AMD Technik
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 10-02-2010, 20:34   #1
denispearl
Flywheel and clutch on ebay for £179. Shell I go for it?
Thats what Ive found on ebay :
''Audi A3 TT Seat Cardoba Ibiza Leon Toledo Octavia VW Bora Golf Beetle Passat Polo Vento 1.4 TDi, 1.8 T, 1.8 GTi, 1.9 TDi, 96- Flywheel, Clutch, Bearing
# New OE Solid Flywheel, Clutch Kit (plate & cover), Bearing
# This is a SOLID flywheel conversion for a Dual Mass Flywheel car
# No more Dual Mass Flywheel problems
# OE specification 4 piece unit
# Brand New
# 12 month Guarantee
# Price inluding VAT ''
Im quite confused with ''This is a SOLID flywheel conversion for a Dual Mass Flywheel car''
Would it fit ibiza 1.9tdi sport 2003???
Should I trust the quality? Is that a bargain???
denispearl is offline   Reply With Quote
Old 10-02-2010, 20:41   #2
DEAN0
# Brand New
Should I trust the quality or that is bargain???
Not sure if it will fit your car but the CONVERSION kit is quite common from dual mass to solid flywheel.
You would probably have to swap the starter toothed ring across between the flywheels.
Mabe someone with EKTA can tell you if the flywheel on yours is the same as the ones listed
DEAN0 is offline   Reply With Quote
Old 10-02-2010, 20:43   #3
denispearl
EKTA???
Its says that if fits ibizas tho...
Hmmm
Old 10-02-2010, 20:46   #4
DEAN0
EKTA???
electronic VW parts catalogue - alows you to see which parts are common between models.
As the seller if it will fit your car - keep the written reply - it it don't fit you can use the reply for a refund
Old 10-02-2010, 20:49   #5
denispearl
Ok. JUst contacted the seller thanks
Old 10-02-2010, 22:43   #6
stebbi
Got Boost???
stebbi's Avatar
Seriously check out how bad the smf sounds on the 1.9tdi.
I could do with one because of the torque im putting out but im just going to get a new dmf so that it sounds quiet when driving. smf sould aweful.
is there any other reason your looking for a new clutch?
remapped?
if your not putting down a silly amount of torque perhaps a clutch from CG Motorsport is a good idea?
seem a more reputable place rather than an ebay seller. considering that its a big job replacing the clutch 4hours labour as its a box out job
__________________
Hi-Spec Monster4's . Hybrid Turbo . Forge FMIC . Sach Paddle Clutch . Eibach Pro-street . 5k HID's . Milltek Turbo-back . BBS . Rear Cage . Rainbow Audio . Yellow . 239.7bhp
stebbi is offline   Reply With Quote
Old 10-02-2010, 22:52   #7
denispearl
remapped?
i might have to replace flywheel cos my car shaking sometimes like an old man, so ibe been told is a bad flywheel. Funny tho, one mechanic said that i can drive with it forever, another - that i less than 5000 miles left on it. So i do no. It shakes sometimes only. Any ideas?
Also is that a really bad sound? Cos buying of ebay i got to pay 270 pounds with labor, but from anywhere else is more the 400......
Old 10-02-2010, 23:01   #8
stebbi
Got Boost???
stebbi's Avatar
i'd recommend against the smf, it might be more expensive but with the smf on a tdi it sounds like its trying to scrape its way out of the bell housing, not nice if you want to be driving every day. on a petrol its not half as bad.
just had a look on eurocarparts and your looking at about 350 for a sash (oem spec) clutch and flywheel kit. not bad when the flywheel its self is 250.
i think it comes back to the 'buy cheap..buy twice' i wouldnt trust anyone apart from a well known company when fitting is around 200 just incase it all goes tits up
__________________
Old 10-02-2010, 23:02   #9
denispearl
remapped?
