Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Engine Discussion » TDi - SEAT Diesel specific topics
TDi - SEAT Diesel specific topics exclusively for SEAT diesel specific topics only.
Reply
Thread Tools Rate Thread Display Modes
Old 04-01-2011, 17:47   #1
FRich
Posts: n/a
1.9 tdi thermostat problem, maybe?
Hi guys (again)
If anyone's been keeping track I'm having some trouble with the cooling system on my Ibiza. I had the water pump replaced as I was loosing coolant and it turned out that was the culprit.
NOW for the new issue! When driving home today the heater was blowing out lovely tropical air but all of a sudden it turned Arctic. Checked the temp gauge and I was running at about 100 but slowly went back to 90. I had this for about 15 mins (10 miles) then I got my heater back and the temp settled. No coolant has been lost (quickly checked when I got home) but I could hear a slight hiss/bubble coming from the expansion tank.
Could I have a faulty thermostat?
  Edit/Delete Message Reply With Quote
Old 04-01-2011, 23:15   #2
MJ
Public transport abuser
MJ's Avatar
MJ has 90 points
there may have been an air lock within the coolant system, this is quite common on the vag apparent self bleeding system which only, in reality bleeds itself once you give the vehicle a good thrashing. Chances are its now released it and wont do it again.
just keep an eye on it over the next few weeks to see how you go.
__________________
Back with the Seat brand after 2 years!
James - Master Technician @ Pentagon Seat Oldham
MJ is offline   Reply With Quote
Old 04-01-2011, 23:22   #3
FRich
Posts: n/a
Well on a long trip (140 miles each way) I lost some coolant but the heater was fine. surely the air lock would have been resolved in that sort of distance?
Old 04-01-2011, 23:26   #4
MJ
MJ's Avatar
MJ has 90 points
i would have thought so, its not uncommon for the header tank to spew a little coolant out when it dumps the air (it comes out as steam).
__________________
Old 04-01-2011, 23:29   #5
FRich
Posts: n/a
The header tank was wet on the top. I'm just worried that its taken this long to get rid of the air lock. but if its gone then I'm definitely happy! I'll keep a close eye on it for a while and make sure. what's the best way to check the thermostat if that it the problem?
Old 05-01-2011, 02:13   #6
Seatmann
Rough around the edges
Seatmann's Avatar
Seatmann has 20 points
I've never had any issue with airlocks on my 2000 1.9tdi Cordy. I just fill it up to the mark, start the car and let it run for 30 seconds or so then top up to the mark again and all is dandy. I have heard of dodgy thermostats though, mainly on some of the vag tdi specific websites. They're always on about using oem or nothing. Take the lid off the coolant tank when cold, make sure the heater is turned up full then start the car. Gently raise the revs a bit just to help circulation. Do this for a few seconds, then check the level and top up if needed. It does sound like air in the system somewhere.
__________________
2001 Mk4 golf Estate (Leon in disguise), 1.9tdi, Bosio PP764 nozzles, 35mm drop.
Custom tune by Nytrixtuning
Seatmann is offline   Reply With Quote
Old 05-01-2011, 12:14   #7
beezanick
Senior Member
beezanick's Avatar
beezanick has 10 points
Shouldnt the coolant be blead by removing the temp sender?
__________________
Mk4 52 plate 130TDi sport - in BLACK
beezanick is offline   Reply With Quote
Old 05-01-2011, 22:08   #8
MJ
MJ's Avatar
MJ has 90 points
Quote:
most of the vw group systems can sufficiently bleed themselves, if not then there will be a bleed screw at the appropriate point.
Never personally had to remove one to bleed a coolant system TBH.
__________________
Old 07-01-2011, 18:19   #9
FRich
Posts: n/a
Ok, done a week of driving to work and I'm still loosing coolant... The heater is behaving its self now but every morning I am topping up the coolant which drops between the min and max lines... Thats a lot of coolant to be lost over a 45 mile round trip! I'm fearing head gasket although there's no coolant in the oil and vice versa... What else could it be before I bite the bullet? Changed the water pump so its not that even though it was causing a problem which did lead to me over heating and having steam pour out of the expansion tank (cap changed after this)
Old 07-01-2011, 18:44   #10
Copey
Senior Member
Copey has 10 points
Ive had practically the same issue since ive had mine, never been able to work out what the problem was, it looses a little bit of coolant but im toppping mine up every so often, not every day.
__________________
03 Ibiza TDI Sport - Jabba Remap - PD160Intake - K&N Panel - Decat - Renaultsport Megane 225 - MK5 Ibiza Cupra - Custom VWR IK Eibach Pro's - GT86 - Mods incoming R/R Thread. - Bits for sale!!
Copey is offline   Reply With Quote
Old 07-01-2011, 19:18   #11
MJ
MJ's Avatar
MJ has 90 points
have it pressure tested to see if the level drops.
__________________
Old 08-01-2011, 01:41   #12
FRich
Posts: n/a
is that a common test for a garage? Every time I take it to a garage they say they pressurise it and it doesn't lose any coolant. they'll leave it running for 20 mins and its perfectly fine. They must think I'm making it up lol
Old 08-01-2011, 02:20   #13
Seatmann
Seatmann's Avatar
Usually when the head gasket starts to go the car sometimes idles a bit rough and the exhaust is fairly white because of steam. You don't always get oil and water mixing, more often it leaks between a cylinder and the water jacket. One of the signs is also the coolant pipes get really hard because of excess pressure. I don't know about your car but on my tdi the coolant temp sender is held in with a clip and some of them can be a bit of a crap fit. I would also check any hoses round the back of the engine for slight corrosion and also check that there isn't an overtightened hose clip. I've seen people cutting the end off the pipe from over tightening them. Just get your fingers underneath any joins and have a bit of a feel. If there's any coolant leaking it will feel kind of greasy/sticky. My mate had this issue on his vauxhall and it was a clip to tight down the back of his engine and the garage missed it somehow. I just took the damaged end off and redone the join and that was that cured.
__________________
Old 08-01-2011, 14:48   #14
FRich
Posts: n/a
Well I think I've found the problem. Had a lot of pressure left in the coolant system overnight and my coolant has gone from pink to green... Head gasket time! Although I'm worried because when I over heated I waited about 30 mins and topped the coolant up with cold stuff. So I'm scared I've cracked or warpped the head as I doubt my luck is that bad that the water pump and head gasket went at the same time
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 83
0770chris23, A.m.C_Ibiza1, abbotsmike, adam cupra 20vt, Andrew_ZA, AP2000, attila_tdi, Badger, Bclowes86, beezanick, BigV, bond007sur, car.crash, Copey, cordoba175, coronah, cra19n, Cuprakevlar, dan666, darkhorse, davidif, DeanC93, dmcar02, EdButler, evo2345, f15h, faysal, Gizza, Hobbiniho, Hutch, I<3VAG, ijmok, johnny_M, jon1982, JonLeonFr, JR_130, killbot, kr1s77, LEE69, lm_gauci, M1KEH, markyboy76, mentalmechanic, mick-fr, Mitch205gti, MJ, Mobo, Murray, Muttley, NagaBurns, Nam-uk, NickCupraR, Pew., PLuKE, posterboy, psjunkie, rackha, ruben95, S10EAT, S7UYJ, Seatmann, SLeonTim, slim, smiff, Smoke'n'poke, snk, sonnex22, sportbilly, Steely, Syko2005, tangomachine, thomasa, TNTom, ucchockey, uksteffy, VeeFource, warond, welshmac, WHOZBOSS, WK2010, Yorkshireboxer
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
