| VAG-COM & Diagnostics VAG-COM is a diagnostics program that allows your PC to talk to your ECU - All VAG-COM / 1551 questions to be posted here |
Thread Tools | Rate Thread | Display Modes |
#1 |
Yellow is the best
N75 logs , any good?
Can someone please look at my log of block 118 and comment if my N75 cycle looks normal? 4th gear run 1920 rpm to red line.
Thanks Group A: 118 Engine Speed Intake Air Wastegate (N75) Boost Pressure TIME Temperature Duty Cycle (actual) Marker STAMP /min °C % mbar 0 1920 15 0 1120 0.24 1960 15 0 1130 0.51 2000 14 89.4 1150 0.76 2040 14 99.6 1190 1.03 2080 14 99.6 1290 1.27 2160 14 99.6 1390 1.54 2240 14 99.6 1500 1.79 2320 14 99.6 1610 2.06 2400 14 99.6 1750 2.3 2480 14 62.4 1900 2.57 2600 14 54.9 2070 2.82 2680 14 55.7 2180 3.09 2800 14 55.3 2250 3.33 2920 14 54.1 2280 3.61 3040 14 52.9 2310 3.85 3160 14 50.6 2300 4.11 3240 14 50.2 2250 4.36 3360 14 50.2 2230 4.63 3480 14 50.6 2220 4.88 3600 14 50.6 2260 5.14 3720 15 50.2 2260 5.39 3800 15 50.6 2220 5.66 3920 15 51 2230 5.91 4040 15 51.8 2210 6.18 4160 15 52.5 2240 6.42 4240 16 53.3 2250 6.69 4360 16 54.1 2260 6.94 4480 17 54.9 2270 7.2 4600 17 55.7 2270 7.46 4680 18 56.1 2290 7.72 4800 18 55.7 2310 7.97 4880 18 55.7 2300 8.23 5000 19 56.1 2290 8.48 5080 19 56.5 2270 8.75 5160 20 57.3 2280 9 5280 20 58 2260 9.26 5360 21 58.8 2270 9.51 5440 21 60 2260 9.78 5560 22 60.8 2290 10.03 5680 22 61.2 2290 10.29 5720 23 61.6 2300 10.54 5840 23 62.4 2280 10.81 5920 24 63.1 2270 11.06 6000 24 62.7 2260 11.32 6080 24 62 2240 11.57 6160 25 62 2220 11.84 6240 25 62.4 2200 12.08 6320 26 63.1 2190 12.35 6400 27 64.3 2200 12.6 6480 27 59.6 2230
__________________
2008 Chrono yellow CUPRA , side skirts, rear spoiler and 3 SEAT CUPRA.NET stickers ![]() ITG INTAKE , FORGE DUMP VALVE , BSH CATCH CAN FOR SALE ALL BRAND NEW http://www.seatcupra.net/forums/showthread.php?t=261584 |
#2 |
Yellow is the best
any one guys?
i have problems so need some help please.
__________________
#3 |
Looks good to me, n75 is trying hard to make boost during initial spool and making the boost easy higher up the rev range. All looks ok, what issues are you having.
__________________
K04 Hybrid Turbo with toys 308 bhp / 292 ft/lbs
#4 |
Yellow is the best
Thanks for the reply
my timing is being retarded , had a rolling road session at JKM at my timing was retarding by up to 5 degrees , lost 40 bhp ![]() so new to vag com and need a bit of help i have more logs to post but i dont know how to add this (code) thing to make them show up better? i am in desperate need of help trying to solve this issue
__________________
#5 |
cooling is the key people
code is the # in the post section, you have to click advanced and press the # and add the logs inbetween it
Code:
Group A: 118 Engine Speed Intake Air Wastegate (N75) Boost Pressure TIME Temperature Duty Cycle (actual) Marker STAMP /min °C % mbar 0 1920 15 0 1120 0.24 1960 15 0 1130 0.51 2000 14 89.4 1150 0.76 2040 14 99.6 1190 1.03 2080 14 99.6 1290 1.27 2160 14 99.6 1390 1.54 2240 14 99.6 1500 1.79 2320 14 99.6 1610 2.06 2400 14 99.6 1750 2.3 2480 14 62.4 1900 2.57 2600 14 54.9 2070 2.82 2680 14 55.7 2180 3.09 2800 14 55.3 2250 3.33 2920 14 54.1 2280 3.61 3040 14 52.9 2310 3.85 3160 14 50.6 2300 4.11 3240 14 50.2 2250 4.36 3360 14 50.2 2230 4.63 3480 14 50.6 2220 4.88 3600 14 50.6 2260 5.14 3720 15 50.2 2260 5.39 3800 15 50.6 2220 5.66 3920 15 51 2230 5.91 4040 15 51.8 2210 6.18 4160 15 52.5 2240 6.42 4240 16 53.3 2250 6.69 4360 16 54.1 2260 6.94 4480 17 54.9 2270 7.2 4600 17 55.7 2270 7.46 4680 18 56.1 2290 7.72 4800 18 55.7 2310 7.97 4880 18 55.7 2300 8.23 5000 19 56.1 2290 8.48 5080 19 56.5 2270 8.75 5160 20 57.3 2280 9 5280 20 58 2260 9.26 5360 21 58.8 2270 9.51 5440 21 60 2260 9.78 5560 22 60.8 2290 10.03 5680 22 61.2 2290 10.29 5720 23 61.6 2300 10.54 5840 23 62.4 2280 10.81 5920 24 63.1 2270 11.06 6000 24 62.7 2260 11.32 6080 24 62 2240 11.57 6160 25 62 2220 11.84 6240 25 62.4 2200 12.08 6320 26 63.1 2190 12.35 6400 27 64.3 2200 12.6 6480 27 59.6 2230 did you copy and paste these from excel?
