Revotechnik
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net Sponsors - Trading area » Badger5
Badger5 Badger5 Ltd - Performance Tuning - Race Proven Products & Honest Advise....Forge,Ferodo,AP,Custom Code,REVO,H&R,Eibach,Vibratechnik,SPEC,Compmotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more...
Reply
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 11-11-2011, 13:30   #101
ibizacupra
Jack-RIP my little Friend
ibizacupra's Avatar
ibizacupra has 50 points
S3 Test with just 80mm TIP fitted.. JR filter on there previously
Latest Dyno of an S3 on the 80mm B5 TIP only mod made, previously JR & normal silicon TIP, on stage 2 REVO (early revo 4bar code). Cars setup on B9T9 plus 4.5deg more ign on unisettings (ealry revo 4bar code was conservative compaed to current stage 2s)
Torque AND Power gains across the board, and reduced spool time.. MORE TORQUE EVERYWHERE
__________________
BADGER 5 LTD: NEW WebShop >> www.badger5.biz
RACE PROVEN PRODUCTS & HONEST ADVICE:
Contact:01453 822880
Bespoke Big Turbo conversions,AEM WMI,Forge,Ferodo,AP Racing Brakes,Custom Mapping,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compomotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more...
http://www.badger5.co.uk
email me at:bill@badger5.co.uk
ibizacupra is offline   Reply With Quote
Old 11-11-2011, 13:39   #102
prawn
prawn's Avatar
prawn has 10 points
Lovely sustained torque curve on that one Bill, nice increases everywhere!
Have you got the other sheet with the numbers on? Looks like it's gone from ~248 - ~265 ish, and 250lbft - 265ish? You seem to be testing loads of these this week!
__________________
Understeer is when you hit the wall with the front of the car, oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
prawn is offline   Reply With Quote
Old 11-11-2011, 14:00   #103
ibizacupra
ibizacupra's Avatar
I am fitting quite a few currently.. just coincidence I guess they have come within a few days of each other.
When tested "properly" the 80mm V2 TIp has gains everywhere on cars I have fitted to and had results back from... Some mis-information touted from other suppliers to the contrary is simply that, mis-information and unfounded.. there is no higher performing TIP for K04's out there... All I see is faster spool, more torque, and longer sustained torque, hence more power. 80mm TIP outperforms 3" TIP - PERIOD
__________________
Old 11-11-2011, 16:40   #104
wild willy
wild willy's Avatar
wild willy has 10 points
Keep em coming Bill, very impressive.
Whats interesting with this is that revo fueling is spot on. I wonder if its the LCR code only that runs too rich.
wild willy is offline   Reply With Quote
Old 11-11-2011, 16:42   #105
seatcupramad23
kc4even23
seatcupramad23's Avatar
seatcupramad23 has 10 points
interesting i spoke to revo on the phone this morning about that that and the guy confirmed that it should be in the mid to low 12s , under 12 sounds like a tiny leak somewhere but mine was smoke leak tested and no leaks so confused ?
__________________
audi s3 now here http://www.seatcupra.net/forums/showthread.php?t=329363
seatcupramad23 is offline   Reply With Quote
Old 11-11-2011, 16:44   #106
wild willy
wild willy's Avatar
Quote:
I've discussed it with them too but they won't have it, maybe time for a new thread in the appropriate section so as not to muddle this excellent thread.
Old 11-11-2011, 16:55   #107
seatcupramad23
kc4even23
indeed
__________________
Old 11-11-2011, 16:58   #108
wild willy
wild willy's Avatar
indeed
http://www.seatcupra.net/forums/showthread.php?t=335398
Old 12-11-2011, 16:05   #109
AwesomeAl
Sales @ Awesome
AwesomeAl has 20 points
Now available from Awesome!
__________________
AwesomeAl is offline   Reply With Quote
Old 12-11-2011, 16:58   #110
adambudders
adambudders's Avatar
adambudders has 10 points
little sneak peak of an 80mm TIP working well, increasing power and torque everywhere. Zero losses against the normal silicon tip on the car previously.. just gains everywhere
Unlike some BS mis-information spread by some folks who are comparing Apples and Pears..
3" aint 80mm 23% Larger Cross Sectional Area on V2 80mm B5 TIP over and above 3" TIP
Revo1 before on silicon TIP/Neuspeed filter B7t4, Revo2 after with 80mm V2 B5 TIP/JR B8t5
just picked my car up from bill and the guys at badger5 after having the b5 80mm tip and jr filter kit fitted and a stage 2 revo remap.
impressed isnt the word! it feels amazing!
it pulls so much harder all the way through the rev range. and thanks to the tip bill logged air flow at 220 gs, the highest recorded being at 227 gs, so well chuffed with that.
the actual fit and finish of the tip is spot on and it really seems to have unlocked the potential of the engine!
as bill and the guys could probably hear from the workshop i was losing traction and spinning the wheels in 4th gear!!!
i really cant say enough, not only for this product but also for bill himself. he really takes time to explain any problems or faults so that the layman (me!) can actually understand them.
so, good work that man, and thanks again.
adam.
