Badger5
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Readers Rides
Readers Rides Show us your ongoing projects / work in progress / pride and joy.
Reply
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 23-01-2010, 19:15   #1
james.l
GT3071r LCR
james.l's Avatar
james.l has 30 points
James' LCR - 2008cc Stroker HTA GT3071r! - Tuned @ Badger5
As the car stands today, and a list of the parts installed / to be installed
Block
BAM Engine Block
92.8mm Forged Crank
1.8 Oil Pump Drive Gear
Mahle Motorsport Powerpak Pistons
Mahle Motorsport Piston Rings
Mahle Motorsport Wrist Pins
06a 1.8T Oil Squirters
DM Forged 144 x 20 Connecting Rods
ARP2000 Connecting Rod Bolts
Calico Coated Main Bearing Set
Calico Coated Rod Bearing Kit
ARP Main Bearing Stud Kit
OEM Head Bolts
HEPA Metal Impellor Water Pump
Gates Performance Timing Belt
9A Manual Tensioner
Contitech Serpentine Belt
Custom Made Oil Catch Can
Overbore Master Gasket Kit
New OEM Oil Pump
New OEM Oil Pump Chain
New OEM Oil Pump Tensioner
AKS Tuning Baffled Sump
Cylinder Head
ADR Large Port Cylinder Head - Ported & Polished
Cat Cams 3658 Billet Camshafts
Cat Cams Adjustable Cam Wheel
New Valve Guides
Ferrea F1556P 26.9mm Intake Valves (12)
Ferrea F1554P 29.9mm Exhaust Valves (8)
Ferrea S10055 Intake Valve Spring (12)
Ferrea S10056 Exhaust Valve Springs (8)
Ferrea SL1025 Intake Spring Seat Locator (12)
Ferrea SL1026 Exhaust Spring Seat Locator (8)
Ferrea E11031 Titanium Intake Retainer (12)
Ferrea E11032 Titanium Exhaust Retainer (8)
New Valve Stem Seals
New OEM Hydrualic Lifters
Turbo
HTA GT3071r Billet Wheel
Tial Vband Turbine Housing .82A/R
Tial 38mm MV-S External Wastegate
Manifolds
TSR Performance Tubular External Wastegate Manifold
SEM Motorsport Large Port Intake Manifold
Bosch 75mm DBW Throttle Body
INA Adaptor Plate
Fueling
Bosch EV14 750cc High Impedance Injectors
DA31 Fuel Pump
Exhaust
Custom Made Downpipe & Center Section by Badger5
Miltek Stainless Cat Back Exhaust System
Cooling
Forge Motorsport Big Race Intercooler
Intake
Custom Badger5 Billet Radius Stack (RS4 MAF)
6" K&N Filter
Chassis
Full KW V1 Inox Stainless Steel Coilovers
Full Superpro Bushes (Wishbones, Dogbone, Rear Axle, Steering Rack)
Vibra Technics Fast Road Engine Mounts
R32 23mm Front ARB
Drivetrain
Southbend Single Mass Flywheel
Southbend Stage 3 OFE Daily Clutch Kit
Southbend Stage 3 Pressure Plate
034 Machined Gearbox Linkage Bushes
Wavetrac 02M LSD
Brakes
Forge 6 Pot Calipers
Forge 356mm Floating Discs
Mapping
Badger5 Custom ECU Map
james.l is offline   Reply With Quote
Old 23-01-2010, 19:16   #2
chris285
leon mk1 fr tdi
chris285's Avatar
chris285 has 10 points
loking good mate
__________________
revo stage 1, custom cat back twin exhaust, fabia rear wiper, aero wipers and c2 aerial - more to come
chris285 is offline   Reply With Quote
Old 23-01-2010, 19:24   #3
oneofthetwins
Born Slippy
oneofthetwins's Avatar
oneofthetwins has 10 points
sexy
oneofthetwins is offline   Reply With Quote
Old 24-01-2010, 10:17   #4
JamJay
California Bound
JamJay's Avatar
JamJay has 20 points
I like alot
The 2nd pic looks quite quaint but i'd love a yard like that.
__________________
///M BMW Tw@ Owner
No fog lamps, brake cooling ducts. Because race car. Club 400.