__________________
inovite cts18s,p-torque 238bhp,koni adjustable ssx,quaife lsd,rear arb,s3 upper/lower,fmic,jetex turbo back system,catch can,ttwishbone bushes,samco tip,apr r1dv,porsche 911 brembos,ds2500,falken452jetex cone.....
#6 | |
Quote:
I would look at things like fuel quality...maybe you filled up with octane 95. Is your air filter clean with no blockages in the intake. was the cooling up to it on the RR, sometimes if they only use a shite fan you'll heat soak and pull chunks of timing which wouldn't happen on the road. Log timing pull and see if you actually have a problem on the road or it may indicate you just need to upgrade your intercooler or use a better cooled RR.
__________________
#7 | ||
Yellow is the best
Quote:
jkm are pretty good with rolling roads as far as i know what blocks do you suggest i log , i can feel it pulling back when driving only use v power , car serviced 1,000 miles ago , at seat no fault codes are present Quote:
thanks for the help , i will try and repost it
__________________
#8 |
Yellow is the best
Code:
Tuesday 2 March 2010 21:27:31 1P0 907 115 C 2.0l R4/4V TFSI 0020 Group A: 3 Group B: 20 Group C: Engine Speed Intake Air Mass Throttle Drive Ignition Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition TIME Angle Sensor 1 Timing Angle TIME Angle Delay Angle Delay Angle Delay Angle Delay TIME Marker STAMP /min g/s % °ATDC STAMP °KW °KW °KW °KW STAMP 0.11 1920 10.5 7.8 14.3 0.23 -0.8 -1.5 -0.8 -1.5 0.35 1920 18.06 12.5 12 0.48 -0.8 -1.5 -0.8 -0.8 0.62 1960 32.69 37.3 17.3 0.75 0 -0.8 0 0 0.87 2000 41.42 98.4 18.8 1 0 0 0 0 1.14 2040 45.64 99.6 18 1.26 0 0 0 0 1.39 2120 50.72 99.6 17.3 1.51 0 0 0 0 1.65 2200 55 99.6 16.5 1.77 0 0 0 0 1.9 2240 61.83 99.6 14.3 2.02 0 0 0 0 2.17 2320 68.94 99.6 8.3 2.29 -3 0 0 0 2.41 2400 76.67 99.6 9.8 2.54 -3 0 0 0 2.68 2520 85.47 99.6 6.8 2.81 -3 0 0 0 2.93 2600 97.67 99.6 6 3.05 -3 0 0 0 3.2 2720 103.97 99.6 5.3 3.32 -3 0 0 0 3.44 2800 111.33 99.6 4.5 3.57 -3 0 0 0 3.72 2920 120.03 99.6 1.5 3.83 -3 0 0 0 3.96 3040 126.33 99.6 1.5 4.09 -3 0 0 0 4.23 3160 133 99.6 5.3 4.35 -3 0 0 0 4.48 3280 133.5 99.6 3 4.6 -2.3 0 0 0 4.74 3400 140.44 99.6 6.8 4.87 -2.3 0 0 0 4.99 3520 146.42 99.6 7.5 5.11 -2.3 0 0 0 5.26 3600 150.14 99.6 7.5 5.38 -2.3 0 0 0 5.5 3720 160.67 99.6 5.3 5.63 -2.3 0 0 0 5.77 3840 173.42 99.6 9 5.9 -3.8 0 0 0 6.02 3960 149.33 99.6 8.3 6.14 -3.8 0 0 0 6.28 4040 160.5 99.6 9 6.41 -3.8 0 0 0 6.53 4160 171.86 99.6 9.8 6.66 -3.8 0 0 0 6.8 4240 177.44 99.6 9 6.92 -3.8 0 0 0 7.05 4360 177.44 99.6 9 7.17 -3.8 0 0 0 7.32 4480 188.64 99.6 9 7.44 -3.8 0 0 0 7.57 4560 188.11 99.6 5.3 7.69 -3.8 0 0 0 7.83 4680 197.64 99.6 5.3 7.95 -3.8 0 0 0 8.08 4800 198.11 99.6 5.3 8.2 -3.8 0 0 0 8.34 4880 195.08 99.6 9 8.47 -3.8 0 0 0 8.59 4960 206.22 99.6 5.3 8.72 -3.8 0 0 0 8.87 5080 207 99.6 10.5 8.99 -3 0 0 0 9.11 5160 208.19 99.6 11.3 9.23 -3 0 0 0 9.38 5240 210.78 99.6 11.3 9.5 -3 0 0 0 9.63 5360 218.33 99.6 11.3 9.75 -3 0 0 0 9.89 5440 222.47 99.6 10.5 10.01 -3 0 0 0 10.14 5520 226.11 99.6 11.3 10.26 -3 0 0 0 10.4 5600 221.83 98.8 12 10.53 -3 0 0 0 10.66 5680 213.83 99.2 13.5 10.78 -3 0 0 0 10.93 5760 207.5 99.6 12 11.04 -3 0 0 0 11.17 5840 211.28 99.6 13.5 11.29 -3 0 0 -3 13.75 6320 10.11 12.9 33 13.61 -1.5 -1.5 -1.5 -1.5 14.01 6320 18.11 12.5 12 13.87 0 0 0 0 Group A: 3 Group B: 20 Group C: Engine Speed Intake Air Mass Throttle Drive Ignition Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition TIME Angle Sensor 1 Timing Angle TIME Angle Delay Angle Delay Angle