| Ibiza Mk4 For the 2002 - 2008 model |
Thread Tools | Rate Thread | Display Modes |
#1 |
Newbie
loud creaking noise
Hi guys, my 2005 1.2 ibiza is making a loud creaking noise whenever i change gear, go on or come off the accelerator, or drive on bumpy roads. Sounds as though its the suspension but the noise only happens when the cars moving. If the engine's off the car doesn't make this noise when i bounce the car. Gear changes also feel quite rough/jerky.
Took the car to the garage and was told the bushes needed replaced, had them replaced but the problem continues, really starting to get annoying! Anyone got any idea what the problem might be? Cheers |
#2 |
Eat soot!
Did they replace the front wishbone/tca voided bushes?
Had mine done recently after living with the exact same symptoms you describe and it cured it. |
#3 |
SWING LOW SWEET CHARIOT
broken engine mount?
with the engine switched off pop the bonnet up and try to rock the engine back and forth, if it makes the noise then it's probably a mount gone. with the engine running pop the bonnet up and get a friend to rev the engine from tickover to say 3k revs, if the engine moves back and forth a little it's ok but any more than say 1 to 1.5 inches of movement is bad. The noise may happen when revving it, if it does then it points to worn/broken engine mounts.
__________________
BIFIDUS TURBINEUS BOOSTARIUM
#4 |
Newbie
yeah had the wishbone bushes replaced, made a difference for about a day and then just got progressively worse again.
Tried the engine mount test earlier tonight, seems to be secure so I think I can at least rule that out |
#5 |
Proud Seat Owner
If it is the bushes what happens if you dont replace them?
__________________
Chris Ramsey - CJRamze 2007 Cupra, Aero Kit, Custom Exhaust System, Custom Induction System Now For Sale !! |
#6 |
Your front tyres wear down the the metal bands on the inside edges and leave the outside edges looking fine, this can happen in just 5 or 6k miles.
Also you will be deaf from all the noises and need to learn sign language.
__________________
#7 |
Proud Seat Owner
Ah ballacks.
This cars only done 24,000 and its 3 years old! Why me! Why now!
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 28
| Aimez, ant49, a_waugh, badbill_uk, bald_eagle, Cal91, CJRamze, Crafoo, DKershaw, flat499, gex18, gh1985, joshbro90, luke c, markm, mick-fr, Nath., Neo, pedro-tdi, pete_266, RaggedLob, roysterfr, Scotty2hotty, sharpy-22, tollydan, tsmithy, twin2189, zoheb |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine noise problem solved!! - Seat Bulletin available | toNes | Leon Mk2 | 77 | 19-07-2010 00:07 |
| 1999 AFN 1.9 TDI engine LOUD ticking | johnbuz | TDi - SEAT Diesel specific topics | 15 | 25-09-2009 07:38 |
| Passenger SEAT - loud creaking?? | MrWill | Ibiza Mk3 | 0 | 24-09-2009 23:42 |
| Odd creaking noise | PaulieB | Ibiza Mk4 | 16 | 26-03-2008 18:11 |
| Loud Ticking noise | Rosco906 | Ibiza Mk4 | 23 | 15-05-2007 17:53 |
