| Ibiza Mk2 For VW Group 1993-1999 Discussion (including Pre & Post Facelifted Models) |
Thread Tools | Rate Thread | Display Modes |
#1 |
MikeC
help - car cut out, wort start
was driving along on fuel light go to petrol station and car just cut out i put fuel into the tank still turned over but no start then i called the rac and they said it had no spark so i belive it to be the coil pack so i had a spare at home so chnaged it this morning so got batterty charging as well
anybody know of anything elsecould be ?//
__________________
coming soon to a book store near you THE CHEAP YORKSHIREMANS GUIDE TO FIXING A MK2 ! |
#2 | |
Senior Member
Quote:
#3 |
MikeC
yes all leads connected and cleaned
colould oil level have anything to do it lol i noticed oil was low
__________________
#4 |
Shallow
coil/battery are the top 2 on the list if it just conked out as you say.
Check the leads/dizzy cap (little carbon rod thing) and make sure nothing it loose but I'd be surprised if it wasnt the coil tbh
__________________
Estate Evangelist |
#5 | |
MikeC
Quote:
last month had new dizzy cap and rotary arm and coil so i think coil is faulty but ill double check leads and battery is charging
__________________
#6 |
vtr btr :)
crank position sensor mate??
__________________
1 step forward, 2 steps back. its just the mk2 way
#7 |
MikeC
hmm ill have a look is this a common fault the crank sensor
__________________
#8 |
vtr btr :)
is something that people have had go that causes the same problem your having. is about £45 for a crank sensor but is a pig to fit. might be worth trying the coil first just to rule it out. if that don't sort it then i'd defo try the crank sensor next.
__________________
#9 |
MikeC
ok fittered new crank sensor new coil pack checked all leads its like there is no spark still turns over but no spark it is as if the spark is not getting to the coil i had a speed sensor reading on fault reader cleaner it off then the reading went but im stumped as i say new coil new crank to rotary arm new dizzy cap all wires look ok and not broken please help
__________________
#10 |
Vince
bad earth?
#11 |
MikeC
check earth to coil and the one to battery is connected as all other radio horn lights work
__________________
#12 |
MikeC
i do have a small and red and yellow lead with a orange connector on the end coming from wiring loom cant see where it goes but was dangling near cranksensor but all cable in area seem ok and connected
__________________
#13 |
checked the spark plugs?
#14 |
Vince
if its a single pin orange block on the end its a spare for oil pressure gauges on some models.
#15 |
MikeC
spark not getting past the coil so no way can be spark plugs as they after
__________________
#16 | |
MikeC
Quote:
does it do much haahahahha that not stopping me going tho
__________________
#17 |
Vince
#18 |
Vince
have you checked the belt is still turning with the cams?
#19 |
Vince
possibly ecu aswell. (im sneakily reading threads on golf owners forums
)also just found this : http://www.seatcupra.net/forums/show...t=misfire+rain Last edited by vngtx; 22-03-2010 at 16:56. |
#20 | |
MikeC
Quote:
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 55
| -SlicK, 2pac58, Aij29, ather`s, beezertart, BIGG addicted, BlackLeon, blobbyknobby, Brummy, Caffienated, crezz, crossedmike, Cruiser87, cupra-8v, cupraspark, dannyjames23, DPJ, EnGbudd, envycordoba, F2 Ed, g60bron, gr066y, gtikezz, HoopDub, Ibiza 09, ibiza power, ibiza@kev, ibizaboi, Ieuan-J, In The Shadows, jaydr128, jenk, JimmyT, Kai_1600, kyle18uk, leon540, m0rk, M1KEH, mattmk2, miscreant, Muttley, N3 CPRA, Oj 89, old 'uns, Pander, redtrev, samc, seatibizagti, skwaggles, splodge81, Steve C, suj, Tangerine_Dream, Trublu07, vngtx |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Car will only start facing downhill! Any ideas? | liza283 | Ibiza Mk2 | 16 | 08-09-2009 21:10 |
| car wont start!!! | gazcuprablk | Ibiza Mk3 | 6 | 12-11-2008 00:09 |
| car wont start | gazcuprablk | REVO Technik Tuning | 1 | 18-06-2008 00:55 |
| Car wont start | Johnsey | Ibiza Mk4 | 8 | 22-03-2008 18:02 |
| car wont start | holmesy55 | Ibiza Mk4 | 5 | 18-03-2008 10:34 |
