SEAT Servicing
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 02-07-2010, 03:49   #1
shazo
shazo's Avatar
shazo has 10 points
EGR delete or removal
hello,
since iv got abit of free time i thought id start working on the ibiza again. i have a facelift 1.9 tdi FR mapped, no cat and no backbox just a straight through pipe and a K&N cone filter.
anyhow recently i was messing about with a mapped fabia VRS and i got off on him and he told me he had a EGR delete. im concidering doing this depending on how hard it is and cost.
so if anyone knows can you answer the following:
1) does removing the EGR and raplacging with a pipe make is faster/responsive?
2) will removing EGR affect the engine?
3) will any warning lights appear on the speedo?
4) any idea where i can get the pipe from? and how much? a fried told me e-bay
any help would be apreciated.
shazo is offline   Reply With Quote
Old 02-07-2010, 03:55   #2
gezmeister
I need a derv!!
gezmeister's Avatar
gezmeister has 10 points
Not sure on any of the technical questions, but here's a link to one on ebay
http://cgi.ebay.co.uk/Allard-EGR-Val...item27b2e6bad4
__________________
1999 Seat Ibiza Cupra Sport
RR Thread http://www.seatcupra.net/forums/showthread.php?t=323845
East Anglia Members List: http://www.seatcupra.net/forums/showthread.php?t=293477
gezmeister is offline   Reply With Quote
Old 02-07-2010, 12:54   #3
Rhys_
Rhys_'s Avatar
Rhys_ has 10 points
Ok i will try my best with what i have learnt but someone may be able to give better advice.
1) There is no performance gain in bhp etc with an EGR removal, all you are doing is stopping the exhaust gas recirculation and therefore stopping the build up of all the black gunk.
2+3) it wont effect the engine as such as you are educing the build up of deposit but a warning is most likily to come once it has been removed - most people then have the light mapped out.
however in having this done on some of th more modern 1.9tdi engines i have heard there is a slight loss in power i.e a reduction of 5hp or a little more, i dont know why and all the people i have spoken with have not got a full answer yet, however the main reason i have know people to do it is not specifically for performance but for the reasons in point 1.
4) Allard used to do a kit, and i think maybe spitfire performance do one but not sure on any others.
hope that helps
__________________
My FRtdi - Awesome gti custom remap + extras..... 182bhp 340 ft/lb - Now sold
Now:- Mk5 Golf Gti edition 30 APR stage 2......
Rhys_ is offline   Reply With Quote
Old 02-07-2010, 20:22   #4
krussel
Senior Member
krussel's Avatar
krussel has 10 points
What about one of these blanking plates with the small hole in the center to let some gas through to fool the sensor, any good.
krussel is offline   Reply With Quote
Old 03-07-2010, 11:21   #5
Rhys_
Rhys_'s Avatar
Rhys_ has 10 points
I have only read that some people have used those because they didnt want the trouble of mapping the light out, but havent heard much further than that sorry.
__________________
Old 03-07-2010, 11:29   #6
L14M_T
THE JOYS OF A 1200cc
L14M_T's Avatar
L14M_T has 10 points
I done this to my 1.2 and felt it was hell of a difference especially on low revs but made my engine run alot richer which caused it to run really hot. I didnt pay any money to blank the EGR valve, get some sheet metal and trace the outline of the end that connects to the inlet manifold and the end that connects to the EGR(from the manifold) solid peices no holes for it to breath. Put them in between like gaskets and disconnect your EGR plug bolt it back together. so no air is leaking into your intake or exhaust gasses leaking into your engine bay. Of course your going to have your engine management light on however way your going to it because the emissions reading is going to be incorrect but thats the easiest and cheapest way that does the same job.
__________________
Current Mods: Stainless Steel Catback With Cupra Tip, 4300K HID, 17" Accessory Alloys, Dropped 35mm On Apex Springs, CDA-9886R Headunit, Vibe CBR12 EVO V2, Espanõl Plates
L14M_T is offline   Reply With Quote
Old 11-07-2010, 04:43   #7
shazo
shazo's Avatar
shazo has 10 points
through my research so far it was sought removing the EGR with the allard kit would increase responsiveness of the car and performance as more oxygen and air was going into the engine.
so far i found a blanking plate and an allard kit for 60 quid on ebay. theres a local lad with it done to his fabia VRS next time i see him il have a proper chat and look under his bonnet.
thanks for the help
Old 11-07-2010, 14:08   #8
nickfantastic
Newbie
nickfantastic's Avatar
nickfantastic has 10 points
I have blanked my egr pipe at the exhaust manifold side. it was just a case of cutting a piece of tin to shape. as for the eng man light there is no reason for it to come on as the egr is vacuum fed and and ur not actually disconnecting. the only reason u wud see the eng man light wud be if your air flow sensor picked up a change in the air drawn into the engine. unlikely tho.
nickfantastic is offline   Reply With Quote
Old 11-07-2010, 14:55   #9
techie
Skoda Techie
techie has 20 points
That's how the engine ecu works out egr flow though, it is programmed to do that.
