| Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only> |
Thread Tools | Rate Thread | Display Modes |
#1 |
Leon 1.8T on steroids
boost leak? [logs included]
Hello guys
![]() I went out with jamiebennett to do some logging tonight as my car doesn't feel as fast as it was before FMIC. You can check the logs here. http://www.seatcupra.net/forums/show...9&postcount=60 Everything point to boost leak right? Is everything else ok? But my spec boost pretty much is meeting my actual boost all the way. So i dont really understand. Please can anyone put some light on that ?
__________________
My beast - gone but not forgotten
#2 |
Hi!
Which intercooler have you fitted? Some intercoolers can cause laggy boost until stage 2 mapping is carried out. Have you changed the exhaust? Also worth considering the N75 valve, although it seems more likely that the intercooler fitment has caused you an issue |
#3 |
Small one from ebay.
Exhaust is not changed yet. N75J valve you mean Will? Yes im sure that it was intercooler fitment that caused this sluggish behavior but does it look like there is a boost leak? I had some problems taking MAP sensor out. In the end i had to drill screw out. Maybe that damaged sensor somehow :/ Thanks
__________________
#4 |
cooling is the key people
you sure all the pipework is tight mate... no leaks getting out there anywhere?
__________________
inovite cts18s,p-torque 238bhp,koni adjustable ssx,quaife lsd,rear arb,s3 upper/lower,fmic,jetex turbo back system,catch can,ttwishbone bushes,samco tip,apr r1dv,porsche 911 brembos,ds2500,falken452jetex cone.....
#5 |
Well....
Im off now to take bumper off and redo all. See you in 7 hours i guess (there goes my day off) :P btw 178g/s that looks good for a mapped LC i guess ?
__________________
#6 |
Jack-RIP my little Friend
what does block 032 say and block 001,115,003 under boost say?
__________________
![]() BADGER 5 LTD: PERFORMANCE TUNING RACE PROVEN PRODUCTS & HONEST ADVICE: Contact:07976 800775, 01453 827936,Fax-0870 0561360 Bespoke Big Turbo conversions,DevilsOwn WMI,Forge,Ferodo,AP Racing Brakes,Custom Code,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compmotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more... http://www.badger-5.com email me at:bill@badger5.co.uk |
#7 |
I dont have possibility of logging anymore. Thats all i got Bill.
__________________
#8 | ||
Custom DUB Shaun
Quote:
Quote:
![]() I dont need any beers this time though, those will last me a while
#9 |
Everything goes very easy today i must say (touch wood). Bumper off and almost all clips retightened. FMIC straightened up. I will take it for a spin soon. If it doesnt feel better then i will go buy new map sensor.
Anyone knows MAP sensor part number ? EDIT: found it - 0281 002 177 for auq between 00 - 03I must be nuts but im almost enjoying this ![]() Tony i will call you later if after all of the above it wont feel faster. Thanks, i know you got your own car to sort out now.
__________________
#10 | |
Custom DUB Shaun
Quote:
make sure it's tight and sit flush. I can imagine as it tool so long you perhaps out it together in haste as I k ownit took you a while. Trust Me I the feeling as the same happened to me ![]() yep shout me up! Beer is lovely mate
#11 |
LCR jabba'd
hey guys, was just having a look at the logs n doesnt seem like there is a boost leak. requested seems to be meeting or there abouts with the actual boost.
fmic is normally more helpful as a stage 2 upgrade. map might need tweaking. as far as the intercooler being the cause , the thicker piping might be the reason it feels more laggy.thats if your using larger diameter piping than oem pipes. i recently installed a front mount in my lcr and did find that the initial throttle response seemed a little less but the cooler air has made it quicker otherwise.plus i used larger diameter piping than oem pipes. also if i recollect correctly, the map sensor is what vag com uses and your logs show boost to be meeting requested so dont know if the map sensor does need replacing unless ive missed something. dont know if any of that helps tho :-) |
#12 |
4 months old this post mate, greeshas sorted now and it was a leak.
also fmic doesnt require mapping in, ecu will adjust to lower intake temps.
__________________
#13 |
Yes it was either faulty MAP sensor or a leak from MAP senor which got damaged when i've tried to take it off old piping
__________________
#14 |
LCR jabba'd
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Boost leak and hissing sound after cambelt/waterpump change | dentist | Leon Mk1 | 3 | 08-11-2009 12:05 |
| boost leak | bennett turbz | Ibiza Mk3 | 1 | 28-09-2008 22:58 |
| boost leak after fitting hybrid | glynnd | TDi Tuning | 9 | 09-09-2008 10:29 |
| Boost leak? | paulmc | Ibiza Mk4 | 7 | 30-08-2008 18:34 |
