| Mk1 & 2 Toledo Up to 2004 Models |
Thread Tools | Rate Thread | Display Modes |
#1 |
Newbie
Standard ride height suspension?
My 2002 v5 170 has 103k on it and the suspension is, to say the least, no longer at its best. I need to retain the standard ride height due to a combination of towing, unmade tracks and speed humps. The car only gets used on the road so my question is can anyone recommend replacement road shocks that retain the stadard ride height?
Thanks! |
#2 |
Resident frequent flier
I have Koni STR.T's on my MkIV (albeit with -40 lowering springs) and they ride better than stock. These can be bought without the related springs which is what I did as I wanted to pair them with EIbach springs.
UTA |
#3 |
Koni FSDs would be worth considering as they are specifically designed for standard ride height springs; I dont know if the STR.Ts that UTA mentioned are.
I've just put Eibach Pro Springs (and dampers) on mine, theoretically it's a 25mm drop but it's hardly noticeable compared to shagged old suspension, mine was at 103k when I changed too. |
#4 |
Make sure you replace the springs as 1 the front springs broke on mine and the other side was cracked, 2001 V5 170 with 90k on the clock. I replaced all mine with an Eibach sportline kit which is lowered so no good for you. Try German and Swedish they should be able to supply OE spec springs, shocks and top mounts.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 30
| 5dr, AP_V5, ath55, BiGpaPPa, Colin C, CULLYBABE, dizzydiesel, gamer555, gavinmaynard, gemini, hugh_, joeypineapplez, k3nny, mrvavavoom, muhdub, niki, Nkon, odd-head, Phoenix27, sedonou75, sgtcortez, Tartan58, Thev5, Tolly, tony19b, Tuvix, UTA_flyinghigh, vee5, willives, Yorkshire Bob |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| LCR Standard ride height/favour | rsmith | Leon Mk1 | 3 | 24-01-2010 09:55 |
| Spacers on standard suspension and wheels. | AndyVTR | Leon Mk2 | 4 | 24-11-2008 13:03 |
| Uprated springs and shocks without ride height drop? | Willie | Leon Mk1 | 0 | 06-07-2008 18:46 |
| ibiza fr tdi uneven ride height? | jocklad75 | Ibiza Mk4 | 20 | 14-01-2008 07:30 |
