Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 21-02-2010, 10:24   #1
kevsn
dipstick housing
morning all
i got up this morning and decided to check my oil after pulling the dipstick out to check it i noticed the dipstick didnt come out like it should the housing snapped off about 2 inches from the to. so now it doesnt like it should.
anyone else had this problem and would this cause any problems to the running of the car
thanks
kevsn is offline   Reply With Quote
Old 21-02-2010, 10:31   #2
andycupra
status subject to change
andycupra's Avatar
its fairly common, they get brittle over time. Probably due to the plastic and that it gets heated repeatably..
(so much so that when i went i went to a dealer to order a new dipstick i was presented immediately with the plastic housing as they presumed this is what i meant. They break often during serbicing apparently).
Would it cause a problem running... i suspect you can get away with it (although id want to cover the remains to stop and debris getting into the housing).
But i by no means know for sure that its ok.
The resons im thinking it should be ok is that when you check oil you dont usually find oil too high on the dipstick and much of the length of the housing is to make it easy to check the oil rather than have to reach down into the bay which could be dangerous for untrained members of the public.,.
But i would be concerned if it was my car!
__________________
Power = 3 stilo . . . . . . . . Handling = 3 stilo
Looks = 4 stilo . . . . . . . . Driver =
How many Stilo do you have?
andycupra is offline   Reply With Quote
Old 21-02-2010, 10:37   #3
sambryant
RoadRunner meep meep
sambryant's Avatar
I broke the dipstick housing the other day while fitting a new thermostat. That really stressed me out. What I did was remove the rest of the housing and dipstick. I then cut down a cork and put it in the hole. I ran the car like this for 3 days with out a problem. Any way eBay have the new housings for £6.99 . Hope this helps
__________________
FMIC, milltek cat back, scorpion decat, 18" BBS CH, Neuspeed P-Flow, forge 007p, forge cold side kit, red hoses, red tip, n249 bypass, 6000k Hids, full vag com.
sambryant is offline   Reply With Quote
Old 21-02-2010, 10:41   #4
kevsn
thanks for the replys ive just checked on ebay but could find one.
are they easy to change?
sorry my car is a 2001 leon cupra
Old 21-02-2010, 10:44   #5
sambryant
sambryant's Avatar
Very easy they just pull off
__________________
Old 21-02-2010, 10:47   #6
andycupra
andycupra's Avatar
at a guess id say they push fit, so removing old one may be a problem if its really very brittle, and some long arms would be useful..
The top of the housing also clips into the horizontal metal plate that sits between the intake manifold and front slam panel, (underneath the plastic cover).
You will probably have to unbolt this plate which is held in place with two allen key bolts which go horizontally into the inlet manifold, and perhaps there is also two nuts to undo on the plate also...
__________________
Old 21-02-2010, 10:48   #7
kevsn
item number
310181324549
sorry cant post the link i havent posted enough
would this be the right one for my car
sorry but my knowledge is limited
Old 21-02-2010, 10:50   #8
andycupra
andycupra's Avatar
personally if i were you id call a dealer and order the part using your reg / chassis. You want to get the right one and a dealer will get it as quickly as anyone. Not the most pricey part,
although i suspect it will have the part number on the item somewhere
__________________
Old 21-02-2010, 10:53   #9
sambryant
sambryant's Avatar
Here u go. http://cgi.ebay.co.uk/Dipstick-Guide...#ht_2148wt_722
__________________
Old 21-02-2010, 10:56   #10
andycupra
andycupra's Avatar
with estimated delivery 4-6 working days.. or pay more for faster delivery.
__________________
Old 21-02-2010, 10:57   #11
kevsn
many thanks ive only had this car a week or so and just keep finding little faults begining to think i should have kept my boring bora tdi.
does anyone have a auq enigne diagram coz ive noticed that one of my vacuum hoses has tape wrapped round i would like identify it so i can replace it. im guessing its split.
Old 21-02-2010, 11:09   #12
sambryant
sambryant's Avatar
Quote:
Mine took 2 working days by the time I ordered it.
__________________
Old 21-02-2010, 11:20   #13
kevsn
looks like it will be the stealers the one on ebay is part number 06A 103 663B
the one fitted to my car is 06A 109 663B. im guessing they are different parts
Old 21-02-2010, 12:28   #14
sambryant
sambryant's Avatar
i think they are both the same to be honest, as it fits a few different cars. it fitted straight on mine but im running a cupra r.
if it looks the same as the pic im sure it will fit
__________________
Old 21-02-2010, 13:47   #15
kevsn
yeah looks the same ive ordered one and i hope for the best
cheers
Old 21-02-2010, 14:00   #16
sambryant
sambryant's Avatar
good man
__________________
Old 21-02-2010, 14:09   #17
kevsn
I just need to find out which vacuum/breather Hose I need now
Old 21-02-2010, 14:29   #18
kevsn
ill post link if anyone can help me identify it
Old 21-02-2010, 14:29   #19
kevsn
http://i806.photobucket.com/albums/y...1/DSC01161.jpg
anyone
it the one with a roll of tape wrapped round it. ha ha
Old 21-02-2010, 14:31   #20
sambryant
sambryant's Avatar
have a look on awsome gti website i no they sell uprated ones
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 35
andycupra, andytaylor1980, BlackLeon, dent, dippy4000, Disco_Mikey, D_O_U_G_I_E, EL, epts2008, Freerider, gazR, gb, GREY 225, hooky, ianevans, james walker, jcborden, joely, JPKinsey, kenny-cupra, kevsn, Kiirst, l.e.star, L30N DG, Mashburn, Muttley, NickLCR, Pieface, rix, S17EW O, sambryant, thebody, Trublu07, wayne lcr, wezy0
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
*** INA : Billet Coolant Housing for the 1.8T 20V *** INA INA Engineering 6 19-02-2010 15:01
cleaning throttle housing daves ibiza Ibiza Mk3 13 23-09-2009 16:04
Dipstick trouble Yello! Leon Mk2 2 20-09-2008 21:49
non standard maf housing question freegeek Turbo Tuning 8 04-07-2008 22:35
Dipstick Snapped: Particles fell in = Problem? Spud_G40 Ibiza Mk3 3 11-03-2008 23:02
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