__________________
04 LCR RUNNING STAGE 2!!! badger5 80mm TIP, JR filter, forge split-r, viper performance, n249 delete, milltek 3'' turbo back, de cat, tx autosport fmic, ebc, s3 strut brace, 285 BHP, 296 LB/FT @ badger5
adambudders is offline   Reply With Quote
Old 12-11-2011, 20:44   #111
wild willy
wild willy's Avatar
Quote:
About time you sold the best TIP on the market, good news.
Old 13-11-2011, 01:34   #112
chris-gti
Posts: n/a
Hi,
I want to buy it.
I tried several times to contact you via email.
Sorry, no answer .. ; (
Or you get no message?
Thanks!?
Old 13-11-2011, 11:03   #113
seatcupramad23
kc4even23
phone him its mucch easier
__________________
Old 13-11-2011, 15:41   #114
ibizacupra
ibizacupra's Avatar
Quote:
Originally Posted by chris-gti View Post
Hi,
I want to buy it.
Thanks!?
i have no outstanding emails here
__________________
Old 14-11-2011, 16:09   #115
Spirit Furtive
Spirit Furtive's Avatar
Spirit Furtive has 10 points
Really happy with the results from last thursday so big thanks to Bill, car feels great and now all that I need to do is go stage 2!
Spirit Furtive is offline   Reply With Quote
Old 14-11-2011, 18:56   #116
Damoegan
Sir Bob,a geordy legend..
Damoegan's Avatar
Damoegan has 10 points
Seen this advertised in this months PVW Bill, I thought that someone was copying you already until I read it
__________________
Damien - Back in the game...
Damoegan is offline   Reply With Quote
Old 14-11-2011, 19:00   #117
fourtwofive
Senior Member
fourtwofive's Avatar
fourtwofive has 10 points
was going to say i saw this in pvw nice increase from just an intake amazing. hope it gets good sales as it deserves
__________________
forged 1.9 k03 hybrid build gone but never forgotten
New 92reg mx5 eunos cheap track fun
http://www.seatcupra.net/forums/showthread.php?t=294178
fourtwofive is offline   Reply With Quote
Old 15-11-2011, 00:29   #118
8bit
Awaiting Email Conf
8bit has 30 points
THAT's what I was hoping to see, direct comparison on the same car with otherwise the same mods. Good result, I'll be shopping for one of these as soon as funds allow.
8bit is offline   Reply With Quote
Old 15-11-2011, 17:00   #119
ibizacupra
ibizacupra's Avatar
nice to see it in PVW Magazine
__________________
Old 16-11-2011, 21:01   #120
Murdered LCR
Wide mouthed mofo
Murdered LCR's Avatar
Murdered LCR has 20 points
Will call tomorrow and order a blue one with the Jetex And heat shield
Murdered LCR is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 754
-pseudonymous-, .liam., 150cupra, 1975jcbg, 1johnson1, 20vturbocupra, 265cupra, 2die4, 54321, 747_727, 8bit, 932matthew, @lq!, Aaron87, aaronipswich, AC, adam cupra 20vt, Adam4D, adambudders, adamTT, adeyspec, Adjay, adzer, Aimez, al20v, Alan Shedden R, AlanUK, Alex.W, alexj124, Allan_84, ammo, andy.morgan, Andy360, andycupra, Andydavy, andypandypoos, anni25pd, Ape, arb79, artemis_1991, Artesin, aviii, AwesomeAl, az20vt, Azza_, B3N-R, B47t0n, bailey1992, bakewell001, banksy21, barryk, bazpro, beachy01, beastgtir, BEEFYGTI, BEEiTCH, belfastchris45, ben@amdessex, bendohhh, bendyb633, benfacer, benoit62, benzy50, Ben_225, ben_edwards30, BEOWULF, Berg, big eck, big rich, Big-Pete, Bigcheese, bigdirtyturbo, BIG_Y, billyhas, bkingb, Black Mamba, Black2, blackmagic20vt, Blucupra, BMH 