Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 26-04-2010, 20:21   #1
Dyscontinued
Senior Member
Dyscontinued has 10 points
Tools to replace LCR Front Brake Pads
I've read the fitting guide and searched (been here long enough to know to do that ) the forum but I can't find any info on what tools I need to change the brake pads on my LCR Brembos.
Also, when I did my Cupra brakes I bought a piston rewind tool, will this work on the brembos? Is it needed? I'm guessing not as the the caliper doesn't get removed so the disc would be in the way.
Will be doing this tomorrow and then booking MOT for Wednesday and Tax day after.
God knows how people manage to spend £1000's on random mods! Maybe cos I have a house I dunno.
__________________
2004 Nissan X-Trail
SOLD 2005 Seat Leon Cupra R in Black- APR Stage 1 remap, Recaros and factory fit SatNav
RIP 2004 Seat Leon Cupra TDI in Black Magic - Neuspeed ARBs - 312mm Brakes (grooved)
Dyscontinued is offline   Reply With Quote
Old 26-04-2010, 20:30   #2
wayne lcr
bored of it now
wayne lcr's Avatar
wayne lcr has 10 points
iam sure its 2 torx bolts behind the caliper .think they are either t 40 or t45 then you need a thin punch to knock the pins out the front that holds the pad retainer in and i think i used a pair of mole grips or stilsens to easy the pistons back
__________________
readers ride thread.
http://www.seatcupra.net/forums/showthread.php?t=300173
wayne lcr is offline   Reply With Quote
Old 26-04-2010, 20:32   #3
wayne lcr
bored of it now
wayne lcr's Avatar
it was last year when i did it and ive got a memo like a siev
__________________
Old 26-04-2010, 20:38   #4
DannyC87
Rubbing is Racing :-)
DannyC87's Avatar
DannyC87 has 10 points
you don't need to remove the caliper or anything; just knock the 2 pins out with a punch and hammer, push the pistons back in by hand with the cap off the master cylinder, copper grease the new pads and put them in. Put the pins and retaining clip back in and your done
__________________
Modded White Mk2 LC - Nurburgring BTG time: 8:25
http://www.seatcupra.net/forums/showthread.php?t=214599 SOLD!!
DannyC87 is offline   Reply With Quote
Old 26-04-2010, 20:41   #5
Android109
Posts: n/a
All the tools I used were a hammer, a punch like above and, er, a bit of tapered 2" x 1" pine, if that can be called a tool. I got the pins out OK after a little encouragement from the punch and hammer; struggled a bit with the pads themselves, hence the wood to nudge/pry/waggle the pads out without apparently doing any harm. Not sure if it's advisable, but it worked for me.
Old 26-04-2010, 20:42   #6
andycupra
status subject to change
andycupra's Avatar
andycupra has 70 points
im sure the guide lets you know what you need... which from memory is very little.
andycupra is offline   Reply With Quote
Old 26-04-2010, 22:50   #7
Dyscontinued
Senior Member
All it really mentions are:
Jack (obviously)
Plastic tweezers (to remove wheel nut covers)
Punch (but not what size of anything)
Screwdriver (if needed use with old pad to lever pistons back)
Seems a lot easier and less hassle than a standard caliper, but I guess maybe that's for ease due to maybe the setup being more race/track focused than a standard car caliper?
Thanks for the info guys, helpful as always
__________________
2004 Nissan X-Trail
Old 26-04-2010, 23:02   #8
vwbassett
Joined the Dark Side
vwbassett's Avatar
vwbassett has 10 points
They are easier than the norm. Just use a nice flat end bunch and make sure the pins go in same way and sit in the same position and leave the fluid cap off the brake resvoir when pushing the pistons back. The job only gets a bit harder when doing discs as well, as my caliper mounting bolts were horrendously tight and only the might of the impact gun got them off a 28inch breaker was useless!
__________________
2004 Artic Grey Seat Leon Cupra R - OEM +
2009 Orange MNR Vortx R1 420bhp/tonne built by me
vwbassett is offline   Reply With Quote
Old 26-04-2010, 23:04   #9
DannyC87
DannyC87's Avatar
Quote:
I had a similar experience with the caliper bolts, though a 12ft scaffold bar over a breaker bar worked a treat
__________________
Old 26-04-2010, 23:10   #10
Dyscontinued
Senior Member
I struggled to get my LC calipers off, tried for an hour and gave up, went back to it after a coffee and realised I was trying wrong way...... embarrassing.
Is ther nothing holding these pins in then? Sounds a bit worrying!
__________________
2004 Nissan X-Trail
Old 26-04-2010, 23:11   #11
DannyC87
DannyC87's Avatar
the pins have a kind of taper on the far end that locks them in place - hence they need tapping in and out with a hammer. Can't really explain the taper thing - you will see what I mean when you take them out
__________________
Old 26-04-2010, 23:14   #12
Phillc
Love is....Yellow
Phillc's Avatar
Phillc has 60 points
Quote:
Originally Posted by Dyscontinued View Post
embarrassing.
There are sprung metal "O" ring things on the end of the pins that compress when pushed in to their holes, they hold the pins in untill you tap them out.
__________________
Gone but not forgotten
Phillc is offline   Reply With Quote
Old 26-04-2010, 23:16   #13
DannyC87
DannyC87's Avatar
Quote:
that is a far better description than mine!
__________________
Old 27-04-2010, 10:13   #14
Dyscontinued
Senior Member
ah I see. I'm sure it'll all be obvious when I get to it like you say.
Thanks guys.
