SERE
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 05-03-2011, 18:22   #1
Klone
Senior Member
Klone's Avatar
Klone has 10 points
Forge Split R - A Rough Guide
Hi guys,
After looking into a Forge Split R since i purchased the car... i spent hours and i really mean hours looking into the so called "limp mode lottery"
I have also spoken to many different tuning companies about them with varied answers from each.
So, when one came up for sale on here... i snapped it up!
Fitted it yesterday, and drove home 20miles with various levels of boost being used:
  • Gentle town running
  • Pulling away boost
  • Hard over taking boost
  • Prolonged levels of over taking boost (dropped to 30 on the road and then hard accelerated to 70)
None of these caused me any problems. No turbo chattering, No leaking and No drop in pressure (from what i can feel as i am not running a Gauge.)
****I would like to take this time to say the following: I cannot and will not accept any damage if you do follow this guide... its just a rough from all the information i have researched.****
Right, so onto the valve. the valve comes in black or silver obviously... and on taking it apart it only has a spring and a piston... no o-rings just a tiny bit of grease.
The piston moves up and down and lets the pressure back into the engine via the bigger opening, and lets out some via the smaller opening.
The way the valve works is effectively its leaking pressure but all of a sudden giving you a PSSH. its not like a scooby, but certainly sounds nice
Fitting:
Fitting is easy just undo the old jubilees, and cut the cable tie (if not undo the small jubilee) that holds on the hose on the top of the DV
Fit the new one in place, with the trumpet face the front of the car. i have seen that some people mount it so that the trumpet faces the firewall, which i havent tried yet.
tighten up the jubilees and put on a new cable tie if needed.
Tuning:
Now, this is a bit of a trial and error sort of affair. i have found the following around on the internet, but as i said... very trail and error sort thing. what i found as a generic rule of thumb is the following.
The top of the valve has a ratchet system, which sets the amount of boost it "leaks". too much, and you get limp mode, too little and you get turbo chatter.
Turn the valve anti-clockwise all the way until it resists... you will know its at the end.
Then you will need to turn the top clockwise a certain amount of "clicks" to set the air flow.
after searching Audi, skoda, Seat, VW forums and speaking to a whole host of tuning companies... i have made the following list as a rough guide.
Normal engine - no remap: 15-18 clicks
Stage 1 remap - 24-28 clicks
Stage 2 remap - 26-30 clicks
I did mine last night and started at 26 to be safe... and ended up setting to 28 for a bit more PSSH.
I have still got my bonnet liner and you can still hear it as you drive along... but its not mentally loud or chavtastic.
Obviously, if you get limp mode... you need to adjust it, which im afraid is just trail and error... turn the engine off turn one way (i would guess anti-clockwise if you followed the above) and then start the car and test.
I will be monitoring mine over the next few weeks, but as yet... i havent had any problems, and the car is as torquey as ever and boosting as hard.
i hope this guide (if you would call it that) helps some people out and encourages people to get one... but if you decide you dont like the PSSH of it, you can blank it off and run full recirc anyway!
Andy_Lang
Ging3r
Forge Motorsport
AMD Essex
__________________
Stage One REVO, Coilovers, Decatted Custom System, RS6 Reps, HIDs, Split R
Reader's Ride//Forge Split-R Tuning Guide
Klone is offline   Reply With Quote
Old 05-03-2011, 18:43   #2
Tomas
Tomas's Avatar
Tomas has 10 points
Mines been sweet just put it on the way it came lol! Put it a little way clockwise (4clicks?) and it seemed to increase lag in a lift off-press again situation, so back almost to the preset now...
Love the Pssssshhh, turbo power sucks without it (no pun :L)
Tomas is offline   Reply With Quote
Old 05-03-2011, 18:44   #3
Klone
Senior Member
Klone's Avatar
Klone has 10 points
i couldnt find how many clicks its preset at im afraid... but yeah i do love it. Pssssssh
__________________
Old 05-03-2011, 18:49   #4
Tomas
Tomas's Avatar
Tomas has 10 points
We should start a tread for peoples Leon DV videos... I need to get a life.
Old 05-03-2011, 19:19   #5
cupra_mike
cupra_mike's Avatar
cupra_mike has 10 points
good thread
__________________
Seat Leon Cupra
cupra_mike is offline   Reply With Quote
Old 05-03-2011, 20:01   #6
Topsie
Topsie's Avatar
Topsie has 10 points
Mine goes psssshhhh, and if i'm just cruising i get a awwwwsome chatter, honestly it sounds better than sex.... lol
Topsie is offline   Reply With Quote
Old 05-03-2011, 20:28   #7
sambryant
RoadRunner meep meep
sambryant's Avatar
sambryant has 20 points
Quote:
your not doing it right then
sambryant is offline   Reply With Quote
Old 05-03-2011, 20:31   #8
Mo Arif
Stage 2+
Mo Arif's Avatar
Mo Arif has 10 points
Ha! ^^^^^
__________________
Click My Readers Ride - mk1 LC Stage 2 @ 230 Bhp & 270.5 lbs/ft - Imitation is flattery
Click My Readers Ride - '95 Lancer Evolution III - Weekend Toy
Mo Arif is offline   Reply With Quote
Old 06-03-2011, 12:04   #9
Klone
Senior Member
Klone's Avatar
Klone has 10 points
As sam said topsie. You haven't got your split r set up right matey. That chatter is the turbo stalling and will shorten the life of it...
