| Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only> |
Thread Tools | Rate Thread | Display Modes |
#1 |
Taking a break from JDM..
Decent grade 7 spark plugs cant find a definitive answer with the search
Hi all
going to change the spark plugs this weekend, as will all my cars that run more than stock boost i stick a colder grade plug in. I'm reading on here that alot of people use NGK BKR7E plugs which are coppers. Used these all the time on the MR2 turbo but just want to double double double check they are fine to use with the LCR. Failing that any other recommendations for grade 7 NGK plugs? have just read through the search results but cant find part numbers aside from Denso's (have had a bad experience in the past so wont use again.) cheers Si
#2 |
cooling is the key people
NGK BKR7E
these will do fine mate, just make sure they are gapped properly.
__________________
inovite cts18s,p-torque 238bhp,koni adjustable ssx,quaife lsd,rear arb,s3 upper/lower,fmic,jetex turbo back system,catch can,ttwishbone bushes,samco tip,apr r1dv,porsche 911 brembos,ds2500,falken452jetex cone.....
#3 |
They ok to use on a LC as well?
#4 |
yep... good plugs, id stay away from the iridium tipped plugs, they have been known to snap the tips off= poo pants time
__________________
#5 |
Thanks James
![]() just ordered some
#6 |
Hi just been looking at spark plugs on sparkplugs.co.uk and they do NGK BKR7E and BKR7E-11, which ones would be the best to go for?
#7 |
Jack-RIP my little Friend
got evidence of this or here say?
__________________
![]() BADGER 5 LTD: PERFORMANCE TUNING RACE PROVEN PRODUCTS & HONEST ADVICE: Contact:07976 800775, 01453 827936,Fax-0870 0561360 Bespoke Big Turbo conversions,DevilsOwn WMI,Forge,Ferodo,AP Racing Brakes,Custom Code,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compmotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more... http://www.badger-5.com email me at:bill@badger5.co.uk |
#8 |
LCR 225
yeah, i thought the iridium ones were supposed to be superior and longer life?
__________________
Leon Cupra R (BAM) - Forge Stage 1, 007p, Jetex Cone, Cruise Control, Boot Tray + 1 broken Splitter (thanks snow!) Readers Ride:http://www.seatcupra.net/forums/showthread.php?t=253679 |
#9 |
Leon 1.8T on steroids
Im using denso IK22 for about a year now - everything's fine
__________________
My beast - gone but not forgotten
#10 |
Senior Member
I've just ordered a bunch of NGK BKR7E(6097) from the UK and plan to gap them at 0.28
__________________
LCR 210, Forge; Black; TIP, Turbo Outlet Hose, 007P, Relocation kit, Race Intercooler. BF TBE 100 Cell, THS FR3 Mounts, -20mm H&R, SPEC clutch(575nm), SPEC SMF flywheel(9.25 lbs). Brembo GT 323mm(Red), Revo Stage2+Switch. Foam Panel Filter. |
#11 |
So the spark plug discussion continues lol I'll stick with my Original ones for the time being whatever they are lol
#12 |
did you not say something of the like bill?.....
__________________
#13 |
Banned
I have the NGK Iridium ones..... still working after 2 years. Gonna get copper before this race season as Ive been told copper has even better conductivity.
#14 |
Rubbing is Racing :-)
Bill's comments were more focused at Denso plugs rather than iridiums from memory..
__________________
Modded Platinum Grey LCR - Nurburgring BTG time: 8:36.8 http://www.seatcupra.net/forums/showthread.php?t=214599 |
#15 | |
3071
Quote:
And for mapped cars its should be 0.028" which is ~0.71mm. BKR7E's are one grade colder than standar so will be fine for any car really. Standard gap is .032"/0.8mm you can gap them down if you want or throw them in as they are. Change them at every oil change as theyre only about 12 quid delivered. Copper core plugs dont last as long as Ir or Pt plugs.
__________________
#16 |
used the BKR7E NGKs on the MR2 and they were fine, local motor parts shop does them for about £2 a plug iirc.
as said change with the oil and they will be fine. |
#17 |
AKA Shifty - Modded LCR
DO NGK do an 8grade plug for the LCR and does anyone use them?
ran them on my evo yet my LCR pretty much boosts to the same level as that did? |
#18 | |
Senior Member
Quote:
Just had them delivered (20 pcs), paid 1,82 £ each bought in the UK. Is it worth gapping them that extra 0.1mm? (Running REVO stage 2 a 1.25 bar)
__________________
#19 |
I was planning to run them at the standard gap unless its recommended otherwise??
#20 |
So does anyone know if there is a difference between the NGK BKR7E and the ones with -11 on the end on camskill.co.uk
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 85
| 8bit, adam cupra 20vt, ADAM_84, adja240986, adm013, Allan_84, aviaa25, Backdraft, CamPark, ChrisGTL, cuprastupot, Damoegan, DannyC87, deano82, dippy4000, Disco_Mikey, DJ-LIAMC, Dyscontinued, faz85, Fl@pper, FR-turbo, gingerben, Gravesie-363, GRD, greesha, GregLCR04, GREY 225, Gubien, Hairy, Hamzilla, harty190486, hooky, ianevans, ibizacupra, Imperial, Indy, jake, james walker, jamesypyk, jgy6000, joely, jonathanp, Jonny95 SXE, Jordan20vt, justin3779, karlw, Lambo69, LEE69, leon cupra r, Mark300zx, matylad, Mikey P, MrBen2k7, muks11, OEM+ 1.8T, OJleon, oldman, p77_macca, PhilW, psycho6285, Rarpuc, rix, Robbie C, robbob, Robertjwebb, rolandinho, rsmith, russman68, samster, sexynips, sgtcortez, sheffboy, sie77, Slimy, speedinsaxo, steve8582, tattybits, tt28, TubbyTwo, turbin, turbo009, vngtx, vwbassett, warren_cox, wayne lcr |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Which NGK spark plugs???? | GregLCR04 | Leon Mk1 | 2 | 01-07-2009 21:31 |
| Spark Plugs | Mario | Leon Mk1 | 7 | 01-07-2009 18:51 |
| Problem with spark plugs | blackdream | Ibiza Mk2 | 0 | 08-02-2009 19:49 |
| spark plugs? | cupra tda | Ibiza Mk3 | 3 | 26-03-2008 16:03 |
| Spark Plugs - How to | s5luf | Leon Mk1 | 2 | 18-02-2008 15:09 |
