seat ibiza 02 problem rear and side light fault
shelbournes
I have a seat ibiza 2002 plate ...that has developed a fault...
The drivers side front side light doesn't work and also the drivers side rear light doesn't work
I have replace both bulbs ...does anyone have any ideas on how to fix this or what could be wrong ...thanks for any help ...kind regards
shelbournes
thanks for your help so far ...does anyone know which fuse this could be ... I have currently not sorted the problem out
if anyone know please could you let me know a.s.a.p
also does anyone have the fuse position list ...or a diagram that I can have
its for a seat ibiza 2002
shelbournes
i have now checked all the fuses in the panel and the bulbs ....
I have just put a tester accross the fuses and they are o.k
is there a relay that it could be
what I cannot understand is that it is only 2 lights that are out
the drivers side front side light
and he rear light drivers side
....really does seam strange
the back light is the main problem as it is obviously a problem with the dark nights
this is still off when the main beam lights are on ...right hand side rear light is out then as well
does anyone know whether they are linked
shelbournes
hi all ....I have checked all the fuses and all the bulbs have been changed
has anyone any other ideas on this it is driving me (excuse the pun) mad
I can only think that it must be the fuse box or the switch itself that is at fault
unless you know better ....please help
any info about the wiring would be great
kind regards
