| VAG-COM & Diagnostics VAG-COM is a diagnostics program that allows your PC to talk to your ECU - All VAG-COM / 1551 questions to be posted here |
Thread Tools | Rate Thread | Display Modes |
#1 |
Newbie
log help please
hi all,
would like some of you guys to take a look at some logs i did today. bare in mind i only have the download version of vag com so cant get all the blocks yet. but here it goes first one i did this morning, 3rd gear Code:
Friday 19 March 2010 08:14:15 06A 906 032 MJ 1.8L R4/5VT 0003 Group A: '002 Group B: '020 Idle speed Engine load Inj. period Air mass in Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME 700-820 rpm 15-25% 2.0 - 4.0 ms 2.0-4.5 g/s TIME Marker STAMP /min % ms g/s STAMP CF CF CF CF 0.35 2160 12.8 1.7 5.53 0 0 0 0 0 1.15 2200 12.8 1.7 5.56 0.75 0 0 0 0 1.97 2200 12.8 1.7 5.61 1.57 0 0 0 0 2.86 2240 12.8 1.36 5.67 2.37 0 0 0 0 3.68 2360 82 9.86 42.36 3.26 0 0 0 0 4.58 2800 133.8 14.62 72.69 4.18 0 0 0 0 5.58 3360 133.1 15.3 86.06 5.09 0 0 0 0 6.38 3840 125.6 14.28 93.89 5.98 0 0 0 0 7.31 4320 127.8 14.62 105.75 6.8 0 0 0 3 8.09 4720 130.1 15.3 117.22 7.69 0 0 0 3 8.91 5120 130.1 14.96 128.42 8.51 0 3 3 3 9.92 5600 126.3 15.3 137.64 9.42 0 3 3 2.3 10.72 5960 124.8 15.64 143.44 10.32 0 6 3 2.3 11.53 6280 121.1 15.98 145.17 11.13 0 6 2.3 4.5 12.43 6320 11.3 1.36 15.56 12.03 0 5.3 2.3 4.5 13.25 5440 11.3 0 10.39 12.83 0 0 0 0 14.13 4040 12.8 0 7.97 13.73 0 0 0 0 14.94 3000 12.8 0 6.17 14.54 0 0 0 0 15.74 2080 13.5 0 5.25 15.34 0 0 0 0 16.54 1240 10.5 1.36 3.22 16.14 0 0 0 0 17.36 920 18 2.72 3.08 16.94 0 0 0 0 18.16 720 24.8 3.4 3.14 17.76 0 0 0 0 18.96 840 23.3 2.38 3.17 18.56 0 0 0 0 19.77 800 19.5 2.04 2.61 19.36 0 0 0 0 Code:
Friday 19 March 2010 21:25:38 06A 906 032 MJ 1.8L R4/5VT 0003 Group A: '003 Group B: '020 Group C: Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME TIME Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF STAMP 0.01 1800 6.92 6.3 21.8 0.36 0 0 0 0 0.87 1.37 1800 9.58 7.8 20.3 1.77 0 0 0 0 2.17 2.57 1840 10.19 8.2 20.3 2.98 0 0 0 0 3.38 3.78 2000 30.06 24.7 18 4.18 0 0 0 0 4.58 5.09 2480 66.94 100 9.8 5.49 0 3 3 0 5.89 6.39 3120 75.94 100 13.5 6.81 0 2.3 2.3 0 7.3 7.7 3720 90.58 100 18 8.12 0 2.3 2.3 3 8.52 8.92 4240 101.28 100 21.8 9.32 0 1.5 0.8 2.3 9.72 10.13 4720 116.44 100 21 10.52 0 4.5 6 7.5 10.93 11.43 5240 128.25 100 15 11.83 3 4.5 6 7.5 12.24 12.74 5720 136.94 100 13.5 13.14 3 3.8 5.3 6.8 13.54 13.96 6080 145.33 100 21 14.36 0 0 0 0 14.76 15.25 4840 117.22 98.4 15 15.65 2.3 3 4.5 6 16.07 16.47 5040 122.11 100 19.5 16.95 1.5 3 4.5 6 17.36 17.76 5120 15.89 4.7 31.5 18.16 0 0 0 0 18.58 19.06 4760 8.89 7.5 4.5 19.47 0 0 0 0 19.87 20.27 4360 9.08 7.8 3 20.77 0 0 0 0 21.19 21.59 3880 9.14 7.8 2.3 22.08 0 0 0 0 22.48 22.88 3320 7.78 7.1 1.5 23.3 0 0 0 0 23.7 24.1 3080 7.25 6.7 1.5 24.5 0 0 0 0 24.9 25.3 2960 7.42 6.7 0.8 25.7 0 0 0 0 26.11 Code:
Friday 19 March 2010 21:27:02 06A 906 032 MJ 1.8L R4/5VT 0003 Group A: '003 Group B: '020 Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF 0.5 1760 16.19 11.8 18.8 0.9 0 0 0 0 1.9 1840 28.39 22.4 14.3 2.3 0 1.5 3 6.8 3.12 2040 45.78 100 11.3 3.62 0 3.8 0 5.3 4.42 2320 58.67 100 4.5 4.82 0 3.8 3 6 5.73 2640 63.39 100 13.5 6.13 0 3 3 7.5 6.93 2920 70.19 100 13.5 7.34 0 3 2.3 7.5 8.14 3200 79.47 100 15.8 8.56 0 5.3 2.3 7.5 9.46 3520 83.64 100 16.5 9.86 0 4.5 1.5 7.5 10.77 3760 91.69 100 14.3 11.26 0 4.5 4.5 6.8 12.17 4040 98.89 100 14.3 12.56 3 3.8 3.8 8.3 13.37 4080 12.94 5.5 3.8 13.79 0 0 0 0 14.67 3680 6.97 6.3 2.3 15.09 0 0 0 0 15.98 3240 7.08 6.7 1.5 16.49 0 0 0 0 17.39 3040 6.53 6.3 1.5 17.79 0 0 0 0 THANKS ALL WHO CAN HELP!!! Last edited by s30tt; 19-03-2010 at 22:04. |
#2 |
cooling is the key people
you need to log in 3rd, ideally 4th from 2500 to the redline, 6500 to get an accurate reading without the need to change gear mate
also what car you have may help out a bit
__________________
inovite cts18s,p-torque 238bhp,koni adjustable ssx,quaife lsd,rear arb,s3 upper/lower,fmic,jetex turbo back system,catch can,ttwishbone bushes,samco tip,apr r1dv,porsche 911 brembos,ds2500,falken452jetex cone.....
#3 |
Newbie
the top 2 logs are 3rd gear upto the limiter. just that the 2nd log i change to 4th once i get to the limiter.
the 3rd log was just taking readings. the car is a leon cupra. totally standard |
#4 |
maf looks fine, some highish timing pull there, shouldnt be any on standard map.. id be guessing timing pull from running smic and inlet temps getting high..
what fuel do you use, 95 ron will cause some timing pull aswell not alot else to see from them logs, on shareware afaik you cant log boost, try logging 032 for fuelling
__________________
#5 |
Newbie
yeh its abit crap i got the downloadversion, should really pull y hand out of my pocket.
yeh 95 ron fuel iuse, i thought its not mapped so 95 shud be ok. does have some hesitation or some kind of surge at low revs tho, also wen cold. this could be the CF's couldnt it? |
#6 |
95 ron could and probably is causing timing pull, cupra is designed to run optimum on 98ron and above mate, ecu will be retarding timing on 95ron.
run some vpower or 99ron through it for a tank or 2 then relog those cf logs and see the difference hesitation could also be caused by running 95 ron.
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 23
| BeartheBruce, billyhas, ChrisGTL, Davidsr, drance, F2 Ed, gazR, Gubien, gulzar, hamavemike, harty190486, jake, james walker, m0rk, markm, ne11er, ross p, rsmith, s30tt, ScoobyJawa, truCido, turbin, vroomtshh |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| What to log in VAGcom? | Gooner_Mike | Ibiza Mk4 | 2 | 27-02-2010 11:13 |
| Please help me to interpret this log. (Again) | J0N | VAG-COM & Diagnostics | 12 | 16-11-2009 11:52 |
| MAF Log | keany19 | Leon Mk1 | 12 | 24-09-2009 17:10 |
| Log book for my Leon | kineticz | Leon Mk1 | 5 | 16-09-2008 08:57 |
| VAG COM log files | robdf2 | VAG-COM & Diagnostics | 3 | 12-05-2008 13:23 |
