Badger5
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 11-02-2010, 09:45   #1
65coupe
I'm too old for this!
65coupe's Avatar
65coupe has 20 points
rear door glass removal - Leon Mk1
Anyone know how the door glass attaches to the window carrier in a Mk1 Leon Cupra??
(It's not a screw into the carrier because I can see it - it looks like some kind of plastic push in/push out lug, but knowing how expensive these things generally are, I don't want to force it)
Someone must have done this...
__________________
65coupe is offline   Reply With Quote
Old 11-02-2010, 12:56   #2
65coupe
65coupe's Avatar
Does nobody know?
__________________
Old 11-02-2010, 14:24   #3
Muttley
Catch that diesel!
Muttley's Avatar
Muttley has far too many pointsMuttley has far too many pointsMuttley has far too many points
Never done this, and I have a Toledo in any case. The guides I've seen suggest it is a single expanding plug with a push-fit pin to expand it. Removal seems to be by pushing first the pin and then the plug out of the hole in the window glass. Seat have a special tool to do this, which may also hold the regulator in place, it isn't clear. On removal the bits you've pushed out have to be retrieved from the inside of the door.
It suggests putting the expanding plug in the glass first on reassembly, then locating the plug in the riser guide and sliding the glass down until the plug fits in the riser. Then put in the pin to expand it all. Not a lot of detail.
Muttley is offline   Reply With Quote
Old 11-02-2010, 16:01   #4
65coupe
65coupe's Avatar
Thanks Muttley - that makes sense from what I'm looking at. Hope I don't break it!!
__________________
Old 11-02-2010, 19:48   #5
Muttley
Catch that diesel!
Muttley's Avatar
There is a warning about making sure the internal pin (looks as though it's a spring pin, to put an expanding spring force on the plug) is driven out squarely to avoid breaking the glass. Without the cool special tool, my guess would be that you need to make sure that you apply pressure to the internal pin only, and as squarely as possible.
Oh, and it says to be careful not to put a dent in the door skin as you drive the pin right out!
God only knows how you put the spring pin back in, though. Somehow you've got to stop the expanding plug from being pushed out of the glass. Maybe you can lodge it off-center in the access hole, so that it is held in from the far side, while still giving enough clearance to get the spring pin in??? Best of luck
Old 11-02-2010, 22:51   #6
65coupe
65coupe's Avatar
well I managed to pop the inner pin out (without hitting the door skin!!) but I can't get the outer one out. Too bluddy cold today anyway!
__________________
Old 11-02-2010, 23:33   #7
techie
Skoda Techie
techie has 20 points
Just remember when refitting you assemble both parts of the pin into the window and just push it down, it locks into place itself.
techie is offline   Reply With Quote
Old 11-02-2010, 23:35   #8
Muttley
Catch that diesel!
Muttley's Avatar
Thanks, techie, the bits I've read are not at all clear. I guess you've done this? I certainly haven't . . .
Old 12-02-2010, 01:42   #9
Al_G
Al_G's Avatar
Al_G has 10 points
I've replaced my rear window...
You dont need a special tool all you need to do is line the glass up with the carrier insert the outer plug then bend your hand behind the glass and insert the inner plug from the outside in (if that makes sense). Obviously to do this you'll need to open up the inner door skin enough to be able to reach inside behind the glass...
Al_G is offline   Reply With Quote
Old 12-02-2010, 08:19   #10
techie
Skoda Techie
You mean when your putting it in? Nah its much easier than that, with the glass out just assemble the pin both parts complete then just slide the glass in and push down and it clips into place.
Yes i've done many of them over the years, its really simple when you know how, once you have done it no problems.
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 95
3gte, 65coupe, 8bit, alecgr, Al_G, Art0ir, az101, B1ADE5, Ballie, bangerstox10, Bigjohn84, bmwww, carlossus, CGD217, clutchitupson, Colin1, Conzo_f, coupe8891, cra19n, Cunners, Cupra TDI 150, cupra_r_ick, DannyC87, ddavies, dday, deansutherland, DJH70, DrewCole, DTM2014, dunali, Eggs, FINN, Fraz, frijj, Gabster, gary_cupra, ginger_jack, Grant1985, Grayboy, Greavesy, greesha, GS16LRHP, Hamzilla, Jack92, jaf2212, jamber, Jamie27, jasont87, Jimmy3rown, kenny-cupra, Kris@SnM, lc_allan, LEE69, libiza2007, lm_92, M20FES, madog, matty85, mike whiskey, Mikey_Bling, milner575, mjt, Mo Arif, MooRzy, mosso, MrBen2k7, Muttley, nath86, Omagh.NI, Pete-r, R88CKS, rallynut, recon99, regallee, robo2731, rogerw86, runsinit, seantdi, Sg76, SLeon, smokeyjoe, spudboy6, Stefot, Suchley, supa_sam, Tangerine_Dream, techie, TerryCupra, Trev, widlajz, will4060, Williamleon, Wolven, Xizor, yessar_kd
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Leon Mk1 20v Turbo Owner rapid Leon Mk1 16 27-08-2009 00:09
Common problems with 1.6 MK1 Leon? WHL_Spurs Leon Mk1 2 09-12-2008 23:33
mk2 parts in mk1 leon Faisal Leon Mk1 4 26-11-2008 19:12
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
