Backdraft Motorsport
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 07-03-2010, 00:27   #1
RaggedLob
The worst is yet to come
RaggedLob's Avatar
Alternator belt replaced- still squeaking :S
My 2002 1.2 Squeaks harshly on startup, so i id the usual thing and had the alternator replaced, the garage taking half my monthly part time wage
But at least it would be fixed...
Except it wasn't. I picked it up the next day and it still makes the same noise, was told it may just need 'bedding in' but it has been over a month now... anyone have any ideas?
__________________
Mk4 1.2 Beeza...Speakers and Amp in, next big jobs: Cupra Bushes, Exhaust.. http://www.seatcupra.net/forums/showthread.php?t=232076
RaggedLob is offline   Reply With Quote
Old 07-03-2010, 06:04   #2
Nath.
SWING LOW SWEET CHARIOT
Nath.'s Avatar
A faulty alternator doesn't normally cause squeaky belts.
The noise comes from the belt slipping or chattering due to being worn or just being loose.
I would have gone for a new tensioner as these are spring loaded and can become week, and a new belt whilst you're at it just to be sure.
I bet the garage that replaced your alternator for you have got it on their shelf ready to sell on.....................
__________________
BIFIDUS TURBINEUS BOOSTARIUM
Nath. is offline   Reply With Quote
Old 07-03-2010, 09:23   #3
Priezti
Auto-Electrical Monkey!
mine had this issue and it turn out to be the tensioner that was failing it was not running straight and you could tell if you look at it with the engine running.
Priezti is offline   Reply With Quote
Old 07-03-2010, 10:14   #4
DonniD1991
Big Donni
DonniD1991's Avatar
mine has the same problem. well it happens now and then normally on cold wet mornings
so are the tensioners exspensive and easy to change?
__________________
My ECLIPSE BLUE ibiza 1.2 FR REPLICA!!! new pics
http://www.seatcupra.net/forums/showthread.php?t=235024
DonniD1991 is offline   Reply With Quote
Old 07-03-2010, 11:06   #5
RUM4MO
Senior Member
One thing to consider as this is only happening "now and again and then normally on cold wet mornings", leaving the "wet" bit behind, when its cold and the car has not been running for a while, then if the battery is dying or become "lazy", after the car has started up, the battery will be putting quite a heavy load on the alternator - so noises will be greater than when its hot. Maybe get the battery checked out first - or do you do a lot of short journeys which will be gradually draining the battery over a long period.
RUM4MO is offline   Reply With Quote
Old 07-03-2010, 11:31   #6
DonniD1991
Big Donni
DonniD1991's Avatar
Quote:
yeh a generally just travel short distances to college and work which are both only a few miles from home not even that i would say.
wel me dads got a new battery for me bros polo(6n2) in the garge so al put that in and see if it still does it.
cheers mate much appreciated
Andrew
__________________
Old 07-03-2010, 11:44   #7
darkhorse
Quote:
The 'self adjusting' tensioner has a tendancy to stick in one place. I find that taking the belt off and moving the tensioner by hand over it's entire sweeping movement helps things. If this doesn't help, as Nath said, get a new tensioner.
A bodge it and scarper trick is to spray hairspray over the ribbed side of the belt but using too much can gunge up the pulleys
darkhorse is offline   Reply With Quote
Old 07-03-2010, 11:47   #8
tooly1
1.2 power !
tooly1's Avatar
ive got that problem its the tensioner when i first got it four months ago it was awful but its gradually kinda gone weird still im gonna fix it when i can be arsed to go to my old mans garage
tooly1 is offline   Reply With Quote
Old 07-03-2010, 18:50   #9
RaggedLob
RaggedLob's Avatar
Yeah, sorry, i mean the belt I will try the tensioner solution soon, see if that changes things...
Cheers for the help
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 36
ant49, benny91, black-baddog, cooljules1974, coolspot007007, cooper61uk, Cordoba Cruiser, darkhorse, dicky FR, DonniD1991, Edward9th, hardcore4, ibiza64, jay10, joop200789, laupie07, LUFC, magicmcfc, mark.w, markm, mazzerati, MrNorma, Nath., Neo, PJ_TDi, Priezti, RaggedLob, ralph, rf860, RUM4MO, schofield, SonicFirestorm, tooly1, Vipers_Venom, zach225, zoheb
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Replaced headlight bulb still not working - Ibiza 1.9 2006 corbs Ibiza Mk4 6 06-03-2010 13:32
Squeaking noise on startup stezo2k Ibiza Mk4 9 24-03-2009 18:36
coil pack replaced then complete system failure on ECU! Julabuba Ibiza Mk3 6 11-02-2009 22:04
headlamps replaced :-) seremotors Leon Mk2 12 25-01-2009 19:06
Maybe a cure for squeaking wing mirrors demontank Leon Mk2 7 13-11-2008 21:59
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
