Badger5
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 16-03-2010, 20:06   #1
swoosh225
Swoosh
swoosh225's Avatar
Best panel air filter for LCR
Hi people i am thinking of removing my BMC cda filter.Have read they are restrictive.Whats the best panel filter out there for the money ,Ive already smoothed my air box in advance.
Thanks in advance.
swoosh225 is offline   Reply With Quote
Old 16-03-2010, 20:12   #2
wilky87
wilky87's Avatar
i have smoothed and drilled my airbox and was thinking of putting a pipercross panel filter in, but i may be more interested in buying your CDA apparently the best bet is a drilled smoothed airbox with green cotton filter and cold ait feed
__________________
LCRWith magic inside
wilky87 is offline   Reply With Quote
Old 16-03-2010, 20:12   #3
wild willy
wild willy's Avatar
I'd say Jetex panel filter, But a new paper filter is even harder to beat.
__________________
K04 Hybrid Turbo with toys
308 bhp / 292 ft/lbs
wild willy is offline   Reply With Quote
Old 16-03-2010, 20:17   #4
swoosh225
Swoosh
swoosh225's Avatar
Quote:
Ill let you know what i decide in the end mate. I used to have a nuespeed filter and heatshield on it but change to the CDA noticed a differance with the change then.Are the CDA's really not good for them?
Old 16-03-2010, 20:20   #5
wilky87
wilky87's Avatar
tbh i dont know, i cant see anything wrong with a cda, i think its all down to personal preferance, but dont hold me on that
__________________
Old 16-03-2010, 20:25   #6
robertj
weight is the enemy
robertj's Avatar
I've had a K&N panel filter on mine for 2 years now. It gets cleaned at service time (at Jabba) and I'm still on the cars original MAF so no oiling up issues.
Brian at Jabba recons a panel filter is as much as you need even when remapped. Or so he told me before they put a custom map on mine.
robertj is offline   Reply With Quote
Old 16-03-2010, 20:29   #7
swoosh225
Swoosh
swoosh225's Avatar
Might fit it and try its not a big job really
Old 16-03-2010, 20:42   #8
D.K
LCR 225
D.K's Avatar
I'v got a PiperX in mine.
Personally I think a bigger cold air feed pipe is key to using the OE airbox
__________________
Mapped & Maintained By AmD Essex 274.2 BHP-295.2 Lb/ft
D.K's LCR, Project Carbon http://www.seatcupra.net/forums/showthread.php?t=169036
D.K is offline   Reply With Quote
Old 16-03-2010, 21:03   #9
swoosh225
Swoosh
swoosh225's Avatar
Ive got a huge air feed upto the bmc cda thats fitted so would just use that i suppose ive removed the original intercoolers so it sit just behind the fog lamp on the n/s.Ill buy a filter and give it a whirl,
Old 16-03-2010, 21:13   #10
Mikey P
LCR 225
JBS are fitting green cotton panel filters as part of a package deal with phase 1 remaps so they must be pretty good.
having mine done in a few weeks so will let you know
Mikey P is offline   Reply With Quote
Old 16-03-2010, 21:14   #11
swoosh225
Swoosh
swoosh225's Avatar
Ok mate.
Old 16-03-2010, 21:30   #12
RS6
RS6's Avatar
after doing some searching on here i heard the green cotton pannel filter was the best filter to fit people seem to have good rr results
RS6 is offline   Reply With Quote
Old 16-03-2010, 21:37   #13
Mikey P
LCR 225
Looks like im in for a good journey home from JBS then lol
Old 16-03-2010, 21:43   #14
swoosh225
Swoosh
swoosh225's Avatar
Itll be the same as a S3 one wont it?
ive found one on fleebay
Old 16-03-2010, 21:46   #15
Mikey P
LCR 225
not sure mate,you could go on vw spares and compare part numbers i supose
Old 03-04-2010, 19:33   #16
Mikey P
LCR 225
Did you fit one in the end swoosh225? had min fitted today, ive only smoothed the airbox and you can just about hear the DV, im going to try it for a few weeks then try an open cone with heat sheild and see the differance
Old 03-04-2010, 19:40   #17
swoosh225
Swoosh
swoosh225's Avatar
I didn't thought id leave the BMC one on it does its job fine enough.Ive smoothed the airbox already but my mates borrowed it for his S3
__________________
Old 03-04-2010, 19:46   #18
Mikey P
LCR 225
fair enough,no point fixin somthing that aint broke
Old 04-04-2010, 16:09   #19
wayne lcr
my car does me head in
wayne lcr's Avatar
i run a green cotton in me oem airbox sounds good but like willy said dont notice any diff from the new paper 1
__________________
if in doult get your lcr out
wayne lcr is offline   Reply With Quote
Old 04-04-2010, 19:57   #20
Gubien
Senior Member
I've logged 206 g/s with my pipercross panel filter, so it's able to flow :o)
__________________
LCR 210, Forge; Black; TIP, Turbo Outlet Hose, 007P, Relocation kit, Race Intercooler. BF TBE 100 Cell, THS FR3 Mounts, -20mm H&R, SPEC clutch(575nm), SPEC SMF flywheel(9.25 lbs). Brembo GT 323mm(Red), Revo Stage2+Switch. Foam Panel Filter.
Gubien is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 124
8bit, Aber1, adam cupra 20vt, AJ-V5, AlanUK, albevan, Allan_84, andyringo, andytaylor1980, armyboi01, Bakes100, Big Ejit, Bigal240576, bigsteve_FR, Bishbash25, brad1, calum001, Calyx, CamPark, carew, ChrisGTL, chriz1, collins, Cupra-cal, cupradan, CupradanM, CupraRcleanR, cupratdi53, cwharreld, D.K, Dannym, Dark Fox, Dione J, DJ-LIAMC, electricrock102, Fergal84, G223, gary87, gazR, gemini, gingerben, godber225r, godzuki, Gravesie-363, GRD, GregLCR04, Gubien, h7 cya, hamps_w, harty190486, hunggar, ianevans, Ibiza Evo 2, ikhlaq206, Irie, jamandspoon81, james walker, Jamie225, jamieread, JamJay, JaWalks, jcullen88, jds, jgy6000, jms_cupra, john.waterman, Johnny_Mac_LCR, Judgejim21, Keano, kez, King kong, lbr66cov, LCRglen, leoncupra666, Leoncuprarfan, luke_h, markbrum, markgb, mikebrennan, Mikey P, moojii, MrBen2k7, mrplebby, Mully, Neal, noodle, Paul B2010, Paul D, paul6316, PHIL LCR, rallynut, robbob, robertj, rolandinho, RS6, S3 AKR, s3tle, SalSheikh, sambryant, shaun., shaunymac, sie77, skullmunki, smudge2011, squirrelater, Steve Hignett, ste_v, stubbsy, swoosh225, tedvagas, ThackersLCR, The Terminator, tim1547, Tpot, UFO Yellow, unkle funkle, Valhalla, vwbassett, wayne lcr, WayOnHigh, wild willy, wilky87, Wolvotim, Yatesey8527
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
K&N 57i induction Kit or K&N Panel filter????? thekiddy Leon Mk1 17 24-02-2010 16:32
Green panel filter for cupra r rusty82 Leon Mk1 2 04-06-2008 11:14
Air filter 1.4 DAB question qwert Ibiza Mk4 13 17-01-2008 00:15
K&N panel air filter bluenose Ibiza Mk2 5 03-09-2007 23:30
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
