Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 11-11-2010, 21:15   #1
Big Geoff
Posts: n/a
Engine Management Light
Seat Leon Mk1 year 2003 1.6L
I have a problem with the engine management light permanently on. Got the code PO402 Gas Recirculation Flow (EGR) Excessive Detected.
Is there a common fault or a guide on the forum to find the cause.
Help appreciated.
  Edit/Delete Message Reply With Quote
Old 11-11-2010, 22:07   #2
GlanzaV
I start fires!
GlanzaV's Avatar
Location: Glasgow (Live) Edinburgh (Work) Ayrshire (Haunt)
GlanzaV has 10 points
16786/P0402/001026 - Exhaust Gas Recirculation (EGR): Excessive Flow
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
  • Reduced Exhaust Gas Recirculation (EGR)
  • Reduced Power Output/Engine running rough
  • Increased Emissions
Possible Causes
  • Exhaust Gas Recirculation (EGR) Valve stuck open/leaking/faulty
  • Exhaust Gas Recirculation (EGR) System leaking/faulty
  • Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
Possible Solutions
  • Check/Clean Exhaust Gas Recirculation (EGR) System
  • Check/Replace Exhaust Gas Recirculation (EGR) Valve
  • Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
__________________
GlanzaV is offline   Reply With Quote
Old 11-11-2010, 22:08   #3
GlanzaV
I start fires!
GlanzaV's Avatar
Looks like a faulty EGR valve - might be gunked up.
__________________
Old 11-11-2010, 22:22   #4
Roohul
Roohul's Avatar
Roohul has 10 points
A code P0402 most likely means one or more of the following has happened:
* The DPFE (differential pressure) sensor is faulty and needs to be replaced
* There is a blockage in the EGR (most likely carbon buildup)
* The EGR valve is faulty
* The EGR valve may not be opening due to a lack of vaccuum
Possible Solutions
With a P0402, it is common for people to replace the EGR valve, only to have the problem return. The most likely solution is to replace the DPFE sensor.
* Check the voltage at the DPFE sensor both at idle and when the EGR is open
* Replace the DPFE sensor
Roohul is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 16
Alexis27, Ash.LCR, craigfosker, Dione J, Doey1978, Getgaff, GlanzaV, JamMonkey, Jirwin, Khaosie, mrvavavoom, Muttley, Rgm racer, Roohul, sambryant, yealmdev89
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
