Listers - Parts
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 31-12-2010, 14:11   #1
dingosnack
Posts: n/a
Red oil light flashing, 3 beeps, won't start
Hi all,
Please bear with me as this is my first post. About three days ago I went to start my car but it wouldn't start. Its a 2003 Seat Ibiza. The red oil light flashes and it beeps three times. After searching on these forums, I thought this was related to the coolant level which I topped up but I couldn't find the prongs to give them a scrape. It is now in the garage, where it has been for 2 days but they can't seem to detect the problem. Their diagnostic computer came up with nothing, they cleaned the prongs which didn't work and a new cam centre (i think thats what he said). Nothing is working! Any help would be greatly appreciated
Old 31-12-2010, 17:55   #2
toledojohn
Posts: n/a
Have you checked the oil?
Old 31-12-2010, 18:13   #3
truCido
Race Lupo in progress...
truCido's Avatar
truCido has 10 points
When you say it wont start whats it actually doing? Also what engine is it?
Red Oil light I thought was for oil pressure low etc.
__________________
Click picture to see Build Thread!
truCido is offline   Reply With Quote
Old 31-12-2010, 18:37   #4
doug2001leon
Vrrrrroooooooom.... Toosh
doug2001leon's Avatar
doug2001leon has 10 points
sounds like an issue between the main loom with the oil temp / presure sensors on it and i would imagine it has melted through somewhere, also check the earthing cable, am i right in thinking it turns over fine just not fireing?
doug2001leon is offline   Reply With Quote
Old 31-12-2010, 18:53   #5
dingosnack
Posts: n/a
I've checked oil and that's fine. It's a 1.2l engine. It tries to start but won't fire up - the spark plugs are sparking and the battery is fine. The garage tried a new oil pressure switch today but no luck. They reckon the next step is a new crank sensor but they can't get hold of one til Wednesday with all the bank holidays. What do you think? It was fine at 10pm the night before, then at 8am the following morning it wouldn't work. It was -11 overnight so could it be to do with that?
Old 31-12-2010, 19:36   #6
andycupra
status subject to change
andycupra's Avatar
andycupra has 70 points
forget coolant sensor for now as this wont effect starting of the engine.
Is it definately the oil light that flashing. - i appreciate this might seem a silly question but many people get the coolant gauge and oil lights mixed up.
andycupra is online now   Reply With Quote
Old 31-12-2010, 20:01   #7
chrisRibiza
Senior Member
chrisRibiza's Avatar
chrisRibiza has 30 points
Mines done this before, the oil light on the middle panel between the speedo and rev counter beeps and flashes.
It has only happened when the car has been low on petrol so I've push started it and filled it with petrol and it's been fine.
chrisRibiza is offline   Reply With Quote
Old 31-12-2010, 20:11   #8
doug2001leon
hmmm, im guessing you had propper antifreeze in it yes?
other thing i can think of is crank pickup sensor but would normally throw up management light.
Good luck bud keep us updated.
Old 03-01-2011, 20:59   #9
Disco_Biscuit
Ibiza Cupra Tdi PD200
Disco_Biscuit's Avatar
Disco_Biscuit has 10 points
If it cranks over for a bit and doesn't fire the oil light will beep and flash, if its a 1.2 chances are the timing chain has jumped.
__________________
Ibiza Cupra TDI PD200 / MNR Vortx R1
Disco_Biscuit is offline   Reply With Quote
Old 28-10-2015, 14:18   #10
tara1990
Newbie
tara1990 has 10 points
I know it's been a long time since this post was commented on, but I wondered if you'd ever managed to find out what the problem was with your Seat? Mine is doing the exact same thing, turning over but not starting, although this is only happening intermittently.
I've tried AA's diagnostics, the local garages diagnostics and I've even bought myself a diagnostic machine to see if I could find the problem but nothing comes up on any of them.
Any suggestions would be appreciated as I'm pulling my hair out at the moment!
tara1990 is offline   Reply With Quote
Old 28-10-2015, 17:57   #11
cheshire cat
cheshire cat's Avatar
cheshire cat has 10 points
as a test when it won't start spray in some easystart if it fires it may well be a juice problem if it doesn't it sounds like ignition at least it may give a clue
__________________
Nic
cheshire cat is offline   Reply With Quote
Old 28-10-2015, 18:39   #12
tara1990
Newbie
Thanks. Will give that a try and let you know if we have any joy. Fingers crossed!
Old 29-10-2015, 12:01   #13
Arkaig
Arkaig's Avatar
Arkaig has 10 points
Quote:
This is correct, the oil light can be a bit of a red herring since it often beeps/flashes if the engine turns over for too long without firing, for whatever reason.
Arkaig is offline   Reply With Quote
Old 29-10-2015, 12:29   #14
tara1990
Newbie
So it could be that the timing chain has jumped?
Old 01-11-2015, 10:48   #15
MW05
MW05 has 10 points
This is why I stick to diesel engines. So much more simple.
My last car, an Ibiza SDi developed a starting problem. Actually the scum who sold me the car sold it with the problem...
The immobiliser would sometimes not stop immobilising and then often when the weather was warm, or it had been left in the sun, it would start but then immobilise itself while driving along.
Once I'd worked out what the problem was, I attached a wire to the fuel shut off solenoid with a ring crimp and bared about two inches at the other and when it conked out or wouldn't start I wrapped the bare end around the buzz bar on the positive side of the battery.
I eventually fitted an illuminated switch in the car below the handbrake handle so I didn't have to keep fumbling about under the bonnet.
I was going to fit a relay which would take a feed from the ignition, but the loom is all wrapped and I couldn't be bothered to pick at it to expose an ignition wire.
MW05 is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 104
.Phase, 00Rupert, 31satara, ab1702_123, adambudders, alcarp, andycupra, andypandypoos, Arkaig, as92lv, Badger, bald_eagle, beezanick, ben3486, Bigjohn84, Blanco92, britishsligean, calin1980, cheshire cat, Chino_UK, chrisRibiza, CJS-90, Cos, CRAZY LEG5, crigisback, cuernos, cupraslayer, cupra_matty, Dabbalz, Danny_B, daverave, dazed007, DEAN0, Derbian, desikeera, dftsa, Disco_Biscuit, doug2001leon, Edward9th, f15h, F@ruk, fa51jam, gareth86, gobby_irl, Gooner_Mike, Guffers, Guinness, Hartosh1, hilly81, ian_106, jacko_86, James_LCR, JimmyL, jman323, jonesy000, jonial, Khaosie, krisbutler02, lil3520, markisgoing, matthab, mick-fr, MMA FR150, Modelmakerman, moseschrist, mty12345, MW05, Nath., neil_g, newbs, Orion1969, peter_cupra197, phey708, PLuKE, R3k1355, rahul, Red ibiza, rf860, Ronan83, RozzerH94, rsulam, RUM4MO, smashingguy, Smcdee, smithy84, spykey, st10587, ste_p23, sydoggkdy, TAOTAO, tara1990, teeth2k, Theinluence, Thev5, tills7, Tom0StarC, truCido, wazb, wezy0, Whitechapel, yookie, zach225, Zero T, Zlash_eX
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
