P-Torque
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 08-01-2010, 09:33   #1
adzer
adzer has 10 points
engine light is on and reads fault code p0116
i'm in need of some help plz guys, i have a 2005 ibiza cupra.
engine light is on and reads fault code p0116 - engine coolant tempature sensor (circuit/range)
so i changed the temp sensor, reset the light and it came on a few hours later.
i've just bought the car and garage is waiting for a part for it, its a fan with 2 pipes, one comes from exhaust into the fan then from the fan into the air box.
the pipe from my fan into the airbox is missing as the garge is waiting for replacement part.
would this cause a fault code to come up??
if its not this thats causin the problem i'm guessing it's a wiring fault?
oh and i think the cars been remapped, would this cause any fault to do with this?
adzer is offline   Reply With Quote
Old 08-01-2010, 12:37   #2
adzer
adzer has 10 points
anyone???
Old 09-01-2010, 08:45   #3
adzer
adzer has 10 points
Old 09-01-2010, 14:40   #4
Pabs
PS3 tag: supra_pabs
Pabs's Avatar
Pabs has 10 points
try posting in the VAG-COM forum mate - might get a better answer in there
__________________
Platinum Grey MK4 Ibiza Cupra : Readers Ride
My Mk1 Leon How-to Guides: Clicky
Pabs is offline   Reply With Quote
Old 09-01-2010, 14:53   #5
RUM4MO
Senior Member
RUM4MO has 10 points
That car sounds to have a few problems, the silly little fan thing you mention does sound about like a turbo - to be honest, if you have bought a Cupra and you have not worked that out then maybe you should avoid reading codes and just changing things. It is true that a code reader is essential and maybe even helpful to someone that does not know too much about cars, but like any tool, its only as good as the knowledge of the person that is using it. BTW you did check the fault codes again after replacing the engine coolant sensor just to make sure that the same code was being logged?
RUM4MO is offline   Reply With Quote
Old 10-01-2010, 11:41   #6
adzer
adzer has 10 points
Quote:
your talking like i'm stupid and dont know what i'm talking about, i've owned 3 scooby's and have rebuilt engines for two of them. i'm simply going by what the garage said to me when i bought the car, anyway they have booked my car in on tuesday to get the repairs done under warrrenty so we'll see how they get on but i'm still not convinced that this fan that sits infront of the engine is causing this fault code.
fault code said temp sensor so i replaced it as they are common faults on these cars.
Old 10-01-2010, 11:49   #7
M1KEH
M1KE
M1KEH has 10 points
I bought a new genuine temp sensor that was broken, could be you got unlucky too.
M1KEH is offline   Reply With Quote
Old 10-01-2010, 12:34   #8
darkhorse
Senior Member
darkhorse has 10 points
Maybe if you could have another go at explaining we might be able to help more but from what you describe it does sound like the turbo intercooler pipe.
Does the temp gauge on the dash act normally? also what colour was the temp sensor you took out and what colour was it replaced with? Black ones are prone to failure and should be replaced with a green one. Check for corrosion on the connector as well
darkhorse is offline   Reply With Quote
Old 10-01-2010, 13:11   #9
a_waugh
I Love Petrol Stations
a_waugh's Avatar
a_waugh has 10 points
Ive got this fault code just now. Everything on the car works as normal though. Temp guage works and the car heats up.
Waiting on my temp sensor to get to my dealer. Should be there on Monday/Tuesday.
Hopefully this fixes the problem.
__________________
Andy
Subaru Impreza WRX Hatch
a_waugh is offline   Reply With Quote
Old 10-01-2010, 14:36   #10
RUM4MO
Senior Member
Whatever, writing posts like you did not know what was what is really your problem - most people here are trying to help and it sounded like you needed help. Try harder next time and you might get the help you need. I've heard plenty stories from people that actually "re-built engnes" - well they were around when that was happening - its the way of the world!
Next time maybe plug the new sensor in before fitting it, and see if the fault can be cleared.
Trouble is, now you need to keep your mouth shut when handing this car back in as the garage will not like you trying to tell them what you have already done while trying to get them to repair it under warranty, I've sorted out many new cars myself, but its only the parts people that end up lecturing me about invalidating the warranty after I hand over the VIN - I just tell them the usual, "a car only last X years or Y miles or Z vists to the workshop!" they don't mind that but the service do!
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 69
20VT Andy, adzer, a_waugh, BKR, Bowen, Breezapom, Cal91, capn.jack, CJRamze, claireeyy, D1x0n, darkhorse, davidif, davidmills2002, DEAN0, defected123, dg, DKershaw, Ferryman, flares, fozzybear, g60jonny, geoffjuggs, great_kahn, Hartosh1, jamborino, jamieruck, jatkinson_85, jeffery, joesmad4it, Jordan22, joshbro90, Keef83, kidinspace, krussel, laserman3000, leons_ leon, lil3520, M1KEH, markm, MartinDov, meltonlad, MichalR, MTIbiza, Neo, Pabs, rdcoops, red_october, repoman, Ricardo_Smooth, rich3001, RUM4MO, ScottHmk4, Scotty22, shaheer19, shazo, Slippery_Stu, smashingguy, thePHILosipher, thomasa, TJP, Veyron, villa4life, walkabout, whitz end, wolfie150, zapata, zzw30turbo
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