__________________
techie is offline   Reply With Quote
Old 11-07-2010, 14:59   #10
nickfantastic
Newbie
if this is the case then if your engine man does appear a egr map out wouldnt work. ud have to totally map wot the maf sensor is seeing. suppose mapping places hav already figured this out
Old 11-07-2010, 15:01   #11
techie
Skoda Techie
You alter the expected egr flow reading the the engine ecu, much like turning it down with vag com but deleting it so it doesn't look out for the calculation.
__________________
Old 11-07-2010, 15:14   #12
nickfantastic
Newbie
so wen egr is blanked would your maf sensor would see a bigger air flow. It would draw more air to compensate the loss of exhaust gas
Old 15-07-2010, 05:36   #13
shazo
shazo's Avatar
shazo has 10 points
i thought it would be a straight up manual job so i can replace the parts myself... this mapping out the EGR flow thing seems like its going to be a headache.
Old 15-07-2010, 12:20   #14
Jimski
Ibiza Gone Landy Here!
Jimski's Avatar
Jimski has 10 points
Iv reduced the gasket size, known to work well on the 'BLT' engine codes etc.
Iv got reduced hesitation on a gear change, definately noticable. £1.40 and 10 mins to do!
Jimski
__________________
FL2 - Black Edition
Jimski is offline   Reply With Quote
Old 29-07-2010, 08:35   #15
shazo
shazo's Avatar
shazo has 10 points
Jimski
i have a BLT engine... how do i go about doing this ?
Old 29-07-2010, 11:10   #16
Copey
Senior Member
Copey has 10 points
which is the BLT engine?? im also interested in this gasket reducing.
__________________
03 Ibiza TDI Sport - Jabba Remap - PD160Intake - K&N Panel - Decat GONE
Megane 225 - GONE
MK5 Ibiza Cupra...mods coming
Copey is offline   Reply With Quote
Old 29-07-2010, 18:31   #17
Jimski
Jimski's Avatar
Click on my readers ride link, its all in there!
OR for the lazy ones; http://www.seatcupra.net/forums/show...=255666&page=4
Jimski
__________________
FL2 - Black Edition
Old 30-07-2010, 17:13   #18
Nexus_french
Nexus_french's Avatar
Nexus_french has 10 points
you can also delete it with vagcom. You can either reduce the usage of it, or totally make it not working!
Nexus_french is offline   Reply With Quote
Old 30-07-2010, 22:04   #19
Aimez
Evil woman of doom beware
Aimez's Avatar
Aimez has 10 points
Sorry I am still lost where is any proof this does anything other than what people 'think' which may be in imagination, anyone RR the car before and after or anything?
Why is Jim saying it cost £1.40 and then people saying it is £60 off ebay?
I have never really heard much talk of this doing anything and been on this and few other VAG forums 4 years now so need to be convinced.
__________________
Mk4 TDI FR Readers Ride
Aimez is offline   Reply With Quote
Old 02-08-2010, 21:17   #20
jase750
jase750's Avatar
jase750 has 10 points
I'm hoping Andy at PSI will be able to shed some light on this as I would like to do it too
__________________
jase750 is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 467
'07Ibiza, *Adam, .Phase, /dev/null, 00Rupert, 01beany, 02browncraig, 221084clarkey, 303jon, 747_727, abbotsmike, abrooking_7, adam cupra 20vt, adam kelly, adam taylor, adamfrtdi, adam_may, Aimez, Al Wyn, Al-Batson92, Alastair28, AlexIbizaSport, alien1974, Alistair_TDI, alix101010, allh2k, alx_chung, AndrewFabia, AndrewJB, andy1max, AndyC567, andye1, andypandypoos, andyspencer, Anekiller, ant5735, apj, Arnoldo, AshFR, Asurik, Az_TDI, B16 HEO, B5BDJ, Badger89, baggies01, bailey1992, bai_ILIA, bald_eagle, bananaskin, barker57fr, Bassedout, baztdi, belfastchris45, Ben-Stevenson, benjiwales, Benn0, benuk, Benzy, Ben_dit, bisto48, Blakrover, Blanco92, bodi739, Bodygard, Bondiblu, bonsaiman, br0wny21, brod, bruceR, bungle89, bushyboy, cactusjack, cairns81, Cal91, calvino, Carisma, carljason, Carlos_11, ceejay90, celoader, chevychase, Chris16v, ChrisssRFC, Chriswaite130, chucky, CJRamze, CJS-90, Cleg85, clouty86, codneedsatdi, CooperC, Copey, cotters, cowtc, craig247, Craigbarnley, creatz, cupra