Delay Angle Delay TIME Marker STAMP /min g/s % °ATDC STAMP °KW °KW °KW °KW STAMP 0.24 2080 44.75 62.4 14.3 0.12 -0.8 0 0 0 0.51 2160 49.69 96.1 18.8 0.39 -0.8 0 0 0 0.76 2200 55.72 99.6 16.5 0.63 -0.8 0 0 0 1.02 2280 64.14 98.8 13.5 0.9 0 0 0 0 1.27 2360 70.72 77.6 12 1.14 0 0 0 0 1.54 2440 74.22 48.2 11.3 1.41 0 0 0 0 1.78 2520 59.81 26.3 16.5 1.66 0 0 0 0 2.05 2560 47.75 22.7 21.8 1.93 0 0 0 0 2.3 2640 57.28 28.6 21.8 2.18 0 0 0 0 2.57 2720 84.47 97.3 15.8 2.45 0 0 0 0 2.82 2800 102.5 99.6 10.5 2.69 0 0 0 0 3.08 2920 121.81 99.6 6.8 2.96 0 0 0 0 3.33 3000 126.06 99.6 6 3.21 0 0 0 0 3.6 3160 128.92 99.6 6 3.47 0 0 0 0 3.85 3280 136.56 99.6 6.8 3.72 0 0 0 0 4.11 3400 137.67 99.6 7.5 3.99 0 0 0 0 4.36 3520 147.64 99.6 8.3 4.24 0 0 0 0 4.63 3600 146 99.6 8.3 4.5 0 0 0 0 4.88 3720 149.19 99.6 8.3 4.75 0 0 0 0 5.15 3840 144.86 99.6 10.5 5.02 0 0 0 0 5.39 3920 170.61 99.6 10.5 5.27 0 0 0 0 5.66 4040 163.97 99.6 10.5 5.54 0 0 0 0 5.91 4160 170.69 99.6 9.8 5.78 0 0 0 0 6.17 4280 173.31 99.6 10.5 6.05 0 0 0 0 6.42 4400 180.36 99.6 9.8 6.3 0 0 0 0 6.68 4480 188.33 99.6 9.8 6.56 0 0 0 0 6.93 4600 193.64 99.6 9.8 6.81 0 0 0 0 7.2 4720 195.53 99.6 9.8 7.07 0 0 0 0 7.45 4800 195.97 99.6 9.8 7.32 0 0 0 0 7.71 4920 201.42 99.6 10.5 7.59 0 0 0 0 7.96 5000 202.42 99.6 10.5 7.84 0 0 0 0 8.23 5080 204.17 99.6 12 8.11 0 0 0 0 8.48 5200 209.67 99.6 12 8.36 0 0 0 0 8.75 5280 212.44 99.6 12 8.63 0 0 0 0 9 5400 215.78 99.6 12 8.87 0 0 0 0 9.26 5480 219.11 99.6 12 9.14 0 0 0 0 9.51 5560 227.44 99.6 12.8 9.39 0 0 0 0 9.78 5640 230.14 99.6 12.8 9.65 0 0 0 0 10.02 5720 233.08 99.6 12.8 9.9 0 0 0 0 10.29 5840 232.81 99.6 12.8 10.17 0 0 0 0 10.54 5880 239.67 99.6 12.8 10.41 -3 0 0 0 10.8 5960 241.64 99.6 12.8 10.68 -3 0 0 0 11.05 6080 239.83 99.6 10.5 10.93 -3 0 0 0 11.32 6160 239.47 99.6 14.3 11.2 -3 0 -3 0 11.57 6200 238.94 98.4 15 11.44 -3 0 -3 0 11.83 6280 242.19 98.4 11.3 11.71 -3 0 -3 0 12.09 6320 120.67 28.2 23.3 11.96 -3 0 -3 0 12.35 6320 99.58 36.5 23.3 12.23 -3 0 -3 0 12.6 6320 127.86 36.1 8.3 12.47 -3 0 -3 0
__________________
#9 |
Yellow is the best
some more logs i have done
Code:
Tuesday 2 March 2010 21:47:38 1P0 907 115 C 2.0l R4/4V TFSI 0020 Group A: 118 Group B: 32 Engine Speed Intake Air Wastegate (N75) Boost Pressure Lambda (Idle) Lambda (Partial) TIME Temperature Duty Cycle (actual) TIME Self-Adaptation Self-Adaptation Marker STAMP /min °C % mbar STAMP % % 0 1920 15 0 1120 0.12 1.8 -0.8 0.24 1960 15 0 1130 0.37 1.8 -0.8 0.51 2000 14 89.4 1150 0.63 1.8 -0.8 0.76 2040 14 99.6 1190 0.89 1.8 -0.8 1.03 2080 14 99.6 1290 1.15 1.8 -0.8 1.27 2160 14 99.6 1390 1.4 1.8 -0.8 1.54 2240 14 99.6 1500 1.66 1.8 -0.8 1.79 2320 14 99.6 1610 1.92 1.8 -0.8 2.06 2400 14 99.6 1750 2.18 1.8 -0.8 2.3 2480 14 62.4 1900 2.43 1.8 -0.8 2.57 2600 14 54.9 2070 2.7 1.8 -0.8 2.82 2680 14 55.7 2180 2.95 1.8 -0.8 3.09 2800 14 55.3 2250 3.21 1.8 -0.8 3.33 2920 14 54.1 2280 3.46 1.8 -0.8 3.61 3040 14 52.9 2310 3.72 1.8 -0.8 3.85 3160 14 50.6 2300 3.97 1.8 -0.8 4.11 3240 14 50.2 2250 4.24 1.8 -0.8 4.36 3360 14 50.2 2230 4.49 1.8 -0.8 4.63 3480 14 50.6 2220 4.75 1.8 -0.8 4.88 3600 14 50.6 2260 5 1.8 -0.8 5.14 3720 15 50.2 2260 5.27 1.8 -0.8 5.39 3800 15 50.6 2220 5.52 1.8 -0.8 5.66 3920 15 51 2230 5.78 1.8 -0.8 5.91 4040 15 51.8 2210 6.03 1.8 -0.8 6.18 4160 15 52.5 2240 6.3 1.8 -0.8 6.42 4240 16 53.3 2250 6.55 1.8 -0.8 6.69 4360 16 54.1 2260 6.81 1.8 -0.8 6.94 4480 17 54.9 2270 7.06 1.8 -0.8 7.2 4600 17 55.7 2270 7.33 1.8 -0.8 7.46 4680 18 56.1 2290 7.57 1.8 -0.8 7.72 4800 18 55.7 2310 7.84 