| Badger5 Badger5 Ltd - Performance Tuning - Race Proven Products & Honest Advise....Forge,Ferodo,AP,Custom Code,REVO,H&R,Eibach,Vibratechnik,SPEC,Compmotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more... |
Thread Tools | Rate Thread | Display Modes |
#1 |
Power by Aptamil Stage 3
Brake bits, advice & prices !
Hi Bill
As per my other thread, I'm in need of some fronts discs & pads for the Passat. It's a 2002 model with 312mm discs (5x112) A few questions if I may... 1) I see you do the 8-groove discs for £159+vat - do these fit the 112mm PCD of the Passat ? And are they decent quality blanks that'll withstand warping ? 2) I presume the DS2500s are £135+vat ? 3) Can you supply the DS3000s, if so how much ? 4) Is the stone-cold performance of the DS3000 at least as good as OE ? If i'd been cruising in sub-zero winter temps for some distance without using them, would they bite quickly when needed ? 5) How much more aggressive on disks are the DS3000s, and how much of a mess of my alloys would they make ? 6) Any idea how much fluid I'd be looking at for a fluid change ? 7) What sort of turnaround time on the disks & pads ? Cheers
__________________
#2 | |
Jack-RIP my little Friend
Quote:
A few questions if I may... 1) I see you do the 8-groove discs for £159+vat - do these fit the 112mm PCD of the Passat ? And are they decent quality blanks that'll withstand warping ? >>No the 312's I advertise are for 5x100 fitment. I can do others but they are not std 2) I presume the DS2500s are £135+vat ? >> Depends on the caliper.. £135 is for LC 312mm caliper 3) Can you supply the DS3000s, if so how much ? >>Yes, depending on caliper, if 312mm calipers yes, they are another £19 4) Is the stone-cold performance of the DS3000 at least as good as OE ? If i'd been cruising in sub-zero winter temps for some distance without using them, would they bite quickly when needed ? >>DS3000 have better bite across the temp range over OE pads 5) How much more aggressive on disks are the DS3000s, and how much of a mess of my alloys would they make ? >> They are a race pad... but I use them personally as they have been disk friendly compared to every other pad I have personally tried. 6) Any idea how much fluid I'd be looking at for a fluid change ? >> between 2-3 bottles of Motul RBF600 fluid (500ml bottles) 7) What sort of turnaround time on the disks & pads ? >> Depends on the disk you want.. you say Passat? Machining to order need to allow a weeks turn round. regards bill
__________________
![]() BADGER 5 LTD: PERFORMANCE TUNING RACE PROVEN PRODUCTS & HONEST ADVICE: Contact:07976 800775, 01453 827936,Fax-0870 0561360 Bespoke Big Turbo conversions,DevilsOwn WMI,Forge,Ferodo,AP Racing Brakes,Custom Code,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compmotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more... http://www.badger-5.com email me at:bill@badger5.co.uk |
#3 |
Thanks Bill - are the 5x112 variants of the 312mm 8-groove disk the same price as the 5x100s ?
__________________
#4 |
what car is this for? model and year please
disk prices vary Presuming: passat 2.0 my2000-2005 = £107.25/pair for plain disks Grooved version (8 or eliptical) are £175/pair prices would be plus vat & delivery regards
__________________
![]() BADGER 5 LTD: PERFORMANCE TUNING RACE PROVEN PRODUCTS & HONEST ADVICE: Contact:07976 800775, 01453 827936,Fax-0870 0561360 Bespoke Big Turbo conversions,DevilsOwn WMI,Forge,Ferodo,AP Racing Brakes,Custom Code,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compmotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more... http://www.badger-5.com email me at:bill@badger5.co.uk Last edited by ibizacupra; 17-03-2010 at 11:46. |
#5 |
Sorry - it's a 2002 Passat TDI 130 Sport Estate.
It's got the original calipers, just with the carriers to take 312mm discs instead of the original 288s (the 312s were standard on some Passats anyway).
__________________
Last edited by muddyboots; 17-03-2010 at 11:50. Reason: I meant carriers, not spacers.... |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 32
| aaronthefox, AlexGSi2000, andyj, bertrum, bristolsparks, butch20vt, c-mac, cav, Coolbefore, cornelius, Deejay, durbzy, Gaz-04, Glenn, greencupra, Hartosh1, ibizacupra, ikhlaq206, John-Cupra_TDI, M1KEH, miscreant, montana83, muddyboots, neil, NeilW, phil_m, Prebs, Random1989, redcupraboy, richieroo, Sean01, tufftybloke |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Brake switch change - please help !! | monkey73 | Problem Issues Q&A | 5 | 28-01-2009 12:18 |
| brake advice following return to dealer | chris285 | Leon Mk1 | 5 | 05-01-2009 15:15 |
| brake pad prices???? | 51cordoba | Cordoba | 3 | 19-01-2008 14:27 |
| Brake discs advice needed | Big_daddy | Leon Mk1 | 19 | 12-12-2007 20:49 |
| discs and pads online? | WeeJase | Ibiza | 9 | 05-02-2003 22:09 |
