| Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only> |
Thread Tools | Rate Thread | Display Modes |
#1 |
Hitting a rev limit to early?
Hello, i have an 02 leon cupra, it has had a remap a couple of years ago, just recently i have noticed that its not quite right. It is fine up to about 4.5 revs then the power just drops, the max speed i can get out of the car is about 118mph! I have had a lot more out of it than that. I have hocked it up to see what faults are there and it came back clean! It seems to be in all gears (only tried from second onwards!) Any ideas?
If there was a problem with the mass air flow sensor would it not show up on the dash or the computer when it was tested? |
#2 | |
Senior Member
Quote:
It should show a fault code though...
__________________
Mods so far - Fabia Rear Wiper, C2 Aerial, Green Cotton Filter, Alpine iDA-x305, Nightbreaker H1 & H7 www.showerspares.com - Spare parts for Showers |
#3 |
MAF doesn;t show a fault code
#4 |
Built Not Bought.
When MAF dies it usually brings on the TC light and does record a fault code but does not usually bring the EML on.
__________________
#5 |
I spoke to my Mrs dad (he's my mech) he said it might not register a code if it doesn't effect the emmissions, so tomorrow i shall take the MAF off and see what happens, then go from there. Some1 mentioned a blocked fuel filter, I dont think it is as it happens at certain points, as in the same time all the time. If it was the fuel filter would it not be at random times and i would feel it through the gears not towards the top end?? huh!
#6 |
i changed the MAF and i did nothin no change at all! any ideas?
#7 |
RoadRunner meep meep
small boost leak somewhere, too small to set the ecu off but big enough to effect performace! cant think of anything else really
#8 |
Senior Member
try running without the maf and see if you notice a difference.
__________________
We will remember them Seat Leon 1.9 tdi
#9 |
Senior Member
clean the throttle body?
__________________
#10 |
Sounds like the same symptons I had. Turned out to be the crank position sensor.
http://www.seatcupra.net/forums/showthread.php?t=255484 |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Error Code 17916 - Idle Sys.Learned Value Upper Limit Attained | dave_ph | VAG-COM & Diagnostics | 4 | 22-12-2009 10:24 |
| Rev counter issue | shibadybob | VAG-COM & Diagnostics | 9 | 29-12-2008 23:32 |
| Tyre hitting arch liner! | Cupra20 | Ibiza Mk3 | 31 | 07-07-2008 12:33 |
| Rev Limit | Redz2486 | Ibiza Mk2 | 1 | 12-11-2006 20:15 |
| Rev Limit | Prometheus | Leon Mk1 | 4 | 17-11-2003 23:08 |