__________________
Old 09-03-2011, 12:19   #10
andy_lang
Senior Member
andy_lang's Avatar
andy_lang has 10 points
Glad it works well mate, and no probs for the advice I always ment to jot it all down in a thread to make sense - good lad!!
After a run at JKM they had it with the bigger side venting to atmosphere, ie trumpet facing the firewall - ALOT louder than before, but this was only after im on a Stage 2, so guess the extra boost / ram air means I can get away with venting a bit more to the atmosphere as theres so much air going down the TIP anyways. Still no issues for me - a year later and lots of track time!
__________________
Forge Motorsport team Cupra on Revo Stage2, Huge custom FMIC, lots of track time gettin ready for the MSV Track day trophy, stripped out &lightened.full carbon roof and spoiler etc
andy_lang is offline   Reply With Quote
Old 09-03-2011, 12:27   #11
Klone
Senior Member
Klone's Avatar
Klone has 10 points
Yeah i spoke to them myself after you mentioned... i dont think i would try it on just a stage 1 though
__________________
Old 09-03-2011, 12:29   #12
andy_lang
Senior Member
andy_lang's Avatar
Lol yer I wouldnt want it that way if I was standard! but SO loud - love it! defo adds character with the pops and bangs for the Zorst, and the turbo whine big up the split-r love and try and shake its bad name from the mooks who dont fit em properly!
all hail the Split-r!
__________________
Old 09-03-2011, 12:31   #13
Klone
Senior Member
Klone's Avatar
Klone has 10 points
haha well i only have the whine... for now
but yeah, the forge Split R gets alot of bad press all over the internet, and frankly it is down to the fitting no the valve..
__________________
Old 09-03-2011, 15:26   #14
cupra_mike
cupra_mike's Avatar
i still dont understand how it was be fit incorrectly? standard is 14-18 clicks starting at say 16. How can this be done wrong?
__________________
Seat Leon Cupra
Old 09-03-2011, 15:28   #15
Klone
Senior Member
Klone's Avatar
Klone has 10 points
a few tuning companies mentioned that some standard cupra's dont like the split r because they are made for a certain amount of air to be recirculated.
Putting in the split r lets some out... therefore drops below the manufactured level...
stage 1+ dont seem to have this problem as they are generating alot more...
that's how i look at it anyway..
__________________
Old 09-03-2011, 15:39   #16
cupra_mike
cupra_mike's Avatar
and would you have set up same as standard of turn it up?
__________________
Seat Leon Cupra
Old 09-03-2011, 15:41   #17
Klone
Senior Member
Klone's Avatar
Klone has 10 points
yeah for mine... as im running stage one (210bhp) i just used more clicks
its all about knowing the right and wrong noises it should make.
Turbo chatter = bad
Boost leak = bad
Tsssh = GOOD
__________________
Old 09-03-2011, 15:43   #18
cupra_mike
cupra_mike's Avatar
OK. what does turbo chatter sound like? lol
__________________
Seat Leon Cupra
Old 09-03-2011, 15:45   #19
andy_lang
Senior Member
andy_lang's Avatar
turbo chatter is stalling the turbo. a thud thud kinda noise.............. youl know it when it happens - lol! not to be confused with the split r chatter and turbo chatter! all a bit confusing! but basicly turbo chatter is loud, split r chatter is subtle.............