1.8 -0.8 7.97 4880 18 55.7 2300 8.09 1.8 -0.8 8.23 5000 19 56.1 2290 8.35 1.8 -0.8 8.48 5080 19 56.5 2270 8.61 1.8 -0.8 8.75 5160 20 57.3 2280 8.87 1.8 -0.8 9 5280 20 58 2260 9.13 1.8 -0.8 9.26 5360 21 58.8 2270 9.39 1.8 -0.8 9.51 5440 21 60 2260 9.64 1.8 -0.8 9.78 5560 22 60.8 2290 9.9 1.8 -0.8 10.03 5680 22 61.2 2290 10.15 1.8 -0.8 10.29 5720 23 61.6 2300 10.41 1.8 -0.8 10.54 5840 23 62.4 2280 10.66 1.8 -0.8 10.81 5920 24 63.1 2270 10.93 1.8 -0.8 11.06 6000 24 62.7 2260 11.18 1.8 -0.8 11.32 6080 24 62 2240 11.45 1.8 -0.8 11.57 6160 25 62 2220 11.69 1.8 -0.8 11.84 6240 25 62.4 2200 11.96 1.8 -0.8 12.08 6320 26 63.1 2190 12.21 1.8 -0.8 12.35 6400 27 64.3 2200 12.48 1.8 -0.8 12.6 6480 27 59.6 2230 12.72 1.8 -0.8 Code:
Tuesday 2 March 2010 21:44:31 1P0 907 115 C 2.0l R4/4V TFSI 0020 Group A: 115 Group B: 31 Engine Speed Engine Load Boost Pressure Boost Pressure Lambda Sensor Lambda Sensor TIME (specified) (actual) TIME Current Value Specified Value Marker STAMP /min % mbar mbar STAMP 0.18 2320 79.7 1080 1310 0.06 1.02 1 0.45 2360 79.7 1090 1330 0.32 0.99 1 0.69 2400 79.7 1080 1350 0.57 1.02 1 0.96 2440 79.7 1100 1360 0.84 0.98 1 1.21 2520 81.2 1400 1370 1.08 0.98 1 1.48 2560 116.5 2130 1440 1.35 0.98 1 1.73 2640 132.3 2200 1640 1.6 0.97 1 1.99 2720 151.1 2220 1870 1.87 0.95 0.93 2.24 2840 172.9 2220 2100 2.12 0.91 0.91 2.51 2960 181.2 2230 2190 2.38 0.91 0.91 2.76 3080 190.2 2240 2260 2.63 0.89 0.91 3.02 3200 191.7 2240 2280 2.9 0.88 0.88 3.27 3320 190.2 2240 2260 3.15 0.86 0.86 3.54 3440 189.5 2240 2220 3.41 0.84 0.85 3.79 3560 190.2 2240 2230 3.66 0.84 0.85 4.06 3640 190.2 2150 2240 3.93 0.84 0.84 4.3 3800 191 1630 2190 4.18 0.83 0.84 4.57 3880 136.1 1400 1790 4.45 0.84 0.87 4.81 3920 113.5 1310 1550 4.69 0.91 0.95 5.08 3960 97 1200 1470 4.96 0.99 1 5.33 4040 91.7 1190 1450 5.21 1 1 5.6 4080 91 1450 1430 5.47 0.99 1 5.85 4120 106 1460 1440 5.72 1 1 6.11 4200 108.3 1430 1450 5.99 0.96 0.98 6.36 4240 107.5 1360 1450 6.24 0.97 0.98 6.63 4320 103 1290 1450 6.5 0.96 0.98 6.87 4360 100.8 1290 1450 6.75 0.98 0.98 7.15 4400 101.5 1410 1440 7.02 0.97 0.98 7.39 4440 106.8 1420 1440 7.27 0.97 0.97 7.65 4520 109 1410 1440 7.53 0.95 0.95 7.91 4560 109.8 1400 1440 7.78 0.93 0.95 8.17 4640 109.8 1400 1440 8.05 0.92 0.94 8.42 4680 110.5 1380 1440 8.29 0.92 0.93 8.68 4720 106 1270 1440 8.56 0.91 0.93 8.94 4760 102.3 1260 1440 8.81 0.92 0.94 9.2 4800 92.5 1140 1450 9.07 0.92 0.95 9.45 4880 90.2 1140 1450 9.32 0.96 0.96 9.71 4880 89.5 1240 1450 9.59 0.96 0.97 9.97 4920 102.3 1450 1420 9.84 0.97 0.95 10.23 4960 106.8 1450 1430 10.11 0.91 0.92 10.48 5000 82 860 1500 10.35 0.9 0.91 10.74 5000 53.4 700 1300 10.62 1.01 1 10.99 5000 46.6 650 1300 10.87 1.02 1 11.27 5000 47.4 650 1300 11.13 1 1 11.51 5040 47.4 650 1310 11.39 0.99 1 11.77 5000 47.4 660 1310 11.65 0.98 1 12.02 5040 58.6 820 1300 11.9 0.99 1 12.29 5040 78.9 1030 1430 12.16 0.99 1 12.54 5040 80.5 1020 1460 12.41 0.95 0.98 12.81 5040 57.1 730 1420 12.68 0.96 0.98 13.05 5080 51.9 720 1290 12.93 1.02 1 13.32 5040 53.4 720 1310 13.19 0.99 1 13.57 5080 54.1 740 1310 13.45 0.98 1 13.83 5040 55.6 740 1310 13.71 0.98 1 14.09 5040 60.2 860 1290 13.96 0.98 1 14.35 5080 86.5 1120 1440 14.22 0.98 0.99 14.6 5120 87.2 1130 1460 14.47 0.94 0.96 14.86 5120 94 1300 1440 14.74 0.94 0.95 15.11 5200 105.3 1470 1420 14.99 0.91 0.91 15.38 5240 117.3 2220 1390 15.25 0.87 0.88
__________________
#10 |
from memory try channel 020 for timing pull. JKM are normally clued up. Try also channel002 for injector timing and air mass.
