Badger5
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 20-01-2011, 20:17   #1
mark_eisner
mark_eisner's Avatar
mark_eisner has 10 points
P0420 fault code
I've been getting a recurring DTC: P0420: Catalyst System; Bank 1: Efficiency Below Threshold
No obvious symptoms but I think the economy is reduced (running rich?)
It's on a 1.2 12V 2003 Ibiza
I have replaced the pre-cat oxygen sensor but the code keeps coming back. The other things that the Ross-Tech wiki says are to check the catalyst and check the intake and exhaust systems. I'm assuming it means check for leaks. The exhaust system I can check easily but the intake system is a little more complex. Where are the places I should check and how do I check? I know there isn't a gapping hole in the throttle body so I assume it will be more subtle.
mark_eisner is offline   Reply With Quote
Old 20-01-2011, 22:26   #2
graham@pioneer
Posts: n/a
We have had a couple of these and fixed them with a replacement air flow meter.
Old 21-01-2011, 08:39   #3
mark_eisner
Thanks, will look into it!
Old 21-01-2011, 08:50   #4
mark_eisner
I can't find any reference to the air flow meter (MAF) for the 1.2. I've looked on parts sites and in my haynes manual, the only reference is for diesels.
Is the part you mean the joint intake pressure/temperature sensor. I think also MAP?
Old 21-01-2011, 09:45   #5
graham@pioneer
Posts: n/a
Yes sorry just a terminology thing
Old 21-01-2011, 16:16   #6
mark_eisner
Thought so, just inexperienced!
Old 24-01-2011, 16:58   #7
mark_eisner
I've just replaced my MAP. The old one had oily deposits all around the probe, is this normal?
Old 25-01-2011, 16:10   #8
canis_lupis
Posts: n/a
Yes it can do from recirculation from cam cover, did it fix the problem?
Old 25-01-2011, 17:23   #9
mark_eisner
Not sure yet, am going for a drive in about 20 mins, the fault code usually only came on after the second motorway journey. It was fine on the first 70 then the code came back up the second time. Quite predictably actually.
Old 25-01-2011, 18:17   #10
seremotors
Dave the Parts Manager
seremotors's Avatar
seremotors has 50 points
Worth looking for green furry corrosion on the O2 sensor multiplug ;-)
__________________
MULTI-TIME SEAT UK 'DEALER OF THE YEAR' & GOLDEN GARAGES REGIONAL WINNER
PLEASE READ FOR T+C'S and FAQ's - http://www.seatcupra.net/forums/showthread.php?t=366731
or click banner to email me direct
seremotors is offline   Reply With Quote
Old 25-01-2011, 19:10   #11
mark_eisner
The post-CAT O2 sensor? Does that just need a clean or sensor replacement?
Old 25-01-2011, 20:08   #12
mark_eisner
Is there a way to check what is broken/has a bad connection with vag-com? Looking at the outputs etc to see if it's nonsense? I just don't know what readings are normal etc...
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 48
221084clarkey, aarmdlr, Alan_, Arkaig, Bean, Biker, bisto48, Blanco92, britishsligean, Chrisallen649, CJS-90, Copey, Cos, Crafoo, Cupra Kid, cuprapowerpaul, cutes6, DarrellW94, davidcaffery, Edward9th, GlanzaV, Gorbstein, Guinness, hamlyn, higgi, jonny_mcc, Jordanwaterhous, kinggy999, living2xs, mark_eisner, Mashburn, Mattyboy1, matylad, monk3y303, philrom, rod the sod, seatcupramad23, Seatmann, seremotors, Shlomi, StarkIndustries, ste_p23, suditaliano, tonycane, Viking, wenman, xxjay247xx
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