__________________
2004 Nissan X-Trail
Old 27-04-2010, 12:20   #15
GlanzaV
I start fires!
GlanzaV's Avatar
Location: Glasgow (Live) Edinburgh (Work) Ayrshire (Haunt)
GlanzaV has 10 points
Only problem I had when changing my pads was getting the old pads out! Took a lot of wiggling and yanking!
__________________
GlanzaV is offline   Reply With Quote
Old 27-04-2010, 12:20   #16
GlanzaV
I start fires!
GlanzaV's Avatar
^^ Say that ten times ten times fast!
__________________
Old 27-04-2010, 12:35   #17
Dyscontinued
Senior Member
hehe.
__________________
2004 Nissan X-Trail
Old 27-04-2010, 18:39   #18
Dyscontinued
Senior Member
Ok I'm tapping the top pin from the side of the caliper facing away from the car and it's not moving at all. Any advice?
__________________
2004 Nissan X-Trail
Old 27-04-2010, 18:44   #19
ArosaRacer
Kamakazie Wee man
ArosaRacer's Avatar
ArosaRacer has 10 points
when your looking at the caliper face you'll see the edge of the pins, i used a 4 mm allen key and tapped them from the wheel side to the insde. There is a sprung clip as well if you push it down near the clip it takes the tension of and allows the pins to slide out.
__________________
Range rover sport HSE VW Lupo Gti
1.0 vw lupo
1984 bmw 732i 3 times magazine featured
ArosaRacer is offline   Reply With Quote
Old 27-04-2010, 20:32   #20
Dyscontinued
Senior Member
Ok managed to do that side but was a right arse getting that pin out, and one of the pads, proper welded in.
Now I've come to do the other side after having tea and the top bit is flat, not sure if I'm going to be able to get it out at all, being hitting it more and it's just warping worse.
Grrr.
__________________
2004 Nissan X-Trail
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 252
007JRB, adam cupra 20vt, adam5363, adamstreeter, adiohead, Ajmk4, Alex.W, Andy Bird, andy550, andycupra, angusallan, Ape, Apratley, arge, ArosaRacer, atsimas, attila_tdi, aviaa25, Azza_, bakewell001, Barry-Lee, beachy01, benzy50, Bigjohn84, BigWill, billyhas, brad_barker12, breedish, chris2r, CJS-90, Clossie, coldturkey, collins, Conzo_f, cookieboy, cool_baz, coops10, Coupegrale, Cupra Chris, Cupra137, cuprachad, Cuprakev, cuprapete, Cupraporky, CupraTim, cupratune, Cupra_power, czaki, D.K, Daedalus, danny m, DannyC87, dannychapman10, Dave S, dave2k, davidcaffery, davidhunter, dazescort, didsi, dilbert356, Dmoe, drka-drka, drty--den, DTM2014, dubslife, Dyscontinued, ejarvo, Eric87, ets2k9, Evil R 225, Fien, filbro, fitzgerald14, forever, g60stu, gac, gard_ian8, Gaz-04, gazR, George657, ginger3131, GlanzaV, godber225r, GoogleBear, GrahameS, GrantM, Gravesie-363, Grayboy, Guizado, HallycupraR, Har, Haze, hombre_paulo, hornet boy, ibizacupra, iChedddd, indiemike, irf, j976rna, jambox, james walker, JamesMorris, James_LCR, jamfull, jaydenturbo, JB, jcullen88, jenk, Jimmy rally's, jlhiggins, jmcuprar, JoshseatR, jpk67, junglist_matty, KarlB1, kenny-cupra, kevlpool24, kirwis, konighaus, kriso, kyleb123, Laser, LCR Craig, Leadfoot, LEE69, leon cupra r, Leon1600s, Leoncuprarfan, leonrob, liam_seat, littlefella, living2xs, Lockey99, Lodey23, loonitic, loopydoo2002, m45, machman, MainSail, Mannyb, Manx_Jay, Mark300zx, markbrum, markgb, markmeus, MarkWabe, Marsh91, Marthamm, martynpaylor, Mashburn, Matt Mitchell, MattEvans, MattG90, mattyholmz89, matt_83, Mike R, miscreant, MisterD2010, Molvi, MPJ88, Mr2turbo, MrFwibble, Mr_Dave, Murdered LCR, Muttley, Neilman, neilopafc, Nick_J, nutter_engineer, Oakley., Oliveracc, Oneiros, Ovni_cupraR, paul160, Paul1974, Phillc, Phil_beeza, pigeon fancier, Prior, PSX, psycho6285, PTM30, push110, Pylon37, R22 JGB, R88CKS, RACK, Radeonuk, rainbird, Rarpuc, rasco, RDS, redkite, repoman, Richie1985, rickyb90, Ricky_88, rikwheeler, ringer, rix, robbob, robertbadlad, rv_y, ryno, Sam 95, Saminglis, Scotty_b, Sean886, shaunymac, Sherman1991, Shields, sick2death, Simplexx, SlimLCR, slimwiltaz, Smcdee, Squar, Squintstream, stewbie55, STOKOE, Stuart83, stump, stupot_1982, sunilbass, swedey21, Tansy, TDI Cupra, tedvagas, Tessitura, thaivol, ThatGuy, thecrow85, Thompa93, threadsta, THROBACK, TOMSY, Toxic, tseaman20, TubbyTwo, Tubey84, Tuck3r, Turbo whizzer, tyrer, UFO Yellow, useyourname, valverjam, vwbassett, Wacky_786, warond, wayne lcr, wisesmurf, Yatesey8527
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
