Darkside Developments
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 11-05-2010, 11:50   #1
vwprime
Transform and roll out
vwprime has 10 points
Exclamation Fault code 01271 and 01596 any help?
Hi there every one.
This is my first post on here.
Just got myself a the little ibiza and loving it BUT have a problem. When i go to start the car it dosn't want to
If it try it to start it 2 or 3 time and push the throtal down it then fires into life.
Have vag-com it and found this
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045
Component: Klimaanlage X0840
4 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
29-10 - Short to Ground - Intermittent
28-10 - Short to Plus - Intermittent
Have used the search button and seems like others have had this problem but theres been no menchan of how to fix it or where to look. Can any one help me?
Im gessing its somthing to do with the auto chok when it cold.
vwprime is offline   Reply With Quote
Old 11-05-2010, 22:42   #2
RUM4MO
Senior Member
RUM4MO has 10 points
No, that module has nothing to do with how the engines starts or runs, as the title says, its for the automatic heating and cooling - ie AIR CON. These flap motor failures are typical of all VAG cars, but maybe try resetting all the motors by running basic settings using VAG-COM.
Which engine has your car got, if its a 1.2 then it might need the static timing checked, or maybe its only the engine coolant temperature sensor that needs replacing - it will not show up as a failure in VAG-COM until it falls outwith expected parameters - but if it is not as intended then it might cause cold starting problems.
RUM4MO is offline   Reply With Quote
Old 11-05-2010, 22:59   #3
vwprime
Thats for the reply Rum and the advice.
It is indead a little 3 pot 1.2l engine which i have. If it is the temperature sesnsor that is corsing the truble, do you now where about i could find it?
How would the air con affect how the car would start also.
Another example today when it was tryed to start the car this morning it wouldn't. this was about 7am. Tryed 6 time. The car turned over but did not fire. Found another method to get to work, but when geting back home tryed it agane and started first time. Its almost as if it dosent like the cold morings but hoter afternoons, lol
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 41
31satara, adam.k, aiden182, AndyC567, Biker, chris_200120vt, CJRamze, cooper61uk, Cos, cyclone1777, davehodge, eugenebd, fr_craig, geoffjuggs, great_kahn, Imteyaz, jacko_86, K.I.T.T., kareemsafwat, KernowFR, Lippo, Mangled, markm, martin150, MartinDov, mick-fr, Mr Krabs, MrNorma, mumblist, processpaul, RaggedLob, Ric 2001, rich3001, RUM4MO, soggytomato, sprite, tcm1106, tdi_swedge, TimJohnson, vwprime
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
