Custom-Code
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 04-03-2010, 22:41   #1
Joeb
Joeb's Avatar
Loud 'wooosh' when applying throttle
Hello people,
this is probably a straight forward one for the boffins...
LCR - 225 - stage 1 revo
Today, when i applied the throttle, the car kind cut back and produced a loud 'WOOOSH' as if ive got a dump valve or something...
Im thinking this is some kind of hose split or something?
ive recently changed the spring in my Forge DV to a yellow one...
what do you guys think?
ive had a quick look and no hose seems to be disconnected or anything (but it could be anywhere right?)
any advise would be great, thanx
Joeb is online now   Reply With Quote
Old 04-03-2010, 22:44   #2
AntneeUK
2 Wheels 2 Many
AntneeUK's Avatar
Which DV do you have? By the way, a DV IS a dump valve
AntneeUK is offline   Reply With Quote
Old 04-03-2010, 22:46   #3
Joeb
Joeb's Avatar
oh sorry
its a forge recirculating value
007p
Old 04-03-2010, 22:49   #4
AntneeUK
2 Wheels 2 Many
AntneeUK's Avatar
I assume you've tried putting it back how it was to see if it cures it?
Old 04-03-2010, 23:42   #5
Joeb
Joeb's Avatar
hey thanks for the reply...
just went for a little test drive...
i think it maybe something more serious
as well as the large Wooooosh, the car has now brought an error code - CODE 16487
things get worse...
The TC and engine management light are on...
the break light started to flicker and when i was stationary at the lights, the car CUT OUT and i had to restart the engine.
Im calling the AA at the moment, its basically undrivable...
Old 04-03-2010, 23:46   #6
gazR
LCR
gazR's Avatar
isnt this the maf dying?
__________________
Leon Cupra R 225
gazR is offline   Reply With Quote
Old 04-03-2010, 23:49   #7
PHIL LCR
PHIL LCR's Avatar
Hello mate
Have you checked all the pipes are on securely? I had a similar problem a few weeks back, I noticed that the pipe from the o/s intercooler going to the charge pipe had come off slightly. Just a matter of putting back on properly and tightening jubilee clip up. Then back in business.
Hopefully yours is something simple too. Good luck.
__________________
PHILS LCR PROGRESS THREAD!
PHIL LCR is offline   Reply With Quote
Old 04-03-2010, 23:54   #8
Joeb
Joeb's Avatar
cheers people
hello phil,
what symptoms were u having exactly?
Old 04-03-2010, 23:56   #9
adam cupra 20vt
Built Not Bought.
adam cupra 20vt's Avatar
things get worse...
That fault code and the fact the TC light is on points to a knackered MAF sensor although I'm not sure how the 'woosh' noise comes into it,
__________________
adam cupra 20vt is offline   Reply With Quote
Old 04-03-2010, 23:58   #10
gazR
LCR
gazR's Avatar
i thought it the maf was cutting the power and releasing the boost through the dv. it did in my last car when the maf was knackard
__________________
Leon Cupra R 225
Old 05-03-2010, 00:00   #11
adam cupra 20vt
Built Not Bought.
Yeah could be the ECU pulling it back because the MAF is knackered and the noise is the DV opening?
I'm thinking in my head more of a high pitched whoosh than a DV woosh....hard to picture these things from just words! lol
__________________
Old 05-03-2010, 00:04   #12
gazR
LCR
gazR's Avatar
i know yeah lol
there a fault code saying it the maf id try a friends to see if it is or just change it
__________________
Leon Cupra R 225
Old 05-03-2010, 00:04   #13
Joeb
Joeb's Avatar
thanks for the advice
been waiting for AA for 45 minutes now, ******s lol
its hard to describe the WOOOSH to be honest, it does sound like a big release of BOOST
ahem, revo settings have been high :-p
Old 05-03-2010, 00:10   #14
gazR
LCR
gazR's Avatar
45 minutes thank god im with the RAC, let us know how you get on
__________________
Leon Cupra R 225
Old 05-03-2010, 00:11   #15
adam cupra 20vt
Built Not Bought.
You can disconnect the MAF and try it? that will prob bring up a code to but would tell you if its buggered?
__________________
Old 05-03-2010, 00:17   #16
Joeb
Joeb's Avatar
cheers lads
just got thru to AA, about an hour wait lol
lets hope the mechanic knows about VAG error codes
u rekon he (or she!) will have a spare MAF in his van of goodies? lol
Old 05-03-2010, 00:20   #17
adam cupra 20vt
Built Not Bought.
I doub't it
Mine went end of last year, genuine Bosch ones are about £66 exchange from GSF.
__________________
Old 05-03-2010, 03:37   #18
PHIL LCR
PHIL LCR's Avatar
cheers people
hello phil,
When it should have been boosting I was just getting a sort of whooshing noise, hardly any power and the Diagnosis/Excess of pollution light on.
Doesn't really sound like the same problem as yours though. Hope you get it sorted.
__________________
Old 05-03-2010, 04:47   #19
Captain Cupra
Captain Cupra's Avatar
SOUNDS LIKE YOU HAVE A BOOST LEAK MY FRIEND!!!!
Check all major Boost pipes first look for signs of spray like a mist of dirt on surrounding components, then check the smaller hoses that connect to to recircluating valve, the most common component to fail is the rubber seal on the metal boost pipe fitting that comes from the pancake pipe on the drivers side behind the wheel from the intercooler then there is a section of rubber hose it then joins the metal section up to the turbo this rubber to metal join has a rubber gasket that over time falls to peices through it perishing with being hot and cold all the time, you will see signs of leaking surrounding the area or a misting of oil spray on the back of the sump depending on what side of the gasket hase blown through.
Could also be a split DV diaphram?
__________________
___________________________
2003 Mk1 Leon Cupra 1.8T AUQ
Captain Cupra is offline   Reply With Quote
Old 05-03-2010, 04:59   #20
Captain Cupra
or ya piston in the forge dv has become stuck or dislocated in the housing some how but not sure its possible, Check you have screwed it back up tight after you changed the spring
Id still go with my previous diagnosis of a big gaping mother of a boost leak although saying that it only has to be a little hole/leak and it makes a right old racket bit like the missus really! (Mouth)
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 109
2footpegs, 8bit, 8MU, aaronjules, adam cupra 20vt, adam5363, andi leon frtdi, andytaylor1980, AntneeUK, antzleoncupra, Art0ir, auq, Bakes100, batman3000, beechey, Bishbash25, calum001, Captain Cupra, CGD217, ChrisGTL, Chrissy20vt, christoff, CupraTDi, Dani_b19, dannypea, Dave_b, demon_dan, dh00001, DiesalTDI, dippy4000, Don Eason, DontPanic, DUB BOY, evvo, FishmanUK, FRESHMODE, FR_POWER, funkycupra, gavinchappell, Gaz-04, gazking2004, gazR, great_kahn, greesha, ianevans, ibizacupra, ikhlaq206, Irie, james walker, JamJay, jaybeee, jgrandfield, jgy6000, Joeb, john.waterman, Jonezyfr, Jonwm, JPKinsey, karlw, kevh, kevsn, LEE69, legoman_0, leonrob, libiza2007, lm_gauci, marco cupra, MarkWales, Mat, Mattrix, mjt, mrwookie, Muttley, Naif, NickLCR, Niktron, paul6316, PHIL LCR, platofan, prezf, robbob, robertj, Rocky Rocastle, rodderz24, rst2t, S17EW O, S3 Nattie, SalSheikh, sambryant, samfla, schofield, Seat Gooner, Seat_Stu, seppuku, sexynips, shaunymac, sheffboy, sick2death, sie77, Spawney, Steely, STIGGY MINT, tattybits, traumapat, Trublu07, Twiggy86, TwoZeroAlpha, vngtx, wjohnson
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Jetex Induction Kit/Cone Filter. J0N Leon Mk1 438 Today 14:32
Loss of Throttle, please help me cupra_clive Leon Mk1 9 30-01-2010 13:39
throttle body / throttle position sensor kirsti.c Ibiza Mk2 0 29-01-2010 11:54
Boost problems on newly Revo'd LCR? speedsix REVO Technik Tuning 20 20-08-2006 10:24
Vag com comparison LCR mat Leon Mk1 84 03-05-2005 00:19
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