25, boabym, BobbyCupra-R, Bogwoppit, BoostHard, BoostinHard, boostjunkie, Bouncerbeater, Br!dges, brad1002, Bregt14, brendanb1801, Bret, Brick_Top, broom, BryanWalker, budweiser28, bully, Bunter6, c-n-d21, Cainey, Cammy, caney, cartercupra, cartney_265, CatB1, chaazza, chads77, Chambers_CUPRA, CharlieRCupes, Chefoo, Chiffs, chorlton, chris c, Chris rickard, Chris-cupra R, chris1788, Chris4877, chriscupra02, ChrisCurzon, ChrisGTL, chris_200120vt, chris_ffx, Chuggy, churcherj, CJRamze, CJS-90, Clarkeez, CluneZ, clutchitupson, cndutton88, Coffeelio, con81, Conzo_f, Cooper_81, coops10, Copey, country, Coupegrale, CrabPaste, Crhome, csd_19, Cupra Grant, cupra r, ash, Cupra Tommy, cupra-barn, cupra-db, cupra-esx, cupra-rich, cupra.al, cupra02ben, cupra118118, cuprabaz, CupraCraig225, cupragirl, Cuprakev, CupraMuscle, cuprapete, cuprapowerpaul, cupraR1980, Cuprar88, cuprarsam, CupraR_Lad, cupraslayer, cuprastoffs, cupratdi-matt, CupraTim, Cupra_collins, Cupra_Mat, Cupra_neil, Cupra_R04, cupra_r_ick, czaki, D.K, d1n93r, d3m0niTe, daiedwards5, Dale!, dalegolf215, Damoegan, damonproyer, dan boy, Dan FR, Dan1720v, danblowes, DANBOY, DanCupraET, DaneJD89, Daniel 1.8t, Dani_b19, dann, danny m, Dannyh, Dannym, DaNnY_LaD, darkangel23, Darren7887, Dave_Cupra88, davidcaffery, davidcupra, davidhunter, David_smith_909, dawson86, daz20vt, dazescort, dazjstuart, dazzaboy, DdraigR, deek_cupra, Degsy1, demonic pete, Dennis0201, denzil691, DGF264, Dibs1980, diddles, dieguisimo, DIFT, din_Shaz, Dione J, dj_troopa, DlllonJ, Dmoe, DM_Cupra, DOLBY, Donny9835, Double-6s, draganus, dreago 1, drka-drka, dsj20v, DuamoLCR, dubslife, dugonve, duncinascoob, dvdt, dylantuk, Easy Life, Ebes86, Ed +, Ed King, edbe, eddie_cupra, edewer, EL, ELV, Emibuddedge, Empi5, Ettienne, evo2345, ezza24, F1990, F2 Ed, Fahid82, Feel, Ferryman, filbro, firestorm, Fisher, Fishy, Fl@pper, fletcher20vt, FlexLeon, FLK, ForgeMotorsport, forsaken, Forum Admin, fourtwofive, foxes, frannyb, frenchman, FroggyLCR, Fu Shou, G2, gav525, GavFR, gaz88, gb, George 3G, George12, George657, george_seamons, Gex, ginger3131, GJF47, GMan_88, godzuki, Gokiwi64, Golf-GTI-MK1, Goo, GoogleBear, GR33NY, grahams81, grant 123, Gravesie-363, Gray & Kirsty, Grayboy, Greavesy, gregy_reynolds, gtchucker09, GTi T, GTJEDI, h2xby, h7 cya, HallycupraR, Harris., Hartosh1, harty190486, haydey, Haze, hendo#1, herbie147, Hobbiniho, hodgy, Holdup, hornet boy, Hubbard94, Hullcupra225, hydroextreme, hyphon12, Iamrab, iamseanyboy, IbizaAlex, ibizacupra, IbizaCupra1987, ibiza_95, iDont Smoke, IH786, IlsonDanni, Impulsive87, INA, irf, Israar, J@mes, J@mes W, jack_1.8t, jaf2212, jake, jamandspoon81, James R., James.Judd.1, james.l, James23Parkin, james291, james6583, jamfull, Jamie225, jamiea69, JamJay, jase750, Jason-R, jasso86, JayFR150, jaypee, JDUB 20V, jduggz08, jenk, jeroencupraR, jesta1865, jezer101, Jimmy-james, jlhiggins, jmcuprar, JMS, jms_cupra, joe-20vt-toledo, JoeCav, John Lindsay, jonathanp, jonathan_phang, JonTelfer, josh.evans, JoshDoubleYou, Joshh, JU5 2 SLY, Judgejim21, K451M, kane88, kazand, Keithslippery, Kev, kinder, Klaus71, kohmikey, ko_racer, kr1s77, krisbutler02, kriso, Kruga, L.R.C., L14M H, L16YDW, Larry225R, LCR 225, LCR350, LCRMartin, LCRnorwich, lcrsammy, lc_allan, LEE69, Leon1600s, LeonFR07DSG, leonmk2cupra, leon_lee, littlefella, littlejon, living2xs, lmiller, lm_gauci, LongDave, loonitic, Loony R, Lucio Bravo, M1KEH, Mackin92, maddox, Madmile, madmonk, magicoi, MaickS3, majesty78, Makam