JamJay is offline   Reply With Quote
Old 24-01-2010, 10:32   #5
cupra.al
Senior Member
cupra.al's Avatar
cupra.al has 20 points
as i said in the other thread looking good.
cupra.al is online now   Reply With Quote
Old 24-01-2010, 10:38   #6
cap r 225
the need for speed!
cap r 225's Avatar
cap r 225 has 10 points
Another tidy LCR, loverly.
__________________
Cappers LCR ownership http://www.seatcupra.net/forums/showthread.php?t=198623 NOW SOLD
cap r 225 is offline   Reply With Quote
Old 24-01-2010, 18:20   #7
christhomas
christhomas's Avatar
christhomas has 10 points
Looks tidy!
christhomas is offline   Reply With Quote
Old 24-01-2010, 19:00   #8
lockly
lockly's Avatar
lockly has 10 points
Looks nice mate.
lockly is offline   Reply With Quote
Old 24-01-2010, 19:57   #9
turbo009
Red Lightning
turbo009's Avatar
turbo009 has 10 points
Beautiful mate love that colour
__________________
Recaros,Milltek,007P,Jetex, stage1 custom RT map,261bhp@264lbft
turbo009 is offline   Reply With Quote
Old 24-01-2010, 20:56   #10
james.l
GT3071r LCR
james.l's Avatar
thanks all for the comments. Definatly found a nice one, spent months looking for a decent one
__________________
467 BHP / 390 LB/FT @ Badger5
Old 24-01-2010, 21:31   #11
stucupra r
stucupra r's Avatar
stucupra r has 10 points
by the way mate forgot to tell you its got auto windows module fitted. just hold down the unlock on the key fob
__________________
lcr gone
stucupra r is offline   Reply With Quote
Old 26-01-2010, 16:08   #12
james.l
GT3071r LCR
james.l's Avatar
Quote:
Originally Posted by JamJay View Post
I like alot
JamJay,
Been reading through a few posts that you have put through to AmD, i'm thinking of getting some coilovers fitted (Weitec Hicon) and wondered what you are getting fitted? Are you doing the front Arb as well?
Quote:
Funily enough i was playing around with vagcom the other day turning on a few bits and noticed that it had auto closure when i was testing the key fob. Cheers for letting me know though.
__________________
Old 26-01-2010, 16:11   #13
james.l
GT3071r LCR
james.l's Avatar
Had a quote from AmD for some Weitec Hicon Coilovers.
£567.35 Fitted - Thoughts anyone?
__________________
Old 26-01-2010, 16:20   #14
gazsutton
MISS MY LCR :-(
gazsutton has 10 points
love the colour of your alloys, goes well mate, id like a similar colour on my black lcr
gazsutton is offline   Reply With Quote
Old 26-01-2010, 16:22   #15
JamJay
California Bound
JamJay's Avatar
Quote:
Originally Posted by james.l View Post
JamJay,
I am still considering these but I used a brand on a old car called K-Sport which were very good at a great price. They normally specialise in Jap Cars but they do a kit for the LCR for a tad over £600 supplied which is 36-way damping adjustable also. They were fitted for 2yrs and I never had a problem at all, not rust either, I think they were stainless steel. APEX Performance are the UK Supplier. I am not sure about the front ARB, I think it's quite capable but needs an upper strut brace to compliment it more than anything.
I would fit them myself but the price from AMD seems fair.
__________________
///M BMW Tw@ Owner
Old 26-01-2010, 16:42   #16
james.l
GT3071r LCR
james.l's Avatar
Are you fairly mechanically minded? Also, your not far from me
__________________
Old 26-01-2010, 20:26   #17
JamJay
California Bound
JamJay's Avatar
My dad is mechanic so I learn from him, i'm not scared to get my hands dirty.
__________________
///M BMW Tw@ Owner
Old 26-01-2010, 20:31   #18
robk2009
robk2009 has 10 points
Hi mate nice car, are you the james who came to look at mine?
robk2009 is offline   Reply With Quote
Old 27-01-2010, 13:55   #19
james.l
GT3071r LCR
james.l's Avatar
Quote:
yup
__________________
Old 27-01-2010, 13:56   #20
james.l
GT3071r LCR
james.l's Avatar
Have you got access to lifts and such like then?
