| VAG-COM & Diagnostics VAG-COM is a diagnostics program that allows your PC to talk to your ECU - All VAG-COM / 1551 questions to be posted here |
Thread Tools | Rate Thread | Display Modes |
#1 |
Hello,
I have never really logged my fuelling much but as im tweaking my setup with unisettings I thought I would take some logs of block 031. My voltages are all over the place to start with - on idle i see .750, then all of a sudden 0.040 volts and it keeps fluctuating between 0.04 - 0.80! ALso they dont match my AEM a/f gauge at all, on my gauge my fuelling looks normal , 14's idle and part throttle and on boost 11-12's but only after 4-4.5K when I actually make any boost! (gt3076r). My question is, could these figures be scalled in any way with my map like they would with the MAF, or Tb? Should I disregard block 031 and go by my AEM gauge? Both have brand new sensors on them! Also my MAF maxxes out @317.08 - should I look at getting that sorted or would he ecu just have its own parameters to run by after that like with the standard map sensor after it see's more than 1.5bar boost? as you can see on the 2nd log, even when im cruising block 031 shows some crazy fuelling but on my aem it seems fine - also I have no faultcodes regarding fuelling ever. ALso maybe someone can chime in on my timing numbers - not great I guess! Hope someone can help! This is my last try with the ME7.5 or im going stand-alone! Thanks Code:
Group A: '003 Group B: '031 Group C: '020 RPM Mass Flow Load Ign. Timing Voltage Voltage A/F ratio A/F ratio Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME TIME TIME STAMP /min g/s % °ATDC STAMP V V STAMP °KW °KW °KW °KW 0.28 2640 5.36 2 13.5 0.58 0 0 0 0 0 0 0 0 0 1.18 2600 18 8.2 36 1.48 0.065 0.095 0.9555 1.3965 0.88 0 0 0 0 2.08 2640 38.83 100 34.5 2.38 0.065 0.08 0.9555 1.176 1.78 0 0 0 0 2.98 2760 46.58 100 34.5 3.28 0.79 0.775 11.613 11.3925 2.68 0 0 0 0 3.88 2920 51.89 100 33.8 4.18 0.765 0.725 11.2455 10.6575 3.58 0 0 0 0 4.78 3080 55.89 100 33 5.08 0.735 0.725 10.8045 10.6575 4.48 0 0 0 0 5.68 3280 65.17 100 33 5.98 0.72 0.73 10.584 10.731 5.38 0 0 0 0 6.58 3440 72.44 100 30.8 6.88 0.71 0.71 10.437 10.437 6.28 0 0 0 0 7.49 3680 88.44 100 28.5 7.78 0.785 0.765 11.5395 11.2455 7.18 0 0 0 0 8.39 4000 119.31 99.6 27 8.68 0.845 0.825 12.4215 12.1275 8.09 0 0 0 0 9.28 4400 203.03 99.6 19.5 9.59 0.83 0.81 12.201 11.907 8.98 0 0 0 0 10.18 5040 243.94 100 16.5 10.49 0.845 0.815 12.4215 11.9805 9.89 3 3 3 3 11.09 5520 288.89 99.6 15 11.38 0.81 0.79 11.907 11.613 10.79 3 3 3 3 11.99 5960 298.75 100 14.3 12.29 0.85 0.82 12.495 12.054 11.69 3 3 3 3 12.89 6440 317.08 100 15.8 13.19 0.825 0.8 12.1275 11.76 12.59 3 3 3 2.3 Code:
RPM Load Inj. On Time Mass Flow Voltage Voltage A/F ratio A/F ratio Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME TIME TIME STAMP /min % ms g/s STAMP V V STAMP °KW °KW °KW °KW 0.29 3360 51.1 2.46 32.42 0.59 0.07 0.09 1.029 1.323 0 0 0 0 0 1.2 3400 49.6 2.87 32.75 1.49 0.795 0.77 11.6865 11.319 0.9 0 0 0 0 2.09 3440 48.9 2.46 33.31 2.39 0.07 0.155 1.029 2.2785 1.8 0 0 0 0 2.99 3520 87.2 4.51 60.14 3.29 0.745 0.71 10.9515 10.437 2.69 0 0 0 0 3.9 3680 108.3 5.33 77.17 4.19 0.765 0.745 11.2455 10.9515 3.6 0 0 0 0 4.8 3960 137.6 7.79 107.69 5.09 0.85 0.82 12.495 12.054 4.49 0 0 0 0 5.69 4280 191.7 11.07 165.03 5.99 0.86 0.84 12.642 12.348 5.4 0 0 0 0 6.6 4840 191.7 13.12 224.25 6.9 0.845 0.82 12.4215 12.054 6.3 3 3 0 0 7.49 5280 191.7 13.12 272.92 7.8 0.81 0.79 11.907 11.613 7.2 3 3 0 3 8.4 5800 191.7 13.53 297.67 8.7 0.855 