SERE
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk3
Ibiza Mk3 For 2000-2002 Specific Information.
Reply
Thread Tools Rate Thread Display Modes
Old 06-01-2004, 20:49   #1
Garth
Back in the S!
Garth's Avatar
Garth has 10 points
ICE MAN: How do I wire an amp idependent of fader?
I want to install an amp and sub in my mk3 Ibiza Cupra as it has less than no Bass!
I know how to wire up the amp (already have Alpine V12) using hi-level inputs, but want to retain the front and rear speakers and therefore the fader.
How can I wire up the amp so that the fader has no effect on the sub?
__________________
Garth is offline   Reply With Quote
Old 29-01-2004, 14:37   #2
CupraPower
CupraPower's Avatar
CupraPower has 10 points
HI.
If you have an alpine sub then you can get an Alpine bass controller
Part Number:RUX-4180
This basically plugs into your Alpine Amp and you can adjust the bass accordingly. Long lead which will reach from boot to dash area.
Though this is only available to connect to the latest amps. 2003 onwards.
See alpine website for more details.
If it wont connect to your alpine amp. Then get a bass cube. Something from Phoenix Gold. The titanium range is the best to go for. This will then allow you to control bass.
Phew..!
Hope that helps
CupraPower is offline   Reply With Quote
Old 29-01-2004, 22:45   #3
Shock_Xe
Posts: n/a
same thing ere, got an alpine v12 (older model) and alpine type R 10" on the way,
Prob i got is that i havent got the plug for amp & hi-lev inputs. any ideas?
Also I would like a boost controller remotly so i can turn it down when the mrs gets in!
Old 30-01-2004, 00:17   #4
Garth
Back in the S!
Garth's Avatar
Garth has 10 points
Thanks for the reply cuprapower, however you don't seem to understand my question.
I want to wire up the amp but not lose front or rear speakers. I still want the front and rear speakers to function as they do now, including the fader. I also want a sub, but I don't really care about being able to adjust it from inside the car. Once the sub level is set, I will leave it alone as I always have in previous cars.
My question is HOW do I connect the inputs to the sub amp. I could disconnect either fron or rear speakers and connect directly into high-level amp inputs, but then I would lose the speakers. I could split the speaker wires to both the speakers and amp, but then surely I would be halving my signal and would lose too much quality.
Either of these methods mean that adjusting the fader would adjust sub level, which I don't want.
Shock Xe: You can get a high-level to rca converter which are pretty good. That way you can convert your speaker outputs from the head unit to rca inputs to an amp.
I remember you added some new component speakers to your car. Did these make a big difference? I am unsure whether to upgrade as the source is probably the limiting factor in the system.
__________________
Old 30-01-2004, 07:18   #5
Shock_Xe
Posts: n/a
I now have focal's up front and infinity 6x4 @ rears. Im in the process of getting a sony Iso Amp. It runs of the ISO connector of the car (no other wires needed) and increases the inputs from standard 20w to 55w. It retails around £70 and is only small so it can be hidden
Old 30-01-2004, 08:06   #6
CupraPower
CupraPower's Avatar
Yeah ISO sony amp is an option. They got them on display in you local Halfords!
Old 30-01-2004, 08:58   #7
Garth
Back in the S!
Garth's Avatar
Garth has 10 points
Shock, did the focals actually make any difference though?
I tried to buy some good components at my local audi place and the sales guy told me not to bother. He reckoned it would only sound worse as there wouldn't be enough power to the speakers from the standard hu.
I said I wanted a simple install. Some good components up front and a sub, with some replacement rear speakers for a little bit of rear fill.
He tried to sell me a HUGE 6 channel amp, an equalizer and everthing else he had in the shop! HELLO?? I actually USE my boot!
__________________
Old 30-01-2004, 09:07   #8
Shock_Xe
Posts: n/a
focals have made a difference. More depth and rear infinityies (fit in stock location) are not so rattly.
As with the sony amp mentioned some dealers (amethyst etc) actually supply and fit it (It goes under centre console) so you will get a big improvement if you combine this and uprated speakers
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 4
A.m.C_Ibiza1, Banksy 1, bruza, motty_90
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