__________________
Old 09-03-2011, 15:48   #20
cupra_mike
cupra_mike's Avatar
ah right ok so it would sound awful and would know straight away? Any way no point messing with something thats perfectly fine is there
__________________
Seat Leon Cupra
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 418
.Pat, 1.9...stefan, 150cupra, 1975jcbg, 20vturbocupra, 45_CB, aaron-gardner, aaronipswich, abs111, Adam+Rhi, adambudders, Adman77, adulka, Adydnt, akchappers, Alex@Forge, andy g, andy.morgan, andy110478, andypotts1981, andy_lang, Ape, Applemobile, Ash.LCR, aveitson, aviaa25, bakewell001, Barney3000, barry4ord, BBoy82, BearAttack, belly91, ben450, ben_edwards30, BEOWULF, big sie, bigG622, bishy, blackcupra180, Blobster, bmknight, BobbyCupra-R, bogs, Bosh 225, Bret, Brettyboy, Burchyboi, Byard, caindey, Cainey, Cammy, car.crash, carlos73, Cassity, Charlie20v, CharlieRCupes, chevychase, chownr, ChrisGTI, Chrissy20vt, chris_200120vt, Chuggy, Cjam, clackie, clarky_gtr, cliveyp, clutchitupson, condi, copey_cupra, cossie1, costello, Crafoo, crimeblitz, cupra 8150, Cupra Chris, Cupra Paul, cupra r, ash, cupra.al, Cupra137, cupra786, CuPRaCaN, CupraCraig225, cupradan, CupraRmark, cuprastoffs, cuprastupot, cupratdi53, CupraTurbo81, cupra_mike, cupra_r_ick, customchrisx, cwharreld, czaki, D.K, d3lboy, d3m0niTe, d4n91, daft_ninja, Dalicin, damo-cupra, Dan29, dan7975, Danny Emmerson, Dannym, DaNnY_LaD, Dante L2A2, darius5779, DarrenJ, Davego46, David101, davyp, daz20vt, DdraigR, dean s, Degenatron, denzil691, dfawbert, DGF264, DMackie, Dodgyp, Double-6s, Dozer360, dreago 1, drew FR, Drew O, drka-drka, dtmwelburn, duanedibbs, Dudfield, d_darko, ebo007, eliran1987, elviscat, eugmul, evo2345, ex888, eybic, fa11ows, FASTER, fcuknafe, FINCH, fiori, FlexLeon, FLK, ForgeMotorsport, fossie, foxes, FRdubzy, G2, Garry_T, gary87, Gav_Kara, gaz cupra, gazR, george_seamons, GlanzaV, godber225r, greck999, gregorsco, GreigAKAHendo, gti dan, Gubien, h7 cya, HallycupraR, halsall1987, hamlyn, herb2578, hixonseatboy, Hullcupra225, iamseanyboy, ianmessy, ijmok, itfben, J90hrv, j976rna, ja-mo4, jackett, jackoni, Jacko_lcr, jack_1.8t, jags1805, James.Judd.1, james0560, jamess1989, jamfull, jamie1, jamielee, JamJay, Jane_LeonCupraR, JCLcupra, jezsidewalk, jimdancar, Jimjum, jimmyboi, jim_bling, jj2007uk, JKM, jmcuprar, JMS, JoeBrooke, JoeCav, john_tdi, jok0212, Jon-Boy, jonathangosbee, jonathan_phang, jonesy118, jonny440, junglist_matty, Jyde, kaspa_dtz, Keithslippery, Kev07, kevinking2020, Kiirst, killieboy123, kilobrown, kingy89, Kirky.aj, klemenmico, Klone, kongenafKbh, l.cupra, l30ncr, Lancashire Lad, lcrsammy, LEE69, Leepj, Leigh200sx, leons_ leon, Leon_1.8T, Leon_Chris, Lewis 9092, liam_91, lloydie, lobs84, Lodey23, lostleon, m.stonehouse, M14KCY, M1C VX, M@rt, Mackin92, MarcGreenaway, Mark300zx, marksnoop, matt-tsi, matt1288, mattblair, MattJAbela, Matty's_Cupra, Matty1986, MELLY85, metroarmadillo, MexxT, michaelvrs, michaelward, micksid, mike vrs, mikebrennan, Mikkel FR, mister_bob, mjl_100, mjones, Mk1 banana, mk1cupradave, Mo Arif, motty225, MPJ88, Mr. X, MrBen2k7, mrdavies, MrSix, mty12345, Murdered LCR, Muzza1742, Myke_pt, n20mrp, nd-photo.nl, ndbrgr, neil, newtimecupra, nhodder, nick stevens, ntcupra, nwmlarge, oldskool, oldskoolzzz, onvi tom, Overture, Ovni_cupraR, paul26982, paul6316, PhillyM, Phoenix27, pistik1409, poliq, Pooky, porter555, powermad, premo, psjunkie, psycho6285, Pudders_, QU4RESMA, rainbird, RavingRichie, Readie46, reaperr, RedFive, revo carl, richardbelfield, Richie1985, richprince, Richvincent82, rickcuprar, rily245, Rob Kelz, robertbadlad, Robin20VT, rock n rolla, RockSteadyEddie, Rodie121, Roohul, rs-tuner, RS6, rs_jon, Ruff Ryder, RustycupraR, S's Cupra, s33vem, sambryant, samcash88, Scam, scott20vt, Scottage, scotty18, Scrivs, Seal_LCR, SEAN_P_, SEAT-MAD, seatcupramad23, SeatR, seat_cr, Sepa87, sh4rk, shadie69, shane_0121, si-cupra180, SiGainey, simon69, sirjimalot, Skefs, skinny04, slimwiltaz, smitwhit, smudge2011, snags, speedfreak, Spirit Furtive, spoons86, Squar, srai, Steely, StephenJ, steve carter, Stewfo, stornolad, stt, Stuart_cupra, Stucupra, SubZero, super_electric, suzsv650, sye, s_purs, t0m, Taz, ThatGuy, The gaffer09, TheMikeh, toby bwoiii, Tom Novy, tom0311, Tomas, tombos9, TomJackUK, Topsie, torax10, tprescott27, Tr1ck, Trancer, traumapat, Trond, UFO Yellow, uksteffy, unkle funkle, unknownuser1, vernsaudis3, VT86, vw-aj, wade.k10, wayne n, weerobocupra, welchy, wesson12, Wiggy20, will130787, wisejason, WiSK, Wolvo-Oleg, x24sevenbikerx, x637ufs, Yatesey8527, Yatsy999, yellowcupraR, zippy88
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
