| Opie Oils OPIE OILS specialises in the distribution of quality oils and lubricants. They sell one of the most comprehensive ranges of quality engine oils and automotive lubricants available anywhere in the UK from manufacturers including Fuchs, Silkolene, Castrol, Mobil, MOTUL, Redline and Amsoil. |
Thread Tools |
Rating:
Display Modes |
#61 |
Forum Sponsor
As the oil is only going to be in there a little time, the grade isn't too important 15w-40 or 10w-40 are fine, although as it's a PD engine, I would probably go for something a little better than the cheapest oil I could find due to the pressure the oil is under. You can drive it, just don't thrash it for that time.
__________________
Use the code CUPRA and get 10% Club Discount oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944
#62 |
Hi i always used to use the Silkolene Pro S in my Nissan Pulsar GTIR and would like to continue using it in my Leon Cupra R 225 which is standard, could you tell me the right one to use please?
Many thanks |
#63 |
Forum Sponsor
Yes, Pro S is a good choice and I would go for the Pro S 5w-30.
http://www.opieoils.co.uk/p-68896-fu...ngine-oil.aspx Cheers Tim
__________________
#64 |
3071
Hi, Tim
![]() I use a 5w/50 oil in my car at the moment, and get some smoking on startup which disappears after a few mins and doesnt come back at all driving, i think the oil is maybe too thin and goin through the seals of the turbo on startup. (i need to check the restrictor on the turbo to make sure its the correct size as well) Ive been thinking about using the Mobil 1 15w/50 motorsport oil or the Silkolene Pro S 10w/50 as my car is probably over 400bhp and i do a lot of track days where ive seen the temps nudging the 120 mark, is this something which you would reccomend?
__________________
#65 |
Forum Sponsor
I would go for the Silkolene (now Fuchs) Pro S 10w-50. 5w-50s aren't great oils, most break down to be a 5w-40 fairly quickly and that is probably it's getting past the seals
__________________
#66 |
Engine Oil Recommendations
Hi Oilman
Can you recommend correct engine oil? Make: Seat Model: Leon Mk 2 - 2.0TDI 140 DSG Year: 2006 Engine type:2.0TDI 140 (Unsure of Code) Performance modifications: SuperChips remap Driving style: (road / off-road / track etc) Everyday road. Any other information that may be relevant: e.g. approx 185 BHP, 33,500 miles covered recommendation are you looking for? Engine oil Many thanks
__________________
Leon 2.0 Tdi Sport DSG - Superchips Re-map - Arm Rest - Bluetooth |
#67 |
Forum Sponsor
Hi
You need an oil that meets the 504.00 spec. 504.00 - http://www.opieoils.co.uk/c-749-vw-50400-oil.aspx The 504.00 oils*are all good oils, so make your decision based on any brand/price preference you have. Instead of using them as a longlife oil, I would change them annually due to the remap. Cheers Tim
__________________
#68 |
Sir Bob,a geordy legend..
What would you recommend for a 300bhp 2.0T FSI (GOLF ED30)?
Will be changed anualy if not every 6 months... |
#69 |
Forum Sponsor
Supposed to be a VW504 5w-30 spec oil. How often does it get serviced? Is it on the fixed or variable (longlife) service? If on fixed you could go for a good performance spec 5w-30 synthetic with changes around 10,000 miles or once a year, whatever comes first.
Cheers Guy
__________________
#70 |
I always change my oil every 6-12 months regardles of service intervals
#71 |
Forum Sponsor
Then dogs danglies would be something like this http://www.opieoils.co.uk/p-68896-fu...ngine-oil.aspx
Cheers Guy
__________________
#72 | |
Quote:
#73 | |
Quote:
__________________
#74 |
Hey i have a mk 1 lcr on a 54 plate. Its done 58k and has an ihi turbo conversion and bosch 440cc green top injectors. Bhp is around 345. Im not entirely sure what oil is best for the car. Not sure on oil temps, im in the process of having gauges fitted.
Only used on the road Thnx Andy |
#75 |
Forum Sponsor
If used hard I would be tempted by a good performance 5w-40 synthetic changed once a year or every 10,000 miles, what ever comes first.
The best are the likes of the Silkolene/Fuchs Pro S, Motul 300v, Redline, Millers CFS and the Gulf Comp here http://www.opieoils.co.uk/c-656-5w-40.aspx Cheers Guy
__________________
#76 |
Thanks alot Guy
Appreciate the info, ill take a look |
#77 |
Hi there,
I'm afraid I'm a bit of novice when it comes to asking the right questions! but I'm keen to make sure I keep my car topped up with the best fit for usage to keep it running smoothly. I'm coming up to a 90k service and I would maybe like to bring my own oil to the garage as I'm not 100% sure what they will use. Make: Seat Model: Leon Cupra 20VT Year: 2001 (Nov) Engine type: 1.8 Petrol Performance modifications: n/a Driving style: (road / off-road / track etc) - B roads mainly As a final silly question, how much oil should I be looking to provide to fulfil an oil change? Many thanks, Doug |
#78 |
Forum Sponsor
Hi
I would use a 5w-40 synthetic and you will find those through the link below. http://www.opieoils.co.uk/c-656-5w-40.aspx Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS, Motul 300V, Redline and Gulf Competition. The Motul 8100 X-Cess, Millers XFS, Fuchs Supersyn and Mobil Synt S are good, cheaper alternatives. According to my data, it only needs 3.5L for a change. Cheers Tim
__________________
#79 |
Cheers Tim, appreciated
#80 |
Hi Oilman.
What engine oil would you recommend for: Make: Seat Model: Leon Mk1 Year: 2004 Engine type: 1.9 tdi 130 Performance modifications: Custom remap (about 175bhp) Driving style: Fast Road |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Stereo head unit advice (iphone/ipod, moving towards subwoofer) | Mewcenary | Modifications and Tuning | 59 | 24-07-2009 08:52 |
| oil change advice | lee25 | Leon Mk1 | 3 | 22-07-2009 19:52 |
| New MK3 Owner Advice. | Tizer | Ibiza Mk3 | 2 | 24-11-2008 11:52 |
| Springs advice! | upkidget | Cordoba | 1 | 16-11-2007 11:21 |