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 1377
*Buster*, -pseudonymous-, -SlicK, .Si., 1.8-20v-cupra, 1.9...stefan, 16v6n, 1975jcbg, 20vt_89, 221084clarkey, 285cupra-matty, 2footpegs, 4937Liam, 4wdibiza, 51mo, 5509433, 6th.replicant, 87DRN, 8bit, 932matthew, @lq!, aaron-gardner, aaronipswich, abbotsmike, abhardwaj1990, abs111, AC, Ac Performance, ackers1987, acky85, adam cupra 20vt, adam kelly, adam taylor, Adam's Cupra, adambudders, adamjb, AdamRoutley, AdamWrady93, Adman77, adulka, adzer, adzy91, ahto, Aimez, air121005, aj51 log, Al, al-jam01, al20v, alan-fr, AlanUK, Aldvrn, alex 80, Alex1337, alex8v, AlexGSi2000, alexj124, alias, Alixsixxx, AllanCupra, Allan_84, Altech, Alzak, Amcm, Amir_dan, Ammar786, ammo, Andi, Andi_cupra, Andrew J, Andrew1, andrew186, Andy McCombe, andy.morgan, Andy360, AndyCupraR, Andyemm, andyl89, andymac123, AndymFR550, andypandypoos, andypower, andytaylor1980, anoyceperson, anthony37, antony-lcr, Ape, Applemobile, AP_V5, ardiano, armyboi01, Arnie-Wilson, ArosaRacer, artemis_1991, Ash.LCR, ashercupraR, Ashley1Richards, Ashley32, ashw831, Ashy172, aslz78, ath55, ather`s, Atteman, auq, ayacoub92, az20vt, B47t0n, badboybunty, BaezoN, bainsycupra, Bakes100, ballyg, bananaman044, barmby, barnsley, basemanuk, Bashiee, beastgtir, BeatoX, beattie17, Becks, BEEZABOI10, ben-chelt, Ben-ibizaFR, Ben-L-CupraR, ben-sullivan, ben450, Ben:, ben@amdessex, bendohhh, bengie_cupra, benjaminjosh, Benjic2, benk2011, Benl172, benny12357, benoit62, benrace91, benrobbo, BEOWULF, Bera, Berg, bertandernie, beta85, betts, BHP Addict, Biano44, big eck, big rich, BIG4244, bigben143, Biglou, Bignod00, bigry, bigtb, Big_Lad, Bikerz, bilas1986, bipbop, birchy2010, bishy, bisto48, bkingb, Black Cupra4, BlackDeath, BlackLeon, Blackpearl__, BMH 25, BobbyCupra-R, BocanegraTom, bogdan_wrc, Bogwoppit, Bomber, boomsly, boosted bandit, BoostHard, boost_addict, boqer123, botanical_monk, Br!dges, brad1, brad1002, brader225, Braders, Bret, brett1223, brett123, Bricey, bruceR, brummel, brwmogazos, buch bdm 400, BumbleJC, Burnz, button_17, buyobd2, c-n-d21, C17 OFF, c170784, c2rlv, Cainey, callum_, calvR, Cal_mk5cupra, CamPark, caney, Canners89, cap r 225, car.crash, cass, cawsey18, cazzac2222, ceb, CGD217, chalin, Chambers_CUPRA, CharlieRCupes, charlie_j17, chazneybcupra r, Chez, chicca1987, Chino_UK, chopra, Chowchow, chris c, Chris OB, Chris rickard, Chris-cupra R, Chris0491, chris1682, chris1788, chris205, chris285, Chris4877, chrisby, chriscupra02, ChrisCurzon, ChrisLindsay, chrisp10001, chrissgoduk, Chrissy20vt, christhomas, Chriswaite130, chris_ffx, chutz1, Ciosmi, CJcupra, CJRamze, clarkson1, claytond, cloke, ClOuDy187, CluneZ, CMAC30, cmd, coleman, con, contiman, cookieboy, cooky25, coops10, Copey, copey_cupra_R, cozzy1990, craigp87, CraigSmith, craigstirz, craigturbo, craigy86, Craig_swansea, Crashapollo, crazybrumi, crezz, Crhome, Crize, CrossyR, csd_19, ctg13, cuky, Cupra