Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 04-08-2011, 18:48   #1
AndyC567
AndyC567's Avatar
AndyC567 has 10 points
Gear Linkage Adjustment
Ever since I got my 130 TDI Sport back in April I have been slightly disapointed in the notchy gear change.
It feels like the linkage or something at the bottom of the stick needs greasing or something ?
I have been searching through the forums and it would seem that the Mk4 uses a cable system which can be adjusted.
Many have said it feels like a new gearbox if it is adjusted properly.
So, has anyone ever done this, is there a 'How To' anywhere or does anyone know the correct procedure required to make the adjustments ?
Thanks guy's.
__________________
Seat Toledo SE 1.9 TDI
and now..
Seat Ibiza Sport 130 1.9 TDI
AndyC567 is offline   Reply With Quote
Old 04-08-2011, 20:06   #2
great_kahn
Spooge
great_kahn's Avatar
great_kahn has 20 points
This vid explains all. Ive never done it myself however, but been meaning to try...
He demonstrates on 5 speed, but shows 6 speed differences at the end.
__________________
"Driving an underpowered car on the motorway is one of the most dangerous things a man can do. Itís up there with sticking your middle finger in the bottom of a sleeping tiger".
great_kahn is offline   Reply With Quote
Old 04-08-2011, 21:58   #3
AndyC567
AndyC567's Avatar
Thanks for the link, great help that..
It looks easy enough, does anyone know if this can be done easily on the MK4 ?
I guess it is to much to hope that it all can be done from the top via the engine bay ?
Thanks again.
__________________
and now..
Old 04-08-2011, 22:06   #4
great_kahn
Spooge
great_kahn's Avatar
Thanks again.
No expert but removal of the battery and airbox might be needed.
__________________
Old 06-08-2011, 19:30   #5
AndyC567
AndyC567's Avatar
Managed to do this today..
I did remove the Battery box so I could see what I was doing, but now knowing where everything is I reckon I could do it by just removing a plastic air intake pipe and getting my handes between the battery box and engine cover.
Not a bad job, the video says it really..
My gear change still feels a bit strange, but I have to say it now selects better.
I guess a 7 year old cable change is never going to feel like a newer direct change !!
__________________
and now..
Old 07-08-2011, 22:33   #6
great_kahn
Spooge
great_kahn's Avatar
Gearbox oil change next maybe?
__________________
Old 08-08-2011, 22:20   #7
philje123
Chug chug
philje123 has 10 points
Just done this one mine.
Had to hold the gear selector down on top of the box manually as the little locking pin was broken and looked like someone had butchered it with something at some point. The when I tried to push it the bloody thing snapped off! Including the metal housing. I've sealed the hole up for now though... that's something to do another day!
On a positive note the gear change has a much more positive feel to it and whereas 5th and 6th were very hard to engage before (had to push the stick as far right as it would go!) they both slip straight in.
I only had to remove the air pipe from the front of the engine and that was sufficient to access everything... until the pin snapped off anyway! lol
Phil
__________________
Cordoba SE TDI 130
philje123 is offline   Reply With Quote
Old 09-08-2011, 00:07   #8
tomhowroyd
Glacier blue pd130 sport
tomhowroyd has 10 points
VEry tempted to do this, just wondering how big of a difference it will make, compared to the risks of messing it up!
tomhowroyd is offline   Reply With Quote
Old 09-08-2011, 08:26   #9
philje123
Chug chug
I would say that unless you are finding it difficult to engage certain gears etc then do it. Other wise there's not much point.
I think mine only went wrong because of whoever had a go at it before me and broke the little pin.
Phil
Sent from my HTC Desire using Tapatalk
__________________
Cordoba SE TDI 130
Old 09-08-2011, 20:59   #10
AndyC567
AndyC567's Avatar
Quote:
I would say there is very little than can go wrong..
I thought the whole process was very easy once you have access.
It deffo makes the gears engage better, although it didn't address my dis-like of the feel of the gearbox.
worth doing..
Go for it, it is not difficult at all.
__________________
and now..
Old 12-12-2017, 15:43   #11
Homr1975
Newbie
Homr1975 has 10 points
Smile
Just wanted to say a massive massive thank you to great_kahn and others for posting the video clip to this-itís enabled me the confidence to do it myself,video was excellent and made the process idiot proof.
Got my reverse gear back and I can confirm it feels like a brand new gearbox
Thanks so so much
Homr1975 is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 103
00Rupert, aanev, Adam4D, AlexK1, AndyC567, AvoK95, backus, Badger, Blanco92, bubbles1, Cammy, CGD217, Cupra Tommy, cupragirl, Cuprar72, custard22, Daatta, dalegolf215, Dan FR, DanHX, dann2707, dannybaldwin, darkhorse, davidcaig90, Discostew, Djwrighty99, dm222, Dowson1993, Dt-spd, eddie_cupra, ElaD, Elliman98, f2evotomo, fishlover900, Flyin Scots, foxes, garethgje, george130, Gizza, great_kahn, h3dshot, HDi--Power, Homr1975, ian_106, icclebug, irf, JacketJ, james_cupra, Johnsbegood, jonial, Josh_evans, JPS3290, JR_130, lcrsammy, Legion1978, M1C VX, mercian1, mick-fr, milner575, Modelmakerman, mymorph, N1njaboy, Nath., Pew., phat purple one, philje123, push, pyle, R7 Adam., racingsquirrel, redlinemike, rf860, Richoscos, RMJ, rodger, RSAlex, RUM4MO, Ruthers, Sam, SEAT4Vicky, Seat_FR, secret.squirrel, Sharaf, skinz, smithy363, spen, sydoggkdy, Syko2005, TAOTAO, tcm1106, tdi_swedge, teeth2k, toadster, tomhowroyd, tomo336, Trx-33, tubbyandy, unclebob, Warning, wild willy, wrayvon, xDaNx
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