__________________
#11 | |
Yellow is the best
Quote:
is it best to do 1 run in fourth gear from low revs to red line , or from first gear to fourth to red line in each gear? thanks for the help really appreciate it. Rob.
__________________
#12 |
from the new logs you've posted your car looks to be performing perfectly.
Airmass logs of 240g/sec is very good.
__________________
#13 |
Yellow is the best
maybe i need to log other blocks?
you on the road you can feel it pulling back notice it more going through the gears , perhaps i should log it this way?
__________________
#14 |
Yellow is the best
On block 20 of my logs why would cylinder 1 be pulling the timing back by -3? but the other 3 cylinders are at zero??
__________________
#15 |
Yellow is the best
more logs 09/03/10
Code:
Group A: 115 Group B: 230 Group C: 231 Engine Speed Engine Load Boost Pressure Boost Pressure Rail Pressure Rail Pressure Rail Pressure Pressure Pressure Load TIME (specified) (actual) TIME (specified) (actual) Difference TIME Marker STAMP /min % mbar mbar STAMP bar bar bar STAMP bar bar % 0.25 2120 103.8 1920 1280 0.37 109.37 108.68 0.69 0.12 4.65 4.55 50.6 0.63 2200 114.3 2030 1430 0.76 120.79 119.3 1.48 0.49 4.65 4.58 52.2 1.01 2320 128.6 2120 1590 1.15 124.48 123.9 0.58 0.88 4.65 4.62 52.9 1.4 2440 145.1 2170 1790 1.52 124.92 124.64 0.28 1.27 4.64 4.64 54.1 1.79 2560 164.7 2210 2030 1.91 124.98 124.7 0.28 1.66 4.64 4.62 55.7 2.18 2680 175.9 2240 2200 2.3 124.99 125.01 -0.02 2.04 4.64 4.61 56.9 2.55 2840 182.7 2260 2270 2.7 124.99 124.8 0.19 2.43 4.64 4.62 58.4 2.94 3000 187.2 2280 2310 3.07 124.99 125 -0.01 2.82 4.64 4.6 59.6 3.33 3160 191.7 2290 2310 3.46 124.99 125.01 -0.02 3.21 4.64 4.6 61.6 3.72 3280 191 2290 2290 3.85 124.99 125.01 -0.02 3.58 4.63 4.59 62.7 4.09 3440 191.7 2300 2280 4.24 125 124.79 0.21 3.97 4.63 4.6 63.9 4.49 3600 190.2 2300 2280 4.61 125.24 124.96 0.28 4.36 4.63 4.63 63.9 4.87 3760 191.7 2290 2300 5 125.58 125.16 0.42 4.75 4.63 4.6 65.5 5.27 3880 186.5 2300 2260 5.39 125.96 124.75 1.21 5.13 4.63 4.59 66.3 5.64 4040 190.2 2320 2300 5.78 126.31 123.61 2.7 5.51 4.62 4.6 67.8 6.03 4160 188 2340 2300 6.15 126.65 123.87 2.78 5.9 4.62 4.63 68.6 6.42 4320 191.7 2360 2330 6.55 127 123.26 3.74 6.3 4.62 4.62 69.4 6.81 4440 191.7 2370 2330 6.94 127.36 114.77 12.58 6.67 4.62 4.57 69.4 7.19 4600 191.7 2370 2340 7.33 127.47 114.25 13.22 7.06 4.62 4.52 70.2 7.58 4720 191.7 2360 2370 7.7 127.49 108.63 18.85 7.45 4.62 4.41 71 7.97 4840 189.5 2360 2310 8.09 127.49 119.95 7.54 7.84 5.71 4.34 91.8 8.36 5000 189.5 2370 2350 8.48 127.49 122.99 4.5 8.22 5.58 4.91 91.8 8.73 5120 191 2370 2360 8.87 127.49 125.64 1.85 8.61 5.49 5.55 91.8 9.12 5240 191 2370 2360 9.24 127.49 125.8 1.69 9 5.37 5.91 80 9.51 5360 190.2 2380 2330 9.64 127.49 125.83 1.66 9.39 5.28 5.83 76.9 9.9 5480 190.2 2380 2350 10.02 127.49 125.39 2.1 9.76 5.16 5.42 78.4 10.28 5600 191.7 2380 2370 10.42 127.49 125.33 2.16 10.15 5.07 5.11 78.8 10.66 5720 190.2 2380 2370 10.79 127.49 125.89 1.6 10.54 5 4.92 79.6 11.05 5840 188 2380 2350 11.18 127.49 126.48 1.01 10.93 5 4.77 86.7 11.45 5920 188.7 2330 2330 11.57 127.49 126 1.49 11.31 5 4.88 85.1 11.82 6040 188.7 2300 2300 11.96 127.49 125.77 1.72 11.69 5 4.98 81.6 12.21 6120 185 2290 2280 12.34 127.49 115.32 12.17 12.08 5 4.86 87.8 12.6 6240 182.7 2300 2240 12.73 127.49 126.33 1.16 12.47 5 5 83.9 12.99 6320 182 2300 2260 13.11 127.49 126.1 1.39 12.85 5 5.01 82.7 13.37 6440 179.7 2310 2280 13.5 127.49 126.35 1.14 13.24 5 4.86 90.2 13.75 6480 136.1 640 2450 13.88 113.66 130.19 -16.53 13.63 5 5.04 83.9 Code:
Group A: 114 Group B: 115 Group C: 020 Engine Load Engine Load Engine Load Wastegate (N75) Engine Speed Engine Load Boost Pressure Boost Pressure Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition TIME (specified) (spec. corrected) (actual Value) Duty Cycle TIME (specified) (actual) TIME Angle Delay Angle Delay Angle Delay Angle Delay Marker STAMP % % % % STAMP /min % mbar mbar STAMP °KW °KW °KW °KW 0 139.1 139.1 88.7 99.6 0.09 2000 92.5 1780 1160 0.24 -3.8 -2.3 0 -2.3 0.36 149.6 149.6 99.2 99.6 0.49 2080 103 1900 1290 0.61 -3.8 -2.3 -3 -1.5 0.76 161.7 161.7 109.8 99.6 0.88 2160 112.8 2050 1410 1 -5.3 -5.3 -3 -4.5 1.13 171.4 171.4 120.3 99.6 1.27 2280 124.8 2150 1550 1.39 -5.3 -5.3 -3 -4.5 1.52 175.9 175.9 133.8 99.6 1.64 2400 138.3 2190 1700 1.78 -5.3 -5.3 -3 -7.5 1.91 180.5 180.5 148.9 99.6 2.03 2520 154.1 2240 1920 2.15 -5.3 -5.3 -3 -7.5 2.3 182.7 182.7 169.2 52.9 2.42 2640 172.2 2270 2160 2.54 -5.3 -5.3 -3 -7.5 2.67 185 185 179.7 54.1 2.81 2800 183.5 2290 2290 2.93 -5.3 -5.3 -3 -7.5 3.06 186.5 186.5 188.7 54.9 3.18 2920 189.5 2310 2350 3.33 -4.5 -5.3 -2.3 -7.5 3.45 188.7 188.7 191.7 52.9 3.57 3080 191.7 2320 2350 3.7 -4.5 -4.5 -2.3 -7.5 3.84 191 191 191.7 52.2 3.96 3240 191.7 2310 2310 4.09 -4.5 -4.5 -2.3 -6.8 4.21 191.7 191.7 191.7 52.2 4.35 3400 191.7 2320 2290 4.48 -4.5 -4.5 -2.3 -6.8 4.6 191.7 191.7 191.7 52.9 4.73 3520 191.7 2320 2320 4.87 -4.5 -4.5 -2.3 -6.8 5 191.7 191.7 191.7 52.9 5.12 3680 191.7 2310 2330 5.25 -4.5 -4.5 -2.3 -6.8 5.39 191.7 191.7 191.7 52.5 5.51 3840 191.7 2320 2330 5.64 -7.5 -4.5 -1.5 -6.8 5.76 191.7 191.7 186.5 53.3 5.9 3960 191.7 2330 2280 6.02 -7.5 -3.8 -1.5 -6.8 6.15 191.7 191.7 184.2 54.5 6.27 4080 186.5 2340 2270 6.41 -7.5 -3.8 -1.5 -6.8 6.54 191.7 191.7 191.7 56.1 6.67 4240 191.7 2360 2340 6.79 -7.5 -3.8 -1.5 -6.8 6.93 191.7 191.7 191.7 56.5 7.06 4360 191.7 2370 2340 7.18 -7.5 -3.8 -1.5 -6 7.3 191.7 191.7 191.7 57.6 7.44 4520 191.7 2380 2350 7.57 -7.5 -3.8 -1.5 -6 7.69 191.7 191.7 191.7 58 7.82 4640 191.7 2370 2370 7.96 -7.5 -3.8 -1.5 -6 8.08 191.7 191.7 191.7 58 8.21 4760 191.7 2360 2350 8.37 -7.5 -3.8 -1.5 -6 8.51 191.7 191.7 191.7 58 8.63 4880 191.7 2380 2350 8.76 -7.5 -3.8 -0.8 -6 8.88 191.7 191.7 191.7 58.4 9.02 5000 191 2370 2350 9.14 -7.5 -3 -0.8 -6 9.27 191.7 191.7 190.2 59.2 9.4 5160 191 2370 2340 9.54 -7.5 -3 -3.8 -6 9.67 191.7 191.7 191 59.6 9.79 5240 191 2370 2350 9.91 -7.5 -3 -3.8 -6 10.05 191.7 191.7 191 60.4 10.18 5400 191 2370 2330 10.3 -7.5 -3 -3.8 -5.3 10.42 191.7 191.7 189.5 61.6 10.57 5480 190.2 2370 2330 10.69 -7.5 -3 -3.8 -5.3 10.81 191.7 191.7 191 62.4 10.94 5600 191.7 2370 2360 11.08 -7.5 -3 -6.8 -5.3 11.21 191.7 191.7 191.7 63.1 11.33 5720 191.7 2380 2370 11.45 -7.5 -3 -6.8 -5.3 11.6 191.7 191.7 191 63.5 11.72 5800 190.2 2380 2350 11.85 -7.5 -3 -6.8 -5.3 11.97 191.7 191.7 188 63.9 12.11 5920 188.7 2340 2320 12.24 -6.8 -3 -6.8 -5.3 12.36 191.7 191.7 189.5 63.9 12.48 6000 187.2 2300 2300 12.62 -6.8 -2.3 -6.8 -5.3 12.75 191.7 191.7 186.5 63.5 12.87 6080 185.7 2280 2270 13 -6.8 -2.3 -6.8 -5.3 13.14 191.7 191.7 183.5 63.9 13.26 6160 183.5 2290 2250 13.39 -9 -2.3 -6.8 -5.3 13.51 191.7 191.7 182 65.5 13.65 6280 182.7 2290 2260 13.78 -9 -2.3 -6.8 -4.5
__________________
#16 |
Yellow is the best
and more
Code:
