AJSanderson
Ibiza Mk5 SC
Does any one know which fuse controls the washer fluid pump. The Manual is not specific. It tells you which are for the washer wipers, which are working. And it tells you which is for the headlamp washer pump - only my cars not fitted with headlamp washers.
I had a new washer pump fitted on Tuesday, used it once and now it not working. No sound from the pump motor which makes me thing the fuse is blown.