Grant, Cupra gt, Cupra R, Cupra r 225bhp, Cupra R101, Cupra Tommy, cupra-barn, cupra.al, cupra123, cupra6l, cuprabaz, CUPRACAR, cuprachad, cupradan, CupraElliott, cuprageoff, cuprahype, cuprakatie, cuprakemp, CupraLew89, cupramillo, CupraMuscle, Cuprapaul91, cuprapowerpaul, CupraR-S6, CupraR1, CupraR210,DJM, cuprar54, cupraras, CupraRmark, CupraR_Lad, cupraslayer, Cuprastephen, cuprastic, cuprastoffs, cupratdi-matt, CupraTE, Cupratje, CupraTrack, Cupra_Jay, Cupra_Mat, cupra_mike09, cupra_mul, Cupra_R04, Cupra_Red, cupra_r_04, cupra_r_ick, Cupra_Wayne, cus, czaki, C_kst, c_larkey, D.K, D3DNA, d4ns, dai_watkins89, dalegolf215, Damoegan, Damon_, dan.h, Dan1720v, dan1990, Dan29, dangerdave, Dangerous Dave, Daniel 1.8t, Dani_b19, dann, danny m, dannyboi321, DannyC87, Dannyh, Dannym, Danny_FR, DaNnY_LaD, Danturbo225, Danzibar9, DaReK, darkhorse, dav3, DaveD, DaveGT84, Davey_p, Dave_, dave_ph, David.vtR, davidDS, davidg60, davidif, David_smith_909, davyp, daytona246, daz20vt, daz463, Daz8161, Dazz 1989, daz_pd, dday, DdraigR, deanodaf, deansutherland, Dean_dubber, Dean_leon2525, Dec91, dedon, deek_cupra, Degsy1, delMAR, DeLoN, denzil691, derelyth, deutsch, Devon, dgjdrummer, dh00001, dieselpower, dino33, Dione J, dizzyandscoop, DJ-LIAMC, djkobra, DMackie, dme2011, Dmoe, DM_Cupra, Dniel, Doctor Gonzo, Dodgercannon, Dodson, dogy_, DOLBY, domin8or, dom_f, Donny9835, Donnyboy, Doogle, dooresy, dreago 1, Drizzle, drka-drka, DrunkenDubber, dsj20v, Dude, dugonve, dustyivan86, dylantuk, Dyvern, e30matt, earache, EB-80, Ed87, eddsuperted, edewer, Edgarasv, ed_barnes, eindringling, ejr, EL, eldiablo, elliottcharles, elroberl, EmDee, Energy52, envy_vwm, eric_bocanegra, Estrioltdi, ethtechno, ets2k9, evo2345, Exe_LeonCR, ezza24, F2 Ed, fabregas4, Fahid82, Faisal, faz1979, feast130, Feel, Fergal84, ferooo, ferrett, Ferryman, fezza, filbro, FINCH, firestorm, fletch2k00, FlexLeon, fliksm, FLK, Floodie, fokusicar, ForgeMotorsport, fourtwofive, Fox god, foxes, foxleyl, Fozzy 89, Fozzy84, fplord, frankmabo, Fraser_Fr170, Fredlcr, frenchman, frfred2009, FR_MATT, Funk, fuzzy232, fyfe9, G2HSE, gac, gamer555, gammon11, Gar3th, Gareth 265 R, gareth watson, Gareth_1.8T, gatman, gav525, gave^, gavmc123, Gav_Kara, gaz700, gazcuprablk, gazR, gazsutton, gb, gdjohny, gebowser, GeeDubble, George 3G, George657, george_seamons, Gertie, gezmeister, Gibbo201, Ginge81990, ginger3131, ginnerste, GJF47, gjgtdi, gk002, goach, googujube, goonerjs, Gooner_Mike, Gordz, GrahamFR, grahams81, grant 123, Gravesie-363, GRD, greck999, Greenjag, greesha, greganderson, Greggio, GregLCR04, gregy_reynolds, Grimsby99, GT Bee, GTi T, gti_jones, GTTIM, gt_pt, Guinness, Gulfstream, Gw19, h0tr0x, h7 cya, hammertime, HarleyMK, Harpal, Hartosh1, harty190486, HeatSnatcher, Heidi, hellowed, hixonseatboy, Hobbiniho, Holdup, HOLLANDMSGH, hooky, Hpswitch, hudzyyy, Hughesy, Hullcupra225, hypah, Iain101, iamseanyboy, ian_jobson, ibiza20vt, IbizaAlex, IbizaC, ibizacupra, ibiza_1.4tdi, ibizouba, iFR, IH786, ikhlaq206, illusion, ILLUXN, iMatchu, INA, interceptor.med, Invincible, irmscher2007, iSamKing, itfben, iTzbRu, ivo098, j.barnett, j0rd4n, j14cdt, J44APX, J@mes, jaba101, Jack1991, Jackd93, jackoni, jaf2212, jake, jake-1991, Jake9119, jakeyw, jam666999, jamandspoon81, Jambo82, James D1, James R., James.Judd.1, james.l, James23Parkin, james91, jameslcr, jamesypyk, jamesy_m, james_cupra, James_LCR, jamfull, Jamie225, Jamie7, jamie8954, jamiea69, jamiebennett81, jamielee, JamJay, jammio, jammydodgerJW, jamoy, Jarre, jasc1988, jasecx, jasont87, JayCee, JayFR150, jaymd, JayParekh, Jayz, JCLcupra, JCR280, JDUB 20V, jebus, jenk, jeroen3131, jeroencupraR, Jfox, jgy6000, Jimbobcook, Jimbo_, jimbo_h, Jimmeh, JimmyCupra, jinidos, JJS, jk-cupra, jlennie, Jm05cop, jmcuprar, Jmerrie, JMP, Joeboy1994, JoeBrooke, JoeCav, joehirth, Joel_Lucketti, joenitro, joestella28, joe_b_gti, joe_c, jof1.8t, John Lindsay, JOHN MAC, johnno1, johnny200486, john_tdi, Jokerman261, jon23, jonathangosbee, jonathanp, jonjay, Jonny95 SXE, jonnyattwood, JonnyH10, jonofthemalley, joostdeblok, JordanMk3, Jordanwaterhous, JoshDoubleYou, joshy514, joy87, JP6, JPower, jrallye, jt20vt, JU5 2 SLY, Judgejim21, Just Waxed, JW.CupraT, K1Ringsell, K1_Chris, k1_tom, kaktuz, Kalel, KarlB1, karlw, kaspa_dtz, kazand, kazinak, KD, KDV, Keano, Keithslippery, Kevgrady, kevinking2020, kidm170, kil2002, killieboy123, kilner, kilobrown, kiminauta3000, kinder, kingy89, Kirill85, Kirky.aj, Klone, km193, knight, knightycuprar, kopec56, kovzharov, kris86, Kurtice, kyle_d, L.R.C., L16JAY, L5NTN, L9 GOW, Laggo, lajohnz, Lambro6, lamby, lankman, lappycupra, Laser, lawrie1987, laz1, LCR 225, LCRMartin, lcrnegro, LCRnorwich, LC_15, le0ntdi, Lee Edgecombe, lee3011, LEE69, leecupra240, leegriffiths, leejay, leesmith, lee_fr200, Legohead, Leigh200sx, leon cupra r, Leon.cupra, Leon1600s, leonbeastmk1, LeonCR, leoncuprar2010, Leoncuprarfan, LeonFRNik, leonfrtdi150, LeonQH, leonrob09, leon_lee, LetsOwnesty, Lewisep, LewisSeat1.6, lexyy, lh89, lindleyp, living2xs, LJA, llebrevilo, lloydie, lm_gauci, lockly, lofer, LongDave, Luke 1, luke1991132, luke2702, Lukeyx, Lukeyy, luke_cafc4, Lwood_seat476st, M1KEH, M20FES, mac64, maca_cupra, MacDonald, Mackin92, Madmile, madmonk, magnumsport, MaguireJ7, maikblackcupra, majesty78, Makaveli8, MalcB, Mancseat, Mandip, ManOnTheMoor, Mantas, mao76, marcb, marco cupra, marcus.l, Mark D, Mark One, Mark300zx, markbrum, Markc1224, markojay, MarkWales, marky t, Mart, marv_n69, Mashburn, matek55, mathewh09, Matt-18, Matt-V5-Duffy, matt88 