Group A: 115 Group B: 230 Group C: 002 Engine Speed Engine Load Boost Pressure Boost Pressure Rail Pressure Rail Pressure Rail Pressure Engine Speed Engine Load Injection Intake Air Mass TIME (specified) (actual) TIME (specified) (actual) Difference TIME Timing Marker STAMP /min % mbar mbar STAMP bar bar bar STAMP /min % ms g/s 0.01 1960 72.9 1790 1020 0.14 68.69 68.79 -0.1 0.26 2040 89.5 3.57 43.11 0.39 2040 92.5 1790 1140 0.51 81.15 80.51 0.64 0.65 2120 100.8 3.82 50.08 0.77 2120 105.3 1910 1300 0.9 93.93 94.23 -0.3 1.03 2200 112 4.08 57.33 1.17 2240 118 2060 1450 1.29 104.83 105.02 -0.19 1.42 2280 127.1 4.34 68.25 1.54 2320 133.1 2120 1620 1.68 114.57 115.18 -0.61 1.81 2400 145.1 4.84 81.47 1.93 2440 148.9 2180 1820 2.06 121.91 121.47 0.44 2.2 2520 163.2 5.1 94.81 2.32 2600 168.4 2210 2070 2.45 124.62 125.33 -0.71 2.57 2680 176.7 5.61 107.08 2.71 2720 178.9 2230 2210 2.84 124.94 125.49 -0.55 2.96 2840 181.2 5.61 111.94 3.09 2880 183.5 2250 2250 3.23 124.99 125.31 -0.33 3.35 3000 188 5.86 120 3.47 3040 191 2260 2280 3.6 124.99 125.72 -0.73 3.74 3120 191.7 6.38 130.78 3.86 3200 191.7 2260 2260 3.99 124.99 125.49 -0.5 4.11 3320 191 6.38 134.36 4.25 3320 191.7 2260 2260 4.38 124.99 124.35 0.64 4.5 3440 191 6.38 140.06 4.63 3480 191.7 2270 2250 4.77 125.05 125.49 -0.44 4.89 3600 191 6.38 148.89 5.02 3640 189.5 2270 2240 5.14 125.33 124.86 0.47 5.29 3720 191.7 6.38 155.44 5.41 3760 191.7 2270 2290 5.53 125.69 125.77 -0.08 5.66 3880 191.7 6.38 168.31 5.8 3920 189.5 2270 2250 5.93 126.04 125.38 0.66 6.05 4000 185.7 6.12 156.5 6.17 4080 189.5 2290 2250 6.32 126.41 124.52 1.88 6.44 4160 188.7 6.38 170.06 6.56 4200 191 2300 2260 6.69 126.73 125.85 0.88 6.83 4320 191.7 6.38 178.25 6.95 4360 191.7 2320 2290 7.08 127.1 124.49 2.61 7.2 4440 191.7 6.38 181.81 7.35 4520 191.7 2330 2290 7.47 127.41 124.25 3.16 7.59 4600 191.7 6.63 191.5 7.72 4640 191.7 2320 2310 7.86 127.48 124.49 2.99 7.98 4720 191.7 6.38 196.08 8.11 4760 191.7 2320 2290 8.23 127.49 123.91 3.58 8.37 4880 189.5 6.38 198.64 8.5 4880 190.2 2330 2310 8.62 127.49 125.57 1.92 8.75 5000 191 6.38 206 8.89 5040 191 2330 2310 9.01 127.49 126.59 0.9 9.14 5120 189.5 6.38 208.11 9.26 5160 189.5 2330 2290 9.4 127.49 125.83 1.66 9.52 5240 191 6.38 214.89 9.65 5320 190.2 2330 2310 9.77 127.49 125.45 2.04 9.92 5400 191 6.38 221.69 10.04 5440 189.5 2330 2300 10.17 127.49 125.77 1.72 10.29 5520 189.5 6.38 223.81 10.43 5560 190.2 2330 2300 10.56 127.49 126.12 1.37 10.68 5640 189.5 6.38 230.14 10.8 5680 190.2 2330 2300 10.95 127.49 124 3.49 11.07 5760 189.5 6.38 233.89 11.19 5800 188.7 2330 2290 11.32 127.49 125.16 2.33 11.46 5880 187.2 6.12 234.25 11.58 5920 188 2280 2280 11.71 127.49 126.96 0.53 11.83 6000 189.5 6.12 242.92 11.98 6040 188 2250 2270 12.1 127.49 118.07 9.42 12.22 6120 185 6.12 240.03 12.35 6120 183.5 2240 2210 12.49 127.49 126.38 1.11 12.61 6200 181.2 5.86 238.58 12.74 6240 178.9 2250 2190 12.87 127.49 125.38 2.11 13.01 6320 179.7 5.86 241.47 13.13 6320 179.7 2260 2210 13.25 127.49 125.07 2.42 13.38 6400 178.9 5.86 247.81 13.52 6440 180.5 2260 2230 13.64 127.49 123.42 4.07 13.77 6520 180.5 6.12 251.58 13.89 6520 178.2 2270 2230 14.03 127.49 124.8 2.69 14.16 6600 177.4 5.86 250.86 14.28 6640 176.7 2270 2220 14.41 127.49 125.95 1.54 14.55 6720 175.9 5.61 252.5 14.67 6720 175.9 2280 2210 14.8 127.49 127.04 0.45 14.92 6800 175.2 5.61 251.56 Code:
1P0 907 115 C 2.0l R4/4V TFSI 0020 Group A: 115 Group B: 118 Group C: 032 Engine Speed Engine Load Boost Pressure Boost Pressure Engine Speed Intake Air Wastegate (N75) Boost Pressure Lambda (Idle) Lambda (Partial) TIME (specified) (actual) TIME Temperature Duty Cycle (actual) TIME Self-Adaptation Self-Adaptation Marker STAMP /min % mbar mbar STAMP /min °C % mbar STAMP % % 0.38 2200 102.3 2000 1260 0.13 2120 17 99.6 1150 0.25 1.7 -0.8 0.77 2280 118.8 2110 1450 0.5 2200 17 99.6 1320 0.65 1.7 -0.8 1.16 2400 136.1 2150 1660 0.9 2320 17 99.6 1520 1.02 1.7 -0.8 1.53 2520 154.9 2190 1880 1.28 2440 17 99.6 1730 1.41 1.7 -0.8 1.92 2680 170.7 2230 2110 1.68 2560 17 56.5 1980 1.8 1.7 -0.8 2.31 2840 180.5 2240 2220 2.05 2720 17 54.9 2160 2.19 1.7 -0.8 2.71 3000 185.7 2260 2260 2.44 2880 17 51.4 2230 2.56 1.7 -0.8 3.08 3160 191.7 2270 2270 2.83 3040 17 51.8 2270 2.95 1.7 -0.8 3.47 3280 191.7 2270 2270 3.22 3200 17 51.4 2260 3.34 1.7 -0.8 3.86 3480 191 2280 2250 3.59 3360 17 51 2270 3.73 1.7 -0.8 4.25 3640 191.7 2270 2280 3.99 3520 17 51.4 2250 4.11 1.7 -0.8 4.63 3800 191 2270 2260 4.38 3680 17 51 2290 4.5 1.7 -0.8 5.01 3960 188 2280 2230 4.77 3840 17 51 2250 4.89 1.7 -0.8 5.4 4080 188.7 2300 2260 5.14 3960 18 52.5 2240 5.28 1.7 -0.8 5.8 4240 191 2320 2280 5.53 4160 18 53.3 2260 5.65 1.7 -0.8 6.17 4400 191.7 2330 2290 5.92 4280 18 54.5 2280 6.04 1.7 -0.8 6.56 4520 191.7 2340 2330 6.31 4440 19 55.7 2290 6.43 1.7 -0.8 6.95 4680 191.7 2330 2330 6.68 4600 20 55.7 2350 6.83 1.7 -0.8 7.34 4800 189.5 2320 2290 7.07 4720 21 55.3 2310 7.2 1.7 -0.8 7.71 4960 190.2 2330 2310 7.46 4840 21 56.5 2280 7.59 1.7 -0.8 8.1 5080 190.2 2330 2310 7.85 5000 22 57.3 2310 7.98 1.7 -0.8 8.5 5200 189.5 2330 2300 8.23 5120 22 57.6 2310 8.37 1.7 -0.8 8.89 5320 189.5 2330 2290 8.62 5240 23 58.4 2290 8.74 1.7 -0.8 9.26 5440 190.2 2330 2310 9.01 5360 24 59.2 2300 9.14 1.7 -0.8 9.65 5560 191 2330 2300 9.4 5480 24 59.6 2310 9.52 1.7 -0.8 10.04 5680 189.5 2340 2300 9.77 5600 25 60.4 2300 9.92 1.7 -0.8 10.43 5800 188 2340 2290 10.16 5720 26 62.4 2300 10.29 1.7 -0.8 10.8 5920 189.5 2300 2310 10.55 5840 27 63.9 2300 10.68 1.7 -0.8 11.19 6040 190.2 2260 2280 10.94 5960 27 63.1 2310 11.07 1.7 -0.8 11.58 6120 185 2250 2240 11.31 6040 28 62 2270 11.46 1.7 -0.8 11.97 6240 180.5 2260 2200 11.71 6160 29 62 2220 11.83 1.7 -0.8 12.34 6320 180.5 2260 2220 12.09 6240 30 63.5 2200 12.22 1.7 -0.8 12.73 6440 179.7 2270 2240 12.49 6360 30 65.5 2230 12.61 1.7 -0.8 13.12 6520 178.2 2280 2250 12.86 6440 30 66.7 2240 13.01 1.7 -0.8 13.52 6600 177.4 2280 2220 13.25 6560 31 68.6 2230 13.38 1.7 -0.8 13.89 6680 175.9 2290 2210 13.64 6640 32 71 2230 13.77 1.7 -0.8
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 45
| adzr32, allh2k, AP2000, AVIHAI-TOPOR, BeartheBruce, Bignod00, Big_daddy, billyhas, Bishbash25, charlie_j17, chrisbell, corradophil, craig01, cupra20vt240, Damoegan, davidcupra, diggerbucket, Disco_Mikey, Dougy, Ed_Sutch, EZ Tutty, gazR, gezmeister, harty190486, jake, james walker, JB!, JKM, Jordan20vt, keirravn, markm, ne11er, Prebs, psycho6285, Random1989, redline69, Revo Kev, robdf2, rsmith, s3, shadydaverave, tarzan, top0cat, weerobocupra, wild willy |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| LCR n75 pipe removal - which one? | dicko's | Leon Mk1 | 2 | 05-04-2009 19:25 |
| My Leon Not Looking Good :( | Mr_Tom_Tom | Leon Mk1 | 2 | 18-11-2008 09:42 |
| Another 'Still not happy with the LC' thread (with logs) | tonipieleanu | Leon Mk1 | 8 | 15-10-2008 07:01 |
| Possible N75 problems??! | Jamie P | Ibiza Mk3 | 4 | 12-09-2008 18:38 |
| No boost problem with N75 | KingDragon | Ibiza Mk3 | 6 | 08-07-2008 16:55 |
