RS Tuning
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk3
Ibiza Mk3 For 2000-2002 Specific Information.
Reply
Thread Tools Rate Thread Display Modes
Old 10-03-2010, 22:12   #1
Jordan20vt
Mk3 20VT
Jordan20vt's Avatar
Boost Pressure Problem (with logs)
Hi all,
Recently I have noticed my boost is only reaching 14 psi and then tailing off a couple of psi. Previously it would spike to around 21-22 and hold around 15psi. (boost guage)
There is no obvious boost leaks or split vac lines, and i have recently serviced th DV. Also there is an occasional bank 1 Lamda fault, but i've had the fault for years with no adverse effect on performance.
Car is running:
Modded airbox with GC filter
Laguna FMIC
Milltek Cat back
Revo Stage one
I've been out logging tonight,but don't really know how to read the data. Can someone have a look for me please Thankyou
Code:
Group A:	'002				Group B:	'020				Group C:	'114
	RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		Load	Load	Load	Load
TIME					TIME					TIME
STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF	STAMP	%	%	%	%
12.78	1440	85	10.66	23.5	13.18	0	0	0	0	12.38	118.8	117.9	80.5	1.2
14.07	1720	106.8	13.53	37.5	14.47	0	0	0	0	13.58	130.8	129.9	100.8	99.2
15.27	2120	136.8	17.22	59.25	15.67	0	0	0	0	14.87	145.1	144.8	124.8	99.2
16.47	2600	179.7	22.14	96.53	16.87	0	0	0	0	16.07	156.4	156.7	160.9	83.5
17.77	3200	172.9	22.14	108.58	18.17	0	0	0	0	17.37	163.9	162.7	175.9	76.5
19.08	3800	169.9	22.96	126.81	19.48	0	0	0	0	18.68	164.7	164.2	168.4	74.9
20.26	4240	165.4	23.37	130.94	20.66	0	0	0	0	19.86	163.9	162.7	168.4	75.7
21.46	4680	166.2	24.19	148.72	21.88	0	0	0	0	21.06	161.7	161.2	165.4	76.5
22.66	5040	164.7	24.19	159.67	23.08	0	0	0	0	22.26	157.9	158.2	165.4	78.4
24.07	5360	156.4	23.37	160.69	24.47	0	0	0	0	23.58	153.4	152.2	158.6	77.6
25.38	5640	148.9	22.55	160.36	25.77	0	0	0	0	24.97	148.9	147.8	148.9	76.9
26.68	5840	145.1	22.55	162.03	27.08	0	0	0	0	26.18	144.4	144.8	148.1	78.8
27.88	6080	141.4	22.55	160.36	28.28	0	0	0	0	27.46	138.3	137.3	142.9	80
29.08	6240	138.3	22.14	163.19	29.48	0	0	0	0	28.68	135.3	135.8	139.8	80
30.37	6480	133.8	21.73	164.33	30.77	0	0	0	0	29.88	132.3	131.3	136.1	80
31.57	6680	128.6	20.5	164.03	31.97	0	0	0	0	31.17	130.8	129.9	130.8	76.9
32.77	6920	124.8	20.09	165.47	33.17	0	0	0	0	32.36	130.8	129.9	126.3	75.3
Code:
10	March	2010	21:07:57
	1.8L R4/20VT SEA    0002
Group A:	'002				Group B:	'115				Group C:	'118
	RPM	Load	Inj. On Time	Mass Flow		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
TIME					TIME					TIME
STAMP	 /min	%	 ms	 g/s	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
10.89	1080	67.7	9.02	15.75	10	1480	12.8	1000	1040	10.49	1480	18	0	1050
12.3	1320	74.4	12.3	23.5	11.39	1160	56.4	1000	1070	11.9	1240	18	0	1060
13.59	1600	99.2	12.71	32.92	12.7	1400	87.2	1540	1110	13.19	1520	15	99.2	1200
14.89	2040	127.8	15.58	52.44	14.07	1760	106	1760	1340	14.49	1920	15	99.2	1430
16.09	2520	165.4	20.09	86.58	15.29	2160	139.1	1890	1670	15.69	2360	14	99.2	1810
17.29	3080	175.2	22.14	101.19	16.49	2720	181.2	2000	2200	16.89	2880	15	77.3	2230
