SG Petch SEAT
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 05-03-2010, 21:17   #1
corbs
Newbie
Replaced headlight bulb still not working - Ibiza 1.9 2006
I'm not really mechanically minded but would like to learn a little and with the help of a friend replaced a dodgy headlight bulb with a new one and still not working. Passenger side.
Visually the old one looks damaged new one as you would expect visually no defects.
Not sure if it is a fuse issue I guess not as I doubt a car would have a single fuse for a single bulb? I don’t have the owner’s manual to check the fuses.
Any ideas greatly appreciated Car is 1.9 TDI FR 2006.
Thanks,
Craig.
corbs is offline   Reply With Quote
Old 05-03-2010, 21:43   #2
DEAN0
Thanks,
Craig.
Have you checked the fuses ? - i'm sure there is one per side on the fr
DEAN0 is offline   Reply With Quote
Old 05-03-2010, 21:57   #3
corbs
Newbie
Quote:
Hi, weird as all the other lights work?
I'll check the fuses tomorrow - I'll have to go through all of them one by one :S but if it has to be done
Old 05-03-2010, 23:24   #4
zach225
zach225's Avatar
It wudnt be too safe now if a fuse blew and took both your headlights out in the middle of the night lol
chech the fuses mate, maybe one caused the other to blow
__________________
tdi 130 platinum grey. Rtech remap 175bhp 300ftlbs, 17" zcw angels. http://www.seatcupra.net/forums/showthread.php?t=256101
zach225 is offline   Reply With Quote
Old 06-03-2010, 00:22   #5
kidinspace
One of those I.T. guys...
kidinspace's Avatar
I'm fairly sure all the manuals and fuse cards are the same regardless of what car you have.
Fuse list...
Quote:
1. Free
2. ABS / ESP
3. Free
4. Brake Light, Clutch
5. ECU (Petrol)
6. Dipped Beam (RHS)
7. Dipped Beam (LHS)
8. Mirror Heating Control
9. Lambda Probe
10. "S" Signal. Radio Control
11. Free
12. Height Adjustment Headlights
13. Level Sensor / Oil Pressure
14. Additional Engine Heating / Oil Pump
15. Automatic Gearbox Control
16. Heated Seats
17. Engine Control Unit
18. Instrument Panel / Heating and Ventilation, Navigation, Height Adjustment Headlights, Electric Mirror
19. Reverse Light
20. Screenwash Pump
21. Main Beam (RHS)
22. Main Beam (LHS)
23. License Plate Light / Pilot Light for Sidelight
24. Wipers
25. Sprayers (Petrol)
26. Brake Light Switch / ESP
27. Instrument Panel / Diagnosis
28. Control: Glove Compartment Light, Boot Light, Interrior Light, Sun Roof
29. Climatronic
30. Free
31. Electric Window (LHS)
32. Control Central Locking
33. Self-fed Alarm Horn
34. Current Supply
35. Open Roof
36. Engine Fan / Ventilation
37. Pump / Healight Washers
38. Fog Lights, Rear Fig Lights
39. Control Petrol Engine Unit
40. Control Diesel Engine Unit
41. Fuel Level Indicator
42. Transformer Ignition
43. Dipped Beam (RHS)
44. Electric Window, (Rear LHS)
45. Electric Window, RHS
46. Control Wipers
47. Control Heated Rear Screen
48. Control Turn Signals
49. Lighter
50. Current Rain Sensor / Central Locking
51. Radio / CD / GPS
52. Horn
53. Dipped Beam (LHS)
54. Electric Window, (Rear RHS)
Fuse Cards...
Hope this helps...
.G.
kidinspace is offline   Reply With Quote
Old 06-03-2010, 13:26   #6
corbs
Newbie
It helped
Thanks for this I’ll be printing it out
Using the fuse layout above quickly figured it wasn’t the fuses that was the issue (Removing and swapping them etc), and then swapped the blub over with the other side. Turned out to be the new blub! Visually there seems to be nothing wrong with it.
Another new bulb in and sorted
Thanks for all your help and comments guys
Next issue rear washer although I’ve heard this is a common fault so I’ll do some digging on the forums.
Cheers,
Craig.
Old 06-03-2010, 13:32   #7
kidinspace
kidinspace's Avatar
Cheers,
Craig.
Yep, very common, mine has only ever come off in two places, either in the boot lid - directly behind/underneath the washer/wiper mecahnism or in the engine bay just next to the bulkhead on the left hand side. Should be as simple as removing the relevant bits of trim if needed or reaching down and popping it back togather, then it's a case of remembering not to use it when it is 0 degrees or below...
.G.
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 29
aanev, ant49, Arnoldo, Art0ir, a_waugh, blackmagicbeeza, corbs, DEAN0, deebow, dicky FR, Edward9th, garethgje, hardcore4, ivorbign, jason-jm, JoeyTGK, kidinspace, Kongen, Kris@Forge, mark1231, Neo, philharris68, Priezti, RachIbiza, Rory101, Stiglet, zach225, zoheb, zoomer46
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
IBIZA 1.9 TDI dualmass or single flywheel? denispearl Ibiza Mk4 30 23-02-2010 15:44
MK4 (2006) Ibiza Cupra TDI plastic undertray CupraOl Ted Johnson SEAT, Barnsley 2 11-11-2009 21:29
Ibiza 1.9 TDI s warning lights xtremei Ibiza Mk4 3 20-11-2008 21:01
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
