hello guys
Sorry for not checking and uploading pictures.
Didnt think you wanted to see these. quite boring pictures.
But heres some.
Last time on ground as an FWD Leon
Cupra...
Finally got it upp on the lift..
Before starting to take parts away.. The car that is behind the door is a Real Supercopa race car. wonder if i should borrow some parts
Rear exhaust off
Bye bye fueltank..
Bye bye Rear Subframe
looks like something is missing??
Lets start at front to get gearbox out and so..
Gearbox and front Subframe is off the car..
My Friend Fredrik that helped me that evening.
New gearbox fitted. Not cleaned yet as we first will trial fitt everything and then take it down and mount it again with new Bolts and so everywhere.
Again going to be very Tight
Propshaft tested. Goin to be tight with the Downpipe
Old
Cupra Rear axle/Subframe vs The Aluminium i will use.
I use the Aluminium one instead of the Metall one i bought first as this looks much better and seems stronger?
So if somebody need one i have this with the parts in the pictures to sale..
Also have front S3 Aluminium Hubs and KW F/R Antiroolbars complete with bushes
Starting to move parts over. Lucky all parts are the same so dont need to press any more bushes. Only one i need to mount on the rear Hubs.
One side Moved..
Old rear Subframe
vs New AWD Aluminium Subframe.
Well thats all for that evening we worked from 6pm to 1am or so but couldnt come further as the Antiroolbars didnt fit. I was told by KW reseller that the front would work only rear wouldnt fit. so i figured to use the oem S3 rear just for mounting and get the rear one later.
But i ordered a set of front and rear Arbs From H&R instead and got them yesterday so went to the garage where the car hangs firm on the lift to mount little.
Then pressed out the old rear hub bushes and mounted the Powerflex there also.
Then i saw that i had to order 4 new bolts to get the hubs on the rear. the old ones are little to short.
But wanted to mount the rear subfram/axel so continued and just will change bolt later.
Diff almost mounted.
Found that i forgot to order these bolts..
And also missplaced lost these 2 with brackets some where.
That was a couple of hors of mounting and cleaning parts of. And went home.
Now Tuesday or wednesday the bolts should arrive so i can get that done.
Maybe later today or tommorow i will go there and cut a bit of the boot floor out.
If someone want to se i can update with pics when ive got a bit further.
Or maybe boring to look at these kind of pictures?