pete, Mandip, manhota, Mao, marco cupra, Marcus_550, Mark One, Mark300zx, marksnoop, Mart, Martyn, maryius, MatP, Matrix, Matt lcr, matt88 lcr, Matthewsarg, Matty's_Cupra, mattygreen, mattyh001, mattyholmz89, Matt_75, matt_s, matylad, mc funbot, mcblow, McDonutz, MCupra85, Mecyt, Method, metroarmadillo, Mick288, mickeyp88, Mike R, Mike225, mikebrennan, Mikefish1, mikemk4gti, mikerowe, Mikey P, Mike_08, Milan20VT, Miller 20vt, millzeee, milner575, mini_racer, miscreant, MJ27, mk4 cupra, mk4dub, MM95, Mo Arif, moforde, mogz83, Monkeyspit, mookster, morrischad, MostWanted, motty225, MPJ88, MR OV51LTA, Mr Roboto, Mr. X, mugge, Mukkyman, Murdered LCR, Muttley, n1ff, n1scottyboy, NAB_ARCK_86, nally270lb,TQE, Nathdavies91, Nautilus, nazamin, nd-photo.nl, Neil82, newbs, NiallCupra, nicckko, Nick G, nikstar, Nimzy, Northerner, ntrueman, Nutkin, Oj 89, old yella, Oliveracc, Oliver_findlay, onvi-cupra, OvEr_KiLL, OVNIWCE, ozaudio, ozzymyster, P1N3R, p34ch3y, Parr17, parsons, patmc123, paul-murphys, paul6316, paulphillips20, pedro1989, Peter 87, peter_cupra197, petey085, phatchoonz1, phi1, PHIL LCR, philrom, PhilW, Phil_JJ, Phoenix27, pigeon fancier, Pimped up vario, Pingu101, PiperRS, pj1985, plattsy, poliq, Pommeh, Pons-93, posterboy, potter88, powlzy79, prawn, Prebs, prezf, psycho6285, QU4RESMA, quintonrose, r055i, R1ch85, R333DDX, R4cup, RACK, rainbird, Raks, Ravey_Cupra, RDS, RDS1972, Readie46, ReDBull, Rgm racer, Ric 2001, Rich79, Richard123, richicupra, Richy Cupra, richybigman, Rick1.8t, rickste_r, rickyb90, Rico76, ric_rt, Rivva, RJohnson, RM1988, roadrunner88, rob - 73, Rob Kelz, rob929, Robbie C, robboz, RobDon, Roffel, rogerw86, roly, Ronin225, Roohul, Rory1984, RS6, rsmith, rsmith713, rsrich, rudgey, Russler, rv_y, Ryan6926, rydogg09, ryno, S's Cupra, s1mon, sabri747, SadaEldesse, sambryant, samcash88, Scam, Scott-o, scottieboy89, scotty18, Seal_LCR, Sean886, seatcupra, seatcupramad23, Seat_FR, Segger, sergi0, shaun@amdessex, Sheekey, Sherman1991, shidoshi, Shmoo, sida, Sile-R, Simon Bowerman, singh123, Skovrs, slappy_dunbar, slimwiltaz, Smoki333, smoothuk, sm_cupra, sovk1n6, speedinsaxo, spen, speters2001, Spirit Furtive, spoons86, Sprogpole, Squar, st200john, stani540, stevekkk1, SteveTDCi, Stewfo, STOCKY, stonemichael, string, stt, Stuart83, stubee, sunilbass, supa_sam, supermatt, supermoto, Supershorty, supersticky, swedey21, Sxanth, t0m, T108, taffyR, TAOTAO, tarzan, Taz, taz95, tchallenger, tdi_chris1, tedvagas, terryt, Tessitura, Tfsi_Mike, Thafussa, ThatGuy, the parrot, threadsta, three_cross, Tigertim001, TILLIO, TimJohnson, tipping44, tj_ryait, tobi20v, toledo.ro, Tombob1080, Tomer 20VT, tommy224, tommytucker, Tomyz, tony323ci, toocoolpash, toosmiles, traumapat, Trigg, triggster, Trublu07, truCido, Tucker157, tufftybloke, tully78, turbo87, turboboy, turboholic, turbomick, UFO Yellow, uksteffy, underpressure, usp, Vaughny, vern, vroomtshh, vrsix_, vstuning, vw-aj, vwdom, vwtrev, W11TTX, wagcupra1, wakko, wanna_cupra, wardyworld, wayne n, westallc, wezza12, Wiggy20, wild willy, wildrides, Will.H, Williams_11, Willie, willows86, window60, Wippit, Wolvo-Oleg, woodlehouse, worzel, x24sevenbikerx, xDaNx, xJabZ, xJmagik, Yatesey8527, yessar_kd, YIN, yogie, Yohan87, York, youngyWHU, ySoCereal, zebangler, zomby, _chris_
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
