| Ibiza Mk4 For the 2002 - 2008 model |
Thread Tools | Rate Thread | Display Modes |
#1 |
Battery not strong enough
Hello Everyone,
Im running into a problem with my battery. It started when i installed my subwoofer (active) 2 months ago. In the beginning i noticed that all the lights of the car were a bit dimming when i was on low rpm (no gas pressed on neutral). Today i was on the highway and after accelerating hard and then left the engine on neutral, when the rpm gauge reached the bottom my engine switched off. Yesterday i installed a parrot bluetooth carkit so probably that is draining the battery juice even more. I should also note down that for the last couple of days my iPhone charger hasn't been able to charge my iPhone (shows its charging but instead of the battery going up, it goes down). Anyone knows anything about this? Am i gonna need a new battery with bigger capacity, or is it some engine setting?? Thanks in advance!
__________________
Proud Ibiza (mk4 Sport 1.4) owner. Ex Renault Twingo owner (totalled). |
#2 |
Metormorphosis
Certainly sounds like you ought to at least get your battery checked.
#3 |
Just checked out my battery with a multimeter. (car idle for more than 4 hours)
Battery level when engine switched off: 12.4V Battery level when engine switched on: 14.4V AFAIK these indications are good.....
__________________
#4 |
Senior Member
if the car starts fine it doesnt sound like the battery is at fault specialy with the readings you have got. and if the alternator was sh4gged that would also effect it
#5 |
only other thing i can suspect is the grounding of the subwoofer (right now attached to the seat belt metal connector on the chassis). could that be causing an energy circulation problem?
__________________
#6 |
Some more voltage information:
After using the car for 30 KM, subwoofer unplugged: - Car on, right after usage: 13.80V - Car off, right after usage: 12.79V - Car on, after making the prev. measurements and connecting the sub again: 13.80V That 13.80V sounds a bit low doesn't it??...
__________________
#7 |
sounds like your alternator cant keep up with demand of the sub. three options id say uprated alternator.install capasitors or remove the sub
#8 | |
Quote:
removing the sub is not an option :P love it :P upgrading the alternator right now is gonna be pricy and my budget is low atm ![]() capacitors....hmmmmmm......
__________________
#9 |
they shunt be too dear i think maplins are cheap for owt like that
#10 |
wat wattage is the amp for the sub? would check the grounds for the batt and alt...
#11 | |
Quote:
Built-in MOSFET 150 W power amplifier Nominal output power: 60 Watt Max power: 150 Watt I think its either the subwoofer draining the bat (and in that case ill get a condenser) OR the ground of the subwoofer needs remaping.. maybe i should use the ground of the rear lights...
__________________
#12 | |
Quote:
If there are none near enough - make your own earth point - drill a small hole and use a small nut & bolt. Where have you picked up the POWER from ? Is there a remote lead to switch on the sub or is the sub live all the time ? |
#13 | |
Quote:
For the record, this behavior was also present in my previous car (twingo) with the same subwoofer...
__________________
#14 |
The traditional advice would be to think about a power capacitor as well as upgrading the wiring of the car.. i mean the battery to earth and batt to alternator. and batt to the sub. make sure the ground for the sub is as good as poss and all should be well!!!
#15 | |
Quote:
__________________
#16 | |
Senior Member
Quote:
I would also check the battery earth, all those readings mean nothing if the chassis isn't earthed. Let me guess, you measured across the battery terminals? Try the same reading between the battery positive and a point on the chassis. |
#17 | |
Quote:
__________________
#18 |
Would it make a difference if i would get a bigger capacity battery? my battery right now is 44Ah...
__________________
#19 |
Rob
Have you asked in the I.C.E section?
#20 |
not really. Wasnt sure if it was subwoofer related or car related. Should one of the mods move the thread there you think?
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 98
| Ad., Aimez, andycupra, ant49, Anth, Arnoldo, attila_tdi, a_waugh, BBB, bertrum, blackmagicbeeza, bloody_typical, Brummy, Cbreslin91, CGD217, Chino_UK, churchill188, CJRamze, CMR, cowtc, Crispy_fr, CrossyR, Dannyboy69, Dan_T, darkhorse, DEAN0, deebow, Dempsey27, Densley2387, dhali, dicky FR, Dopsonj, Edward9th, Fl@pper, Flyzone, gunsdontkillppl, hodson, ibiza64, James Elder, jeffery, jfinn, JimmyT, joewl92, John-Cupra_TDI, joop200789, joshbro90, JR_130, justjoe, Kai_1600, kidinspace, krussel, lankman, Lazy Jack, Leigh15, luke c, mark.w, MartinDov, Martyn1989, Mattwood, mazzerati, MiguelTavares, Mo.IE, mouse1989, mr india, MrNorma, MWG, Neo, nick0323, NickyJam, Palmer, pete_266, Priezti, push, RazzleUltra, rf860, Rittzy, RUM4MO, SeanyK, shox, Slimy, Slippery_Stu, stebbi, telwick, The Legend, TheCraig, thefingers, thomasa, TonyK, tony_tigger, TubbyTwo, twin2189, wild willy, wongstar83, xpa, Y8 NLD, YorkIbiza, zach225, zoheb |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Battery Discharge Problem | KenR | Leon Mk1 | 14 | 10-03-2010 10:37 |
| battery problem | chris285 | Leon Mk1 | 3 | 02-02-2010 14:20 |
| Leon Battery! what to get? | PM Leon | Leon Mk1 | 10 | 05-01-2010 19:41 |
| Proper battery box Best value for £16 | jcp | Leon Mk2 | 6 | 24-03-2009 16:31 |
| Racing Battery or Standard Battery???? | Dinky Dave | Ibiza Mk2 | 36 | 21-10-2008 22:40 |