0.82 12.5685 12.054 8.1 6 3 3 3 9.3 6240 191.7 13.53 317.08 9.6 0.83 0.8 12.201 11.76 9 6 3 3 3 10.2 6720 191.7 13.94 317.08 10.5 0 0 0 0 9.9 6 1.5 3 3 20.98 3240 11.3 0 7.36 21.28 0 0.01 0 0.147 20.68 0 0 0 0 21.88 3200 9 0 6.39 22.18 0 0.005 0 0.0735 21.58 0 0 0 0 22.78 3160 11.3 0 6.69 23.08 0 0.01 0 0.147 22.48 0 0 0 0 23.68 3080 12.8 0 7.08 23.98 0 0.01 0 0.147 23.38 0 0 0 0 24.58 3040 11.3 1.23 6.67 24.88 0.835 0.825 12.2745 12.1275 24.28 0 0 0 0 25.48 3120 84.2 4.51 51.61 25.78 0.785 0.78 11.5395 11.466 25.18 4.5 3 1.5 0.8 26.38 3240 97 4.92 61.86 26.68 0.745 0.735 10.9515 10.8045 26.08 4.5 3 0.8 0.8 27.28 3360 105.3 5.33 69.31 27.58 0.695 0.695 10.2165 10.2165 26.98 3.8 3 0 0.8 28.18 3520 93.2 4.1 52.31 28.48 0.035 0.05 0.5145 0.735 27.88 2.3 3 0 0.8 29.08 3480 10.5 0 6.67 29.38 0.01 0.025 0.147 0.3675 28.78 0 0 0 0 29.99 3560 91.7 4.92 62.67 30.28 0.785 0.775 11.5395 11.3925 29.68 0 0 0 0 30.89 3680 113.5 5.74 82.56 31.19 0.72 0.725 10.584 10.6575 30.59 0 0 0 0 31.78 3840 72.9 0 43.25 32.08 0.085 0.09 1.2495 1.323 31.49 0 0 0 0 32.68 3680 11.3 0 9.14 32.98 0 0.01 0 0.147 32.39 0 0 0 0 33.57 3440 12 0 8.56 33.87 0 0.01 0 0.147 33.28 0 0 0 0 34.47 3240 10.5 0 6.06 34.77 0 0.005 0 0.0735 34.17 0 0 0 0 35.37 3160 12 0 7.31 35.67 0 0.01 0 0.147 35.07 0 0 0 0 36.27 3080 9.8 0 6.81 36.57 0 0.01 0 0.147 35.97 0 0 0 0 37.17 3040 11.3 0 6.28 37.47 0 0.01 0 0.147 36.87 0 0 0 0 38.07 2960 9.8 0 4.89 38.37 0 0.015 0 0.2205 37.77 0 0 0 0 38.97 2960 78.2 4.1 46.17 39.28 0.41 0.635 6.027 9.3345 38.67 0 0 0 0 39.87 3040 86.5 4.51 50.58 40.18 0.785 0.775 11.5395 11.3925 39.57 0 0 0 0 40.77 3080 82 4.1 49 41.08 0.56 0.655 8.232 9.6285 40.47 0 0 0 0 41.68 3160 74.4 3.69 44.86 41.98 0.75 0.745 11.025 10.9515 41.38 0 0 0 0 42.58 3200 73.7 3.69 46.42 42.88 0.725 0.71 10.6575 10.437 42.28 0 0 0 0 43.47 3240 73.7 3.69 46.75 43.77 0.285 0.41 4.1895 6.027 43.18 0 0 0 0 44.37 3320 95.5 4.92 60.47 44.68 0.755 0.74 11.0985 10.878 44.08 0 0 0 0
__________________
#2 |
3071
Stupid question but is it a wideband ecu?
__________________
#3 |
Hi mate, thanks for replying!
Actually it isnt wideband - I always thought it was but its the 4wire one - my harness and ecu is from same car as yours, ayp 06a906032aa ecu I think!
__________________
#4 |
Posting my car
I was going to ask if it was a wideband.
031 is no use to you.
__________________
Dave ...................... dpj@seatcupra.net![]() ![]() ![]() ...............................................................................Alhambra Stylance 140Tdi...KiwiCupra 8v...387.7bhp Leon Cupra GT
#5 |
Oh, thanks I had this feeling but wasnt sure! Can I use block 033?
My 032 fuel trims are 8.7% and -25%. 100% I dont have a leak - pressure tested to 1.8BAR. thanks alot.
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 27
| -pseudonymous-, BeartheBruce, Bishbash25, Damoegan, Davidsr, densil, Don Eason, DPJ, gazR, Glenn, gulzar, Hartosh1, harty190486, jake, james walker, Jordan20vt, markm, ne11er, phatchoonz1, PhilW, rsmith, s30tt, str8ballin, thomasa, truCido, wild willy, Wilko |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| help me plz poor logs | harty190486 | VAG-COM & Diagnostics | 10 | 22-02-2010 12:55 |
| How big is to big for a turbo? | Andrew@ALD | Big Turbo Discussion | 17 | 18-10-2009 05:12 |
| Who has Big Turbo on Leon? | agentme | Leon Mk2 | 7 | 08-02-2009 13:24 |
| 04 big turbo conversion ... | r8byb | JBS Autodesigns | 12 | 11-03-2008 19:12 |
| Cheapest Big turbo conversion.. | r8byb | Ibiza Mk3 | 38 | 22-02-2008 23:54 |