18.49	3600	168.4	22.14	116.75	17.69	3240	170.7	1980	2090	18.09	3440	15	74.9	2060
19.79	4120	168.4	23.37	133.08	18.89	3760	168.4	1970	2010	19.29	3920	15	75.3	1990
21.08	4600	163.9	23.78	142.31	20.18	4280	164.7	1940	1980	20.58	4400	17	76.1	1950
22.39	5000	164.7	24.19	157.14	21.48	4720	163.9	1880	1910	21.99	4880	18	78	1880
23.58	5360	156.4	22.96	158.97	22.79	5120	163.2	1820	1850	23.19	5240	19	78.4	1860
24.78	5680	146.6	22.14	158.22	23.99	5440	151.9	1790	1820	24.38	5560	20	77.6	1780
26.09	6000	142.9	22.55	162.89	25.19	5760	146.6	1750	1750	25.59	5880	21	80	1730
27.5	6360	136.8	22.14	164.89	26.49	6120	142.1	1660	1690	27	6200	21	80.4	1670
28.79	6640	130.8	21.32	165.75	27.98	6440	135.3	1600	1650	28.39	6520	23	78.4	1650
29.99	6880	125.6	20.5	163.19	29.19	6720	128.6	1590	1620	29.59	6800	23	76.9	1630
31.18	7040	46.6	4.92	49.47	30.39	6960	123.3	1600	1590	30.79	7040	24	66.3	1580
__________________
2000 Imperial Blue Ibiza Cupra 20vt revo
___________________________________
2003 Black Maigic Ibiza 130TDI Sport revo
Jordan20vt is offline   Reply With Quote
Old 10-03-2010, 22:48   #2
Jordan20vt
Mk3 20VT
Jordan20vt's Avatar
Also I have tried using SPS to up the boost, but the higher i go the less it boosts! Currenty using HB4 setting on old SPS and Igntimig 5.
__________________
Old 11-03-2010, 12:34   #3
Jordan20vt
Mk3 20VT
Jordan20vt's Avatar
Can anybody help?
__________________
Old 11-03-2010, 21:03   #4
tarzan
cupra owner from norway
tarzan's Avatar
this is mine with k03 revo stage 2 on B9T6
Code:
'003				Group B:	'020				Group C:	'115
RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Absolute Pres.	Absolute Pres.
				TIME					TIME
 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	%	 mbar	 mbar
1680	11.58	6.7	29.3	0.4	0	0	0	0	0.8	1800	76.7	1250	1070
1920	39	100	12	1.7	0	0	0	0	2.1	2160	124.8	2000	1530
2320	65.03	100	11.3	2.9	0	0	0	0	3.3	2680	162.4	2190	2040
2880	104.28	100	6.8	4.19	0	0	0	0	4.59	3480	191.7	2300	2460
3680	136.14	100	6	5.49	0	0	0	0	5.89	4200	191.7	2290	2330
4400	154.39	100	6.8	6.69	0	0	0	0	7.09	4800	174.4	2080	2130
5000	160.36	100	6.8	7.9	0	0	0	0	8.3	5280	160.2	1930	1990
5440	159.39	100	6.8	9.2	0	0	0	0	9.69	5800	145.1	1800	1830
5920	160.06	100	10.5	10.49	0	0	0	0	10.89	6120	136.8	1730	1740
6240	161.17	100	12.8	11.69	0	0	0	0	12.09	6440	130.1	1620	1720
6280	0	3.5	20.3	12.89	0	0	0	0	13.29	5080	72.2	1010	1330
__________________
revo stage 2 sps3.n249 bypass forge oo7 dv.3inch decat simons catback.custom fmic fk koingsport coilovers
tarzan is offline   Reply With Quote
Old 11-03-2010, 21:05   #5
tarzan
tarzan's Avatar
but i got more gs with B6T6 had peak on 1.5bar
this log
Code:
	Group A:	'002				Group B:	'115				Group C:	 Not Running
	TIME					TIME					TIME
Marker	STAMP	 /min	%	 ms	 g/s	STAMP	 /min	%	 mbar	 mbar	STAMP
	0.99	1440	27.1	4.92	13.22	0.59	1400	16.5	1020	1050
	1.79	1560	88	11.48	29.83	1.39	1480	77.4	1640	1050
	2.59	1800	102.3	11.07	37.86	2.19	1680	95.5	1720	1230
	3.39	2080	126.3	13.53	55.72	2.99	1920	112	1830	1440
