| Ibiza Mk4 For the 2002 - 2008 model |
Thread Tools | Rate Thread | Display Modes |
#1 |
My outside temp reading has been acting strangely.. -44 degrees C today
. I took off the passenger side fog light grill and noticed the sensor had fallen from its place in the bumper. I found it dangling and checked it out (physically looks ok) and replaced it in its 'slot' in the bumper. Turned on car and temp reading was --.-- C. Fiddled around with it again and got a reading again of 1 degree C which sounds a little now.I ran VAGCOM and found this error.. 00779 - Outside Air Temp Sensor (G17) 30-10 - Open or Short to B+ - Intermittent I'm guessing its better to replace this sensor.... do you just solder the new one into the existing wires or do you have to replace the old wiring too?? (would rather not replace wiring.. it would be a pain to do this I am thinking.. Anyone know how much these sensors cost and what the best way of fitting them is? thanks
#2 |
The Gentlemans Express
further back from the sensor there will be a plug and socket mate, you will need to open the plastic trunking that the wiring is protected in.
#3 |
cheers..
On a slightly separate note can you turn off the warning beep when it gets below 4 degrees C with VAGCOM? |
#4 | |
Teaching the kids
Quote:
That always scares the crap out of me... that and the low petrol warning!
#5 |
Does this sensor effect anything such as air con etc..?
#6 |
Interestingly its giving me sane readings today 6 degrees this morning and 11 degrees this afternoon
#7 |
Senior Member
I think it's used as a reference for the climate control system - certainly my father's old mk3 did some weird things with the climate control when it developed an exterior sensor fault
__________________
Now - 2 x Audi A3 2.0 TDI SE - 1 Manual & 1 S-Tronic! Previously - Ibizas - FR TDI & Sport TDI, Leon - 1.4 S, Leon - FR TFSI |
#8 |
Senior Member
Oh yes, it disables the cooler compressor below - maybe 6C to prevent freezing in parts of theh system. That is mainly the reason why folk give in and sort this problem as having an indicated 4C in high summer means no chiller!
#9 |
ok cheers, It seems much better today, but I will keep an eye on it as I suspect there is an intermittent fault there.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 68
| Acksaw, awins, benuk, Big Ejit, BoardTracker, bubba, Chino_UK, chris4500uk, CrossyR, Cupra R, darkhorse, DEAN0, dicky FR, DieselBerry, d_darko, f1remandans FR, farmermo, Glennolls, Gooner_Mike, Haydn, Ibiza 130 tdi, ibiza_adam, james walker, jeffery, jkr1977, kidinspace, krussel, LCR_Tom, Leigh15, leon20v, LeonL, luna fr, markm, martin150, MartinDov, MATT RILEY, mikew, Morlock, mrvavavoom, n11tht, Nath., neapoletan, Neo, nick9one1, pavil, pawel, pedro-tdi, pete34a, pete_266, philmccavity, Redcupra20vt, RoSonic, RUM4MO, RVP09, ScottHmk4, Si_TDi_FR, slim, smark32, stanliz1, stuy, TheCraig, TJP, tomd1338, Trickmonkey74, turbo009, Unt_Gos, Veyron, vroomtshh |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cooling, fan, temp guage and more problems | jy5eire | Mk1 & 2 Toledo | 9 | 13-08-2009 14:43 |
| Temp gauge issue (another one) | msmalls74 | Mk1 & 2 Toledo | 1 | 25-04-2009 18:13 |
| Secret Clima Functions | gleon | Leon Mk2 | 48 | 16-01-2009 04:21 |
| Outside Air temp | Rossco_ | Ibiza Mk3 | 10 | 27-07-2008 10:35 |
| ibiza mk3 air temp sensor | 5k0da...t3ch | Ibiza Mk3 | 8 | 24-06-2008 21:19 |