Old 10-02-2010, 23:08   #10
denispearl
i agree. But do i have to change it now? And where from can i get these parts cheaper with a good quality? Thanks
Old 10-02-2010, 23:09   #11
knackerdecobre
It only makes a noticeable noise on tick over in neutral, just dip the clutch and your fine
knackerdecobre is offline   Reply With Quote
Old 10-02-2010, 23:12   #12
denispearl
Quote:
so is not that bad, is it? I dono wether ill change it or not, cos if ill buy the cost of the car will be higher that the price of sale. So thinkig to sell that how much u recon could cost 2003 1.9 tdi sport with 91000 on clock? So far ive spent on it 2900 pounds.
Old 10-02-2010, 23:16   #13
stebbi
Got Boost???
stebbi's Avatar
but as soon as someone jumps in they will know the fly needs sorting so could probs bargin like 400 off the price.
google it and you'll find a vid.
__________________
Old 10-02-2010, 23:20   #14
stebbi
Got Boost???
stebbi's Avatar
http://www.youtube.com/watch?v=Vb9Z6O_Czow
there you go.
when it goes quiet thats when he's dipping the clutch.
I couldnt hack my car sounding like that
__________________
Old 10-02-2010, 23:25   #15
denispearl
there you go.
jesus. Horrible. Have to sell it anyway
need a new ibiza:.)
Old 10-02-2010, 23:40   #16
denispearl
there you go.
need a new ibiza:.)
Old 11-02-2010, 14:54   #17
krussel
krussel's Avatar
there you go.
God thats a bloody awful sound
I was hoping to go SMF when the time comes to cure my shuddering but NO WAY if it has to sound like that
krussel is offline   Reply With Quote
Old 11-02-2010, 15:02   #18
knackerdecobre
That video sounds loads worse than they actually are. Remember it only makes that noise when sat on tickover, how often do you have your car sat on tickover without you in it?
Old 11-02-2010, 16:11   #19
krussel
krussel's Avatar
Even so mine sounds like a tractor at the best of times i really dont want to make the diesel clatter sound any louder
Another year and a bit of warrentee and i am going to mod my electric throttle pedal to increase the tickover
Old 12-02-2010, 10:12   #20
denispearl
cannot open the boot from central key, only manually. What do to? Also p/s door lock
hmm
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 105
.Phase, 01samuelr, aaronbromley, adam kelly, adaytorememb3r, Aimez, alex88, AndrewJB, andypandypoos, Ant FR, ant49, Arnoldo, a_waugh, beezanick, berniejnr, Bikerz, borderboy, Brem, Browny_37, Brummy, buzbi, cairns81, carljason, CGD217, Chriswaite130, CJRamze, Craigbarnley, Crashapollo, CrossyR, dangriff, Dan_225, davescupratdi, davidmills2002, Davidsr, daz5476, DEAN0, denispearl, dg, DKershaw, dmcar02, Dom1988, Domino, DPJ, DScape, Fl@pper, flegz16, george130, Gillen, Gooner_Mike, Hartosh1, ivorbign, James FR, jasont87, jeffery, jgy6000, joebailie, John-Cupra_TDI, Jonny95 SXE, Keano, keithr, Kie183, knackerdecobre, knight85, krisbutler02, krussel, Leon_MHX, luke c, luna fr, markm, MATT RILEY, Mossberg, MrNorma, mumblist, Neo, nikstar, nvidia, onesh0t, Palmer, pd130, pete_266, PH1L NI, philharris68, PLuKE, Poochy, prezf, R1ch85, Ric 2001, ROBD--M15RPD, rod the sod, rossco22, roysterfr, rsmith, scoobsta1990, Slippery_Stu, st10587, stebbi, stephenh, tarzan, TheCraig, theycallmepaul, thomasa, welsh frtdi, Young_Derv, zach225, zoheb
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sachs Performance Clutch Group Buy JBS Sales JBS Autodesigns 27 19-08-2010 01:22
Ultimate Clutch Guide stebbi TDi - SEAT Diesel specific topics 6 02-02-2010 18:42
sachs clutch + flywheel, Are these prices right? Mully TDi - SEAT Diesel specific topics 6 10-09-2009 08:00
Clutch & Flywheel Soundwave AmD Essex 2 20-02-2008 17:01
How hard is it to fit a clutch and flywheel? Chrisdaman Ibiza Mk2 4 03-10-2007 21:05
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