lcr, Mattgrace, matthab, Matthewd91, MattJAbela, Mattwood, matty-c, matty85, mattylol, matty_glanza, Matty_Hart, matt_s, matylad, Max pt, MaXx, mayfair86, mc funbot, mcd90, McManus, McMillan, mcsolle, mdmay, MexxT, MI 55UTH, Mick288, mick710, Mickylad, mickytf, Mikas, Mike R, mike.1981, mike.ford84, Mikey P, Mikey-D, MikeyTomo, Mike_P, milburnj, Miller 20vt, Millsy_Cupra, milner575, Mindslicer_, Minimorri, minty23, MisterE, mjones, mk1kid, mk4 cupra, mk4dub, Mk?craig, Mo Arif, MOE16V, moff, moggytom, Mojofrojoe, Mojo_SA, monkeyboy999, Mooks, moominian, morini, morrischad, mosso, MostWanted, mouse1989, MPJ88, Mr Footlong, Mr OCD, Mr. X, mr.chris, mrbdrm, MrBen2k7, mrgasoil, MrWill, mrwookie, mr_bod, Mr_Dave, mty12345, Muffew, Mukkyman, munch8987, Murdered LCR, Muzza1742, MWG, mwillis551, Mylo2912, myslilyyli, n11tht, n1ff, n20mrp, N3 CPRA, NAB_ARCK_86, Nads123, nash0604, nath-g, Nath., nath.lcr, nath86, nathanbuckrr, NathWraith, nato, ndbrgr, Nef, neil, Neil82, neox, neron4o, nev, Nganasan, NiallCupra, Nick Bosch, Nick.k, NickLCR, Nicko_12345, nightflight, Ninja_Jim, nismo1, nite, nitroverf, NLmaverick, noodle, Northerner, ntcupra, Obsidon, ochoaaar, Oli-k1-jenkins, oli_c, omra, One T, oneofthetwins, orson carts, ozaudio, p-hoey, p-twirler, P.LeonCR, P10 GGOT, P1TT8ULL, p34ch3y, Palmer, palmer84, pampi, partom02, Paul D, paul-murphys, paul6316, paultownsend, Paul_fr, PD, Pedestrian, Pedrooo, pedrosousa, perikolos, pete34a, peterg60, petey085, Phaardrive, phantom1, Phat Busted, phat purple one, phil 9289, Phillc, PhilW, Phil_JJ, PID, pietwillem, Pingu101, pinotattt, PiperRS, Pixis5, platinumatt, PLuKE, poison605, poliq, POLMAN, Pommeh, pontifex, Poochy, Popadopalous, porksword28, posterboy, Poverty, prawn, Prebs, prezf, PriceyFR, pricey_2k10, probee, Probot-matt, Prof.H, proximo, przemekPL, psycho6285, Purespeed, putridmocha, pwleicester, r.i.c., R333DDX, R4cup, r6_allan, rabcupra, RACEBITS, rae1001, RafLad, rainbird, rallycupra, Random1989, Raptor6702, RayRoocroft, RazzleUltra, RDS, Readie46, reapermatt, ReDBull, RedCupra160, redcupraboy, Redrat, reggy_fr, revo20vtdan, RevoMark, Reyes, Rgm racer, Ric 2001, Ricardo, rich225cupra, Rich66, Richy Cupra, Richy!!!, richybigman, Rick1.8t, rickcuprar, rik_t, Rivva, Riyuko, Rob Kelz, rob321, robbob, robboz, RobDon, robertj, robk2009, robthebubble, rob_humphrey, Rocky Rocastle, RoDiK, rogerw86, roly, Ronin225, Roohul, Rory-C, Rory1984, Rorza, RossB, rosshutchie, rs-tuner, RS6, rsmith, rsrich, rudolf2, Russ3474, russ85, Russler, Russo, RyanMK4, RYAN_101, S's Cupra, S10EAT, s1mon, s24-k1, s3_cyp, S800BRN, SalterTDI, Sam89, sambryant, samcash88, samj2011, samu23, sas 99, Sashky, Sast, Saviorz, Scattle, Scosh, Scott-o, scott5, scottl5690, Scotty-cupra, scotty1310, scotty18, Scotty229, scotty86d, scotty_f, scott_159, seabrook, Seal_LCR, sean