| Leon Mk2 For all topics relating to the Mk2 Leon |
Thread Tools | Rate Thread | Display Modes |
#1 |
Eat My Soot!!
They've suddenly stopped working!
![]() Checked the fuses (hard to tell which one from the handbook), all seem to be intact. Rear wiper works, & the washers work, just no wipers. What the hell is wrong?
__________________
Black Magic Leon 2.0 TDI Sport - Green panel filter, Upsolute remap, Spax PSX/Eibach Pro Kit, MkV Golf GTI front brakes, 18" Audi A8 parabols, 08 Cupra black grille, MkV Golf rear wiper, Cupra exhaust trim, MFD2, iPod, Custom Bi-Xenons. |
#2 |
Is the bonnet def closed as they will not work if the bonnet is not fully closed? Worth a check
__________________
LEON FR TFSI,WITH SPORTLINES AND NON RESONATED MILLTEK CAT BACK DUAL OUTPUT.
#3 |
MkII Leon FR TDi 170
Had something similar on one of our other cars (wipers and spray on front not working with rear wiper and spray working). Ended up being a faulty switch on the wiper stalk. Wasn't a Seat though.
#4 | |
Insurance co's are crap.
Quote:
Have you had it on VCDS? Checked for fault codes?
__________________
My Sig. |
#5 |
Eat My Soot!!
Haven't had it checked on VCDS yet. Just checking the obvious faults first.
__________________
#6 |
Eat My Soot!!
I've checked the bonnet & that's definately closed.
Anybody know which fuse the wipers are on?
__________________
#7 |
This relates to the Altea so might be the same or a little different. The wipers are on seperate fuses, one for each side. They're under the bonnet on the fuseboard near the battery (if you have one there). From memory, one is fuse number 3 and the other is something like 31.
The wipers run as master and slave, so when you turn them on the ecu sends a signal to the master wiper motor (passenger side) only. The passenger side motor then sends a signal to the drivers side, so if both wipers have stopped working then I'd be investigating the passenger side first. You'll find that there's 4 wires going to the master and 3 wires to the slave so if the motors are the other way round to mine then you'll know by the wiring.
__________________
My Sig. |
#8 |
Eat My Soot!!
Thanks for the info Viking.
The handbook doesn't exactly say which fuse(s) are for the wipers. The closest description is "Cleaning"! I've checked the under bonnet fusebox, but I'll have another look. I've got a feeling it might still be the bonnet catch, as I had the front bumper off at the weekend. It may have been disturbed when I was messing with the bumper.
__________________
#9 |
I suspect you pulled a wire off the switch then. That's where I'd start given the current situation, and ignore the fuses and motors etc.
__________________
My Sig. |
#10 |
Eat My Soot!!
The bumper has to come off again anyway.
Need to tweek my new lights, but it's so bloody cold I really don't want to do it!! I getting too old to be crawling around under cars in the cold & wet!
__________________
#11 |
Eat My Soot!!
Right, it's not the switch or wiring.
Had it checked with VCDS & it's looks like it's the master wiper motor! Apparently they need to be coded in with the car if you replace them?
__________________
#12 |
Master motor (on the passenger side in the Altea) controls the slave motor (on the drivers side).
12volts constant supply goes to both motors, and they're fused separately. When you put the wipers on the ecu sends an activation signal down a separate wire to the master (passenger side) motor, then the master sends a signal to the slave (drivers) motor via a second wire. The signal wire tells the motors to work (in turn) and the motors use the supplied 12v feed to drive them.
__________________
My Sig. |
#13 |
Eat My Soot!!
I've now got this fixed.
It was the master (N/S) wiper motor that was faulty. A new one is £114 from the dealer. I also had to replace the spindle/crank assembly (£97!!) on the N/S as the spindle sheared off when the wiper arm was being removed. It had seized on. The wipers have to be syncronised via VCDS (something I couldn't do), so I took it to my friendly local VAG independant for fitting. So, I'm now £290 lighter but pleased my wipers work!
__________________
#14 | |
Senior Member
Quote:
#15 |
SWING LOW SWEET CHARIOT
That was the very first thought in my mind. LH threads catch a few peeps out.
__________________
BIFIDUS TURBINEUS BOOSTARIUM
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 95
| -pseudonymous-, alx_chung, Andy_FR, antonissilver, B20, Bedlam, Big_Mikey_G, bmb779, Bretty, bronquito, Chan_P1_TDi_FR, chris2401, Ciosmi, clarkey, clarkey2r, coggie, CovCupra, Cupra Jim, Cupra58, cuprakemp, Cupranation, CupraNoobie, Dampy, dan1990, dannychapman10, danston, dazjb69, demey, Donnyboy, evo2345, F8 CMR, fordgt40, GavinM, hellowed, HotHatchSteve, HuckingFell, IanG, ianltd, Ian_1690, itsmefishy, ivan2, jasont87, john atkinson, johnfbr, Jon TDI, kevs fr, Leigh15, LeonFR07DSG, leon_lib, likeitah, mnkiboy, Mobo, moshii, mrsixstring, Nath., nc30rider, NinjaPirateUK, NJ-Geol, No_LiMiT, Oj 89, OldDevonian, onlyonearrow, owen lcr, Paul_W, Pheo, predo, ragz, rdalton15selby, rich146, RickyD1975, rix, rllmuk, robbob, ross27, rslomax, SeanCorky, seatibizadub, shaw25, SiPrince, spacedmonkeys, Starscraper, stevesLeon, SteveTDCi, Stingbrace, Tam, tom fada, Tom99, tomtomwill, toot, tyke666, Viking, warren_cox, Watto_uk, wef24, YIN |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front wipers not working | Mark304 | Leon Mk1 | 1 | 07-02-2010 16:04 |
| VAG-COM stopped working | NottsLCR | VAG-COM & Diagnostics | 4 | 07-01-2010 12:30 |
| Help! My dipped beam stopped working! | aigoro | Ibiza Mk4 | 14 | 13-12-2008 15:07 |
| Front & back wipers - wont switch off! | Matt111 | Ibiza Mk2 | 3 | 07-09-2008 18:24 |
| Front end damaged and fog lights not working | superleon1 | TDi - SEAT Diesel specific topics | 3 | 05-05-2008 23:05 |