	4.19	2400	151.1	16.81	74.42	3.79	2200	139.1	1960	1730
	4.99	2800	178.9	20.5	101	4.59	2600	166.2	2070	2080
	5.79	3320	191.7	25.42	136.97	5.39	3040	191.7	2110	2450
	6.68	3880	191.7	25.42	147.11	6.28	3640	191.7	2120	2520
	7.59	4400	188	25.42	157	7.08	4160	191.7	2090	2390
	8.39	4840	177.4	24.6	162.53	7.99	4640	181.2	2000	2230
	9.19	5120	168.4	23.78	164.17	8.79	5000	174.4	1900	2050
	9.99	5440	157.1	22.55	161.67	9.59	5280	162.4	1860	1990
	10.79	5720	150.4	22.14	162.03	10.39	5560	153.4	1820	1930
don`t no why i got more gs and more boost with B6T6 then B9T6
__________________
Old 11-03-2010, 22:48   #6
Jordan20vt
Mk3 20VT
Jordan20vt's Avatar
Been out in mine tonight and upped the boost and timing but acheived less boost.
The problem is it's just lost that initial spike on spool up, it's still as fast up the revs, the map just feels really smooth and progressive. I would't have a problem with it if thats how it was to start with, but it wasn't so something must be wrong.
Advancing the timing seems to have no effect and i'm runnng 99 ron, advancing the boost makes it acheive less and i have no problems with intake temps.
The logs don't really show the problem. Think it's one of those problems which could be anything and is probably something simple.
I have an N75J staring at me from across the room I'll fit that at the weekend.
__________________
Old 11-03-2010, 22:55   #7
Jordan20vt
Mk3 20VT
Jordan20vt's Avatar
Quote:
this log
Code:
	TIME					TIME					TIME
Intrestin comparing data, looks as though yours is spiking alot higher than mine and holding bost alot longer. But yours is stage 2 I suppose, Is there anything you see wrong with my logs?
__________________
Old 12-03-2010, 19:19   #8
tarzan
tarzan's Avatar
i use a hallman boostcontroler instead off the n75.the revo stage 1 is more agressive i heard
__________________
Old 14-03-2010, 22:48   #9
Jordan20vt
Mk3 20VT
Jordan20vt's Avatar
n75 changed all fixed goes like stink spiking 23psi!!!
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 59
-pseudonymous-, Alex Cupra, alexbradford, AP2000, aterro, basil, Benson, Berg, Big_daddy, Bowen, ChrisGTL, cupra/chris, cupra20vt240, CupraElliott, cupraR59, Damoegan, dandan, Danny_B, Edz Cupra, EZ Tutty, footlong, fourtwofive, Glenn, harty190486, ibizacupra, ibiza_c11pra, jake, JB!, Jordan20vt, level_lewis, lm_gauci, MrNorma, ndbrgr, Noam, p34ch3y, Pingu101, Prebs, psycho6285, R4cup, Ravey_Cupra, rhysox, Robbie C, RobVT, ross p, rover75mad, rst2t, Samoose, Sharky_82, skirlaugh1, Stoker20VT, sxboy200, Tallpaul, tarzan, tom w, tommy2008cupra, tooshy, tstrahonja, venner, WASPY
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
boost problem bainsycupra Leon Mk1 1 13-02-2010 13:36
what boost pressure should i be getting? dave_ph Leon Mk1 18 07-12-2009 10:10
Boost pressure on stage 1 map ? please robdf2 Leon Mk2 5 12-03-2009 18:53
Boost pressure sensor G12MO X Badger5 4 30-12-2007 21:29
Leon FR TDI boost pressure? pr0ton Leon Mk2 1 03-12-2007 18:30
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
