drrn, EZ Tutty, ibiza_95, in10sity, Indy, Johnsey, Jonezyfr, Jordan20vt, kevinking2020, L.R.C., matt_s, MK21147, Mook, old yella, pete@integrated, PhilW, Pingu101, Prebs, rsrich, Shaunyboy, splatrat, STOCKY, Tom Duff, tombird, vazelos@ibiza, vwsean, westallc, wild willy, Yosh, zacxanthi
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Timing belt change coco g Leon Mk1 1 20-09-2009 07:07
as anyone done timing belt lit and waterpump dai cupra Ibiza Mk3 6 15-01-2009 14:16
Power steering/auxillary drive belt problem Bruffy66 Leon Mk1 1 11-12-2008 09:41
Timing Belt Garetht TDi - SEAT Diesel specific topics 5 16-10-2008 08:13
v5 170bhp ancillery drive belt tol16v Mk1 & 2 Toledo 1 07-02-2008 21:25
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