tda2, CupraSean, CupraSeanTDi, cupra_ian, Cupra_Tim, cwharreld, D-Power, D4V2K1, damon6uk, dan666, danarmstrong, DangerConsult, danny mk3 cupra, dannyshep, darkhorse, Darren FR150, darren78, davescupratdi, Dave_88, davidmills2002, Davidsr, daytona246, DazJohnson, DazzaPD160, daz_pd, Deamox1fy, DEAN0, deansutherland, Degenatron, deputy-dog, dervpower, dErZ, Desert Varnish, devonfr150, dholdi, dicky FR, digby130?, dionbee93, Disco_Biscuit, DKershaw, dmcar02, Dom1988, Dubbed, DUTTY636R, DXI 9073, dyl5, Eastwood29, ecklad, edbe, EdButler, f1remandans FR, F3rAL, Fairy-130, Fatnfast, Feel, Fergy, Flash6180, flegz16, fletch2k00, fordy, FR Mark, FRCookie, FRich, FR_MATT, fr_nathy, fuzzy232, g0dd3rz, G2, gac, garethgje, garethpitt18, Gareth_1.8T, garycocozza, Gazb, gbm, gdjohny, geeves, george130, georgebibizafr, gezmeister, go fast sid, GotBoost, Graeme-p, great_kahn, grq, GT Bee, Guinness, H1JJY, hannay-fr, Hardsy, Hargo, HEAVYRIGHTFOOT, hendos, hubbly_bubbly, Hudson, Hugos, i3ai2t, iain1970, ib04tom, ibiza@kev, ibizacupra, ibizatom, ibiza_1.4tdi, ickleginge, imkeller, Imteyaz, IxOZxI, J44APX, ja-mo4, JackM92, jacko_86, jake_h, james631, jamest87, jamie8954, JamieC19, jase750, jay6392, jenk, jimbo_h, Jimski, jo runt, John-Cupra_TDI, John11367, johnnyc91, john_tdi, jonesy000, JonnyBCK, Jonny_89, jonny_mcc, JonSportPD100, joop200789, Jordanwaterhous, Joshh, JPS3290, JR_130, jscottuk, JTD-ED, JuanPretorius, JuJu_Cupra, juneau, KaizokuShinobi, kart19, kelford1988, kenny629, kidm170, kingy89, kinjamin, knight85, Kris@Forge, krussel, L14M_T, lacojski, Lagosta, Lambro6, lardyboy, lawry, Lee_89, leonbeastmk1, leontom, Leon_FR_150, level_lewis, liam TDi, Lippo, Lucio Bravo, LUFC, Lui, MadFaz, madvortex, magicmcfc, makkakm, malaroo978, ManOnTheMoor, manos-z, marcosport, marcusleon, mark_eisner, marsh175tdi, Martin_FR, MATT RILEY, MattBennett, Mattwood, mazzerati, mcd90, mcdatkyid, mgrays, Mick288, Mickylad, mikectr, MikeR, Mikey.B, Milltek Kev, MiniMrMan, miniond, Misko, Mitch Turbo, mitchathome, mjl_100, mjrally, MK1_LOVE, Modelmakerman, moggytom, moonrat, MrNorma, Mudvayne, Muttley, n5erd, nac34, nase, neil_g, Neo, Nexus_french, nick0323, nickfantastic, niki, Ninety, NK03HHT, Noone, Number12, Octane2097, oldtimer, ozzysoil, palmeirex, paulhdi, pazz1991, pegski, Peter 87, peterrc, pete_266, phey708, Phil-B, phillpotts92, pjdj, platinumatt, PLuKE, Plutus, Poncho.:R, Prebs, pro00mo, puchos, push, r34nel, RafLad, Raj, Raks, Random1989, Raziel, Razzario, Red Panda, rf860, rhysfr, Rhys_, RichRoth, Rich_Derv, Rick, riffmaster, rob_pd160, Roccatmode, rocky2008, rod the sod, roscupra, rossh13, S10EAT, S7UYJ, sacho, sahar, salvodeveloper, samussamus1, Sarg, SCO5TYE, Scotty22, scottym, Sean Gallagher, Seat tech, SHADY-NINJA, shaggy7, Shandow, shaun21, shaunTDI, shazo, SheffieldKid, shep0706, shorn, shox, Signor Whippy, simo, Si_TDi_FR, sjolliff, smashingguy, smiff, snave, sonnex22, spen, spikes129, Spirit Furtive, Spooky211, sprintman, sprite, stebbi, stevedoc, steve_1017, Stevo-91, strykezero, stuc_27, Stueeyb, Stuiemc, suj, TALBOTL, TAOTAO, TazB, TDi Buz, tdi sport, tdi_chris1, tdi_swedge, techie, TerrificToledo, thaiffer, the rob, thekingofming, thomasa, tills7, Ting, Tiz, TJaxx, tj_the_great, Toby Davis, tobybongo, tollydan, Tom-FR, tomberry89, tomek113, tomh18, Tommyboy91, Topcat, Trancer, trebormint, TSVB, tuan21, turboboy, Turboelvis, tyson23, VIKINGODIN, vroomtshh, vwtrellis, walpole, Warning, Watkins1991, wazb, wealthysoup, Weedall, wenman, wezy0, Whitechapel, whitie, widowmaker, wilfster, will105, will7291, Willsy33, Wilson9, Wolves73, Woodsy19, wrayvon, xKnife, xxjay247xx, x_hale, yoo, Yosh, Young_Derv, zach225
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
