P-Torque
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Altea - includes XL and Freetrack
Altea - includes XL and Freetrack Use this forum for specific topics relating to the Altea MPV range
Reply
Thread Tools Rate Thread Display Modes
Old 22-12-2010, 09:48   #1
Alteamees
Newbie
Alteamees has 10 points
Seat Altea ECU connections
Hi everyone,
Greetings from Estonia,I am newbie here so this is my first post.
I own Seat Altea 1,9 TDI 2007. The car has stayed for 3 months and now when it´s winter i started to drive with it again. Now i have noticed that after a little driving TSC/ESP light will appear to dashboard (car with S road underneath). The light will be constantly, not blinking. ABS is still working then, but i think TSC will not. After i start the car again, the light is gone, but will be back soon after some driving.
I tested it with Bosch tester and it showed error code 042 - altarnatror charging too low. I tested alternator and it was OK (14.4 V). Bosch didn´t show any problems with ABS, TSC, ESP system.
042- means also open circuit. One of the mechanic told to check all the connections with ECU.
Here is my question, do you have any other ideas, what can cause this situation ? Where is located ECU ? Where is located ABS/TSC/ESP central system ?
Thank you in advance !
Madis
Alteamees is offline   Reply With Quote
Old 27-12-2010, 13:36   #2
klawit
ALTEA 2.0 FSI SpEd
klawit's Avatar
klawit has 10 points
Hi Madis,
though it's only links to a german SEAT board, I hope you'll be able to get the information there translated ... as I regard them quite useful.
Issue seems to be well known (given that yours is the same) and they discuss a more reasonable exchange of just defect parts than replacing the whole expensive ABS-ECU.
=> http://www.seatforum.de/forum/showthread.php?t=166175
=> http://www.seatforum.de/forum/showthread.php?t=167552
(esp. check out Nieli's posts)
greets ... Klaus
EDIT: additional info ... location of ABS-ECU (here GOLF5) and how to unfold:
1: tear out fixation gib as far as possible
2: disconnect plug from ECU, remove cable tie securing plug to cable harness
pic#3: open/remove cover of plug (only if necessary)
(excerpt from a DIY from team-dezent.at)
__________________
ALTEA 2.0 FSI Sport Edition
MY2006 + Lluvia Blue + 17" Alloys + Sunroof + CD2/MP3 + CDC
klawit is offline   Reply With Quote
Old 27-12-2010, 18:01   #3
Alteamees
Newbie
Thank´s Klaus,
Now at least i know from where i should start to check the connections. I hope i don´t have this falult which demands the ABS ECU replacement.
Could somebody tell me, if they have this kind of problem which refers to falulty ABS ECU, does this TSC/ESP is lighting constantly or not ?
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 42
Alteamees, anarchy1515, anedisime, arsenal401, bazmac28, bertandernie, bluehawk, boki, christhesparky, chutz1, CrispDust, Datsun, davidif, davidspringer19, dubzilla, gazb46, jonathan 2222, jonial, jtmac, kinjamin, klawit, krisby, M1KEH, Mao, matty18-88, megadyptes, mike55, mr.chris, Mute, MWG, Prenders, reddevilhome, Redemption, robint, SCOBLADE, SCupra, smashingguy, specek, STOCKY, stuwbafc, tony19b, Wimbledonian
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
