Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 16-12-2009, 14:30   #1
NI3K
NI3K's Avatar
NI3K has 10 points
cupra tdi egr valve?
any suggestions for websites to source EGR valve from?
recently had engine management light on which showed up as egr valve, we took it off cleaned it and put it back on but since then engine management coming back on, startup is a bit rough for first couple of seconds and can be a bit jerky at part throttle or when pulling away below 1500rpm. im assuming its still the EGR valve. its an 04 cupra tdi 150. is there a egr replacement which wouldnt make the engine management light come on?
NI3K is offline   Reply With Quote
Old 16-12-2009, 14:49   #2
Ant FR
Ant FR's Avatar
Ant FR has 10 points
can you not put an allards egr replacement pipe on. I hjave one sitting at home to put on my beeza cupra tdi. I too have the jerky pull away on cold starts, so much it sometimes stalls. was told the engien management light will not come on with it.
__________________
EP3 civic type r in championship White
Ant FR is offline   Reply With Quote
Old 16-12-2009, 14:55   #3
NI3K
NI3K's Avatar
NI3K has 10 points
from what ive been reading looks like the management light will still come on unless egr is turned down or disabled. anyone near dundee with vag com?
__________________
Seat Leon Cupra TDI 150. Ducati 749. Kawasaki ZX636 B1H.
Old 16-12-2009, 15:41   #4
GlanzaV
I start fires!
GlanzaV's Avatar
Location: Glasgow (Live) Edinburgh (Work) Ayrshire (Haunt)
GlanzaV has 10 points
Hi!
If you removed and cleaned the EGR but never blanked off the valve you shouldn't really get an EML...
I've read a few posts on this and think it may have something with the anti-shudder valve being faulty, which can blow a 10A fuse (in the engine bay fuse box) -- so maybe it's worth checking those to see?
__________________
GlanzaV is offline   Reply With Quote
Old 16-12-2009, 15:49   #5
NI3K
NI3K's Avatar
NI3K has 10 points
any ideas which fuse this could be? looked in the handbook but couldnt see anythin obvious for which of the fuses to check
__________________
Old 16-12-2009, 16:15   #6
GlanzaV
I start fires!
GlanzaV's Avatar
Nope... the thread I read a while back just mentioned a 10A fuse in the engine bay, he replaced the fuse cleared the EML and then a few days later the EML came back on, under inspection the fuse had blown again.
__________________
Old 19-12-2009, 20:42   #7
laawtytdi
laawtytdi's Avatar
laawtytdi has 10 points
i've got the problem. it's a fault with the manifold inlet flap motor not opening and then it surges back and blows a fuse. my additional engine heating fuse is blowing 10a think it's number 14.
Let me know if you get to bottom of it.
any guides for removing the egr to clean would be appreciated.
cheers
laawtytdi is offline   Reply With Quote
Old 20-12-2009, 08:12   #8
NI3K
NI3K's Avatar
NI3K has 10 points
got another EGR valve ready to be fitted as a few mechanic friends said that should be all it is so will report back once thats on
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 46
adam cupra 20vt, Ant FR, AntneeUK, BenG, chris285, chriz1, Craigbarnley, danmay, danthevanman, darkhorse, DarrenJ, daveyboy32, Dave_88, davidmills2002, devonfr150, drooghi, drvince, dylan7685, Fozly, georgebibizafr, GlanzaV, great_kahn, jmackay2, karizma_fas, krisbutler02, kyleb123, laawtytdi, Laser, lukecupra2001, luke_h, MATTCR, MrBen2k7, Muttley, n11tht, NI3K, oldman, PTM30, Raj, rallynut, ratgreen, robbob, Seat_Stu, tangomachine, turboboy, uzi_cupra
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Leon Cupra 2.0 TDi vs Ibiza CUPRA tdi G!zmond0 Leon Mk2 28 14-09-2010 23:15
Difference between FR TDI and Cupra TDI the_fbi Leon Mk1 3 07-07-2009 13:03
Ibiza Cupra TDI Review Hindey Ibiza Mk4 18 06-06-2009 18:27
Cupra R or Cupra TDI MrTs_Cupra Leon Mk1 31 24-01-2008 20:07
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
