| Ibiza Mk3 For 2000-2002 Specific Information. |
Thread Tools | Rate Thread | Display Modes |
#1 |
<insert something witty>
Boost Issue..... Possible Limp Mode?
Dunno if it's related to this thread
http://www.seatcupra.net/forums/showthread.php?t=254833 Shouldn't be as it's still been booting ok.... I'm sure even last night it was boosting normal. Can't say for sure as I was on a date and being sensible ![]() Anyway, after dropping her off, I was driving home and went to overtake someone and noticed it wasn't pulling as much.... So I kept "testing" the boost..... Now if I was high in rev range, the boost would shoot to 15psi, as soon as it it 15psi, it dropped straight to 9psi.... If I was lower down in the rev range (so taking longer to buildup boost), it would simply not pass 9psi..... I'm sure earlier on in the night it had boosted higher, but can't say for definate. One thing that the diagnostics machine bought up in the thread I mentioned above was something like "Turbo <something> Malfunction". The diagnostics people couldn't work out what this was. I assume that they got that code due to N112 and N249 being removed and bypass..... |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 24
| Calum_Cupra, catellkai, cupra240bhp, cuprawill, Dan1.6, dan1990, Dougy, kelvin_redcupra, liam_R, M87NER, Mat, Monoux, Norregaard, pj1985, R4cup, Ravey_Cupra, redcupraboy, s1l3nc3r, simon d, tarzan, tomxt99, tstrahonja, widdowd, __B3NNY__ |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Limp Mode after fitting Jetex air filter | jonnyblease | Ibiza Mk3 | 17 | 24-09-2009 23:05 |
| Limp mode - no faults | M87NER | Ibiza Mk3 | 17 | 28-01-2009 18:01 |
| Limp mode since fitting FMDVSPLTR advice needed on setting it up. | kenboon | Leon Mk1 | 9 | 19-05-2008 12:27 |
| Turbo Pressure causing limp home mode | smark32 | Ibiza Mk4 | 13 | 29-03-2008 20:11 |
| turbo limp mode wiring fault | stuart edwards | Alhambra | 0 | 09-12-2007 12:32 |
