Service light/spanner
DazJohnson
If I remember rightly...I just turned ignition off, press and hold trip reset (button on clocks), turn ignition on (so check lights come on), keep holding the reset button for about 10seconds.
Or get someone with VAGCOM to plug their laptop in
VWscooby
288
Durham
I think I turned the engine on, turned the trip reset switch to the left for 5 seconds, turned the ignition off while still holding the switch to the left then turned the igniton on and kept the swtich turned for another 10 seconds.
Of course the easiest way would be to use the forum search function and try the ways that hundreds of people have already posted ;)
Ibiza_Dave
The exact answer you want is in your manual my friend :)
Sent from my GT-I9300 using Tapatalk 2
chrisRibiza
1,194
51
From memory it's hold in the trip reset button, turn on the ignition as you are still holding in the button then turn it to the right for a few secs.
That was on a 1.4 Ibiza.