ox, seanconnolly, SeanH., Seanyt, seatcupramad23, seatmannen, SeatR, seatturbopower, Segger, shakey_hand_man, shakzTDI, sheperd, Shiki, Shmoo, sidhuboy, Sile-R, Silver Leon, simon128927, singh123, skiddusmarkus, skippa, SLeon, SlimLCR, slydog18, smallwood90, Smee, smithy88, smokeyjoe, Smoki333, smokiefr, sm_cupra, sniperftw, snk, soche, sollerboy, Songman, sovk1n6, Sparkk, speedinsaxo, spen, speters2001, SpidaCZ, spiff, Spirit Furtive, SPLeon, splinter_cdo, Squar, srai, staceys3, steady_eddy, StealthInspired, stephend, stephenl2nst, steve8582, stevebuzz, SteveHollis, stevekkk1, stevelcr, stewbie55, Stewfo, ste_brough, STOCKY, STOKOE, stonechip1, Stonesie, stubee, stucupra r, Stuiemc, stupot_1982, styling, SubZero, Suddy, suj, sunscott, superkarl, supermoto, super_electric, suzsv650, swedey21, swoosh225, Sxanth, Sy, t.oldaker, t0m, T18_MPA, tak1986, Talx, tarzan, tashacupra, TatoTDI, Taxi350, TazLCR, TDCupra, tdi_chris1, techie, tedvagas, tetsujin, Tfsi_Mike, The crow, The Don, thebacon, thekid, thePHILosipher, thunderous111, Tiburon, Tigertim001, TILLEY, Tilley1, tim144, tiny-tinkerbell, TJenkos, TJP, tj_the_great, Tobs, tom t, Tom., Tom.S, Tom0StarC, tom72k, tomcats, Tomer 20VT, tomh18, Tomjames69, Tomkins23, Tommyibizacupra, tomwolves, tonipieleanu, tony323ci, tonycane, tony_burrin, toocoolpash, torquesteer, Tournataka, Tr1ck, Transtellar, traumapat, trav13, trev_tang, trickycupra, TrisLC, truCido, TSVB, TTRR, tuan21, TubbyTwo, tufftybloke, turbo009, turbo87, turboboy, turboboy111, turboholic, turbomick, TVR, tyrer, UK225, ukreddevil, ultimateauto, Umar, UncleFester, underpressure, urii_sc, usp, V5 VAG, Valhalla, van cleef, Van Man, Vasily87, Vaughny, vaux_gled, vernsaudis3, Vipers_Venom, virdi, volts, vr6, vroomtshh, VRSLOZ, VT86, vts16v, vw-aj, vwdom, vwtrellis, Vw_g60, W11TTX, W33YUL, wade.k10, wadey91, wakko, wanna_cupra, Wash It!, wayne lcr, wayne235, wazza5, wazzzer, weerobocupra, welly, wenman, wesson12, westallc, wes_keo, weve33, wezy0, wezza12, Whitechapel, WHLF, WHOZBOSS, wigz45, wild willy, WileEcoyote, Wilko, wilky19, Willem, Willow86, WILSY, wilz, window60, wmffra, Wolf_gsxr, Wolven, Wolvo-Oleg, Wolvotim, woody cupra, Woody'sCooper, woodyzs, woody_, worzel, Wraithlcr, wrighty89, X cupra, x24sevenbikerx, x637ufs, Xanthianx, xavier de, xDaNx, XH558, xreyuk, xX usher Xx, x_jago_x, Yatesey8527, yaue10, yellonvi-R, YellowLCR, yessar_kd, YIN, Yohan87, York, younger25, youngyWHU, zan, Zox, _chris_
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Basic Sub & Amp for LCR Boot install rllmuk Modifications and Tuning 4 22-02-2010 08:36
First few days with my LCR 210 jcborden Leon Mk1 3 12-07-2009 01:04
FR DSG - First Impressions post LCR. rllmuk Leon Mk2 1 16-03-2008 05:46
LCR or FR+ ?? Ellisium Leon Mk1 8 27-02-2008 09:28
Calling LCR owners (wishbone question) HTC Leon Mk1 0 15-11-2007 23:25